Question about ASUS A7N8XVM-400 (DSAUA7N8XVM400) Motherboard
DISPLAY PROBLEM NO DISPLAY
  • Anonymous May 11, 2010
    what motherboard do you have ,make & model number,
    is it a new mobo you are trying to installing.
    are you using the onboard video or a seperate video card pluged into the motherboard.
    what operating system are you using
    this will help me to help you
    Terry
    President:
  • 2,351 Answers
Hi sulip, your board uses an Integrated nForce 2 with TV-out video card. The nForce shares your system memory to function.
If you have not made any changes to your system memory, I suggest you follow these steps.
1. Please upplug the power cord from the PC
2. Remove your system memory (if more than one DIMM is being used), remove one at a time.
3. Using some house hold alcohol & a cotton swab lightly damp, clean the memory's copper contacts.
4. Blow out the DIMM slot with canned air. (If you have some).
5. Firmly & evenly re-install the DIMM. Do the same to the other DIMM.
6. Plug your power cord back in & start the PC. (do you have display)? If yes than we are all done.
If no, than recheck the cable connection from the PC to the monitor. (good connections). If possible test your monitor by hooking it up to another PC or notebook.
Your board can also use an AGP 8x 1.5volt (only) video card.
You can buy an AGP card or borrow one from a friend & add it to your system. If you get display with the AGP card than your integrated video card is defective.
In case you need to buy an AGP 8x 1.5v card you can find one at this link below.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3569995&CatId=318
This card uses the 1.5 volt spec.
It also has a Lifetime Warranty.
Good Luck!
If I can be of more service, just ask.
Mike
Posted on Mar 26, 2008
SOURCE:
Hi i have an apple display connected to my macbook
Unplug the display from your macbook, and restart your macbook, when it's fully restarted and you are logged in, plug the display back in, then check to see if it is detected. Macbooks don't like to be put to sleep (shutting the lid) with a display connected, this causes issues with display detection. So always unplug your display and wait about 5 seconds before closing the lid on your macbook, and when you open the lid, wait another 5 seconds before plugging in your display. The only time it is acceptable to leave the display plugged in when you close the lid is when you plan to use the macbook in clamshell mode, this is done by plugging in and configuring your display, shutting the lid, and then "waking" the macbook from sleep mode with an external mouse (wired or wireless will work). That will start the macbook using the external display as the main display, without even turning on the macbook built-in display. Never connect or disconnect an external display when your macbook is off or in sleep mode. Have a nice day.
Jun 26, 2010 | Apple Cinema Display Flat Panel Monitor...
No display 6300 nokia
this problem is display IC or display. solve this problem by change display or display IC . formate by software.
Jul 30, 2009 | Nokia 6300 Cellular Phone
Change time
Hey here is something you can use to adjust the time on your T7206.To Change the Time:
1. Press the CHANGE softkey Display will read: "Hour:
2. Press the CHANGE softkey Display will read: "Hour: _ "
3. Enter the new HOUR. (in 24-hour format - Ex.: 5:00pm = 17:00. Display will then read the new Hour programmed.
4. Press NEXT Display will read: "Minutes: # # "
5. Press the CHANGE softkey Display will read: "Minutes": _ "
6. Enter the new MINUTES.
To Change the Date:
1. Press NEXT Display will read: "Date DD MM YY"
2. Press the CHANGE softkey Display will read: "Year: # # "
3. Press the CHANGE softkey, (If the year is incorrect) Display will read: "Year: _ "
4. Enter the new YEAR Display will then read the new Year programmed.
5. Press NEXT Display will read: "Month: # # "
6. Press the CHANGE softkey, (If the month is incorrect) Display will read: "Month: _ "
7. Enter the new MONTH Display will then read the new Month programmed
8. Press NEXT Display will read: "Month: # # "
9. Press the CHANGE softkey, (If the day is incorrect) Display will read: "Day: _ "
10. Enter the new DAY Display will then read the new Day programmed
Let me know how that turns out and good luck
Oct 03, 2008 | NorStar T7208 Corded Phone
Printing issue
In order to proceed with the solution to your problem, we'll need to save the current settings on your Crown printer and then restore the printer to its original factory settings as shipped. Your current settings will be saved, and can be restored after we finish this troubleshooting session. You will need to access the printers front panel in order to perform the following settings.
Procedure to save your current printer settings
Procedure to restore printers original factory settings
Procedure to restore your saved printer settings
1. Make sure the Online light is lit and that the display reads Idle.
2. Press the Online/Offline button to take your printer offline.
3. Press the Menu button once. The display should read Operator Control.
4. Press the Right Arrow button once. The display should read Administration.
5. Press the Select button once. The display should read Communications.
6. Press the Left Arrow button until you see Miscellaneous in the display.
7. Press the Select button once. The display should read Save Defaults.
8. Press the Select button again. The display should read No.
9. Press the Left Arrow button once. The display should read Yes.
10. Press the Select button.
11. A few seconds should pass until the display reads Yes Is Selected.
12. Press the Online button twice to take the printer online while the display reads Idle. Your current printer settings are now saved and you are ready to proceed with returning the printer to its original factory settings.
6. Press the Left Arrow button until you read Miscellaneous in the display.
8. Press the Right Arrow button. The display should read Restore Defaults.
9. Press the Select button once. The display should read Factory Defaults.
10. Press the Select button again. The display should read No.
11. Press the Left Arrow button once. The display should read Yes.
12. Press the Select button. Yes Is Selected will appear in the display.
13. A few seconds will pass and the printers display should read Disk And Flash Sys Loader.
14. Your printer will reboot with the original factory settings and return to Idle.
Try a test print. Does the problem still exist?
10. Press the Right Arrow button. The display should read Custom Defaults.
11. Press the Select button. The display should read NO.
12. Press the Left Arrow button once. The display should read Yes.
13. Press the Select button. Yes Is Selected will appear in the display.
14. A few seconds will pass and the printers display should read Disk And Flash Sys Loader. Your printer settings are now restored to their original saved settings
Try a test print, does the problem still exist?
Sep 24, 2008 | Minolta magicolor 3100 Laser Printer
Menu display intermitent
display is disclosed which produces multiple visual displays in an intermittent manner which includes a display housing having a perimeter wall which is transparent during visual display and is an opaque mirror between visual displays. The perimeter wall of the display housing is a composite structure which preferably includes a transparent cylindrical substrate which is coated with an optical film and an opaque mask which defines display windows. Multiple visual displays are produced by a rotating display base which carries rows of rotating display elements. Preferably, the display elements are elongated triangular elements having three image faces which bear images which create the visual displays. The triangular display elements are arranged in a triangular configuration wherein the rows intersect one another at acute angles and are carried by the rotating base. The rotating base includes three display positions and each of the triangular elements includes three display positions. A stationary observer would see nine different visual displays and may see themselves mirrored in between and during the changes of visual displays. The perimeter wall of the display housing becomes transparent as the triangular display elements are backlit along their entire length by elongated fluorescent or neon light tubes. When the light tubes are off, the cylindrical display housing is an opaque mirror, preferably, about its entire periphery and height. Other embodiments of the invention include a single row of triangular display elements, and a rotating display base which includes display faces consisting of only a single display element.
Feb 25, 2008 | Solarism LM-1730 (Black) 17 in. Flat Panel...
Open Questions:
I've got a Avg antivirus 1*888*499*5520 and it was working perfectly... I've got a Avg antivirus 1*888*499*5520 and it was working perfectly... I've got a Avg antivirus 1*888*499*5520 and it was working perfectly... I've got a Avg antivirus 1*888*499*5520 and it was working perfectly... I've got a Avg antivirus 1*888*499*5520 and it was working perfectly... I've got a Avg antivirus 1*888*499*5520 and it was working perfectly... I've got a Avg antivirus 1*888*499*5520 and it was working perfectly... I've got a Avg antivirus 1*888*499*5520 and it was working perfectly... I've got a Avg antivirus 1*888*499*5520 and it was working perfectly... I've got a Avg antivirus 1*888*499*5520 and it was working perfectly... I've got a Avg antivirus 1*888*499*5520 and it was working perfectly... I've got a Avg antivirus 1*888*499*5520 and it was working perfectly... I've got a Avg antivirus 1*888*499*5520 and it was working perfectly... I've got a Avg antivirus 1*888*499*5520 and it was working perfectly... I've got a Avg antivirus 1*888*499*5520 and it was working perfectly... I've got a Avg antivirus 1*888*499*5520 and it was working perfectly... I've got a Avg antivirus 1*888*499*5520 and it was working perfectly... I've got a Avg antivirus 1*888*499*5520 and it was working perfectly... I've got a Avg antivirus 1*888*499*5520 and it was working perfectly... I've got a Avg antivirus 1*888*499*5520 and it was working perfectly... I've got a Avg antivirus 1*888*499*5520 and it was working perfectly... I've got a Avg antivirus 1*888*499*5520 and it was working perfectly...
Oct 17, 2019 | AVG Computers & Internet
See all ASUS A7N8XVM-400 (DSAUA7N8XVM400) Motherboard Questions
ASUS A7N8XVM-400 (DSAUA7N8XVM400) Motherboard Logo
124 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
