Question about Whirlpool MH7140XF Microwave Oven
GE HVM1540DN1BB over the range microwave. Touchpad will not respond. Unit was purchased in July of 2008.Can it be fixed or should I replace It?
We had this same problem. I went on youtube and there is one link called "Quick Fix for GE Microwave." The guys shows how to take the panel off. You take the connectors off and put the keypad on the table and pull the ribbon tab out of the connector (don't take the connector out of the board, it doesn't some out). Then you put the ribbon tab back into the connector and it works. The ribbon tab just needed to be reseated. The whole thing took about 5 minutes. I was ready to listen to all these other people and go out and buy a new keypad. . .even worse. . I was ready to pay $500 for a new microwave. No way. . it's done. My wife thinks I'm so amazing blah blah.
Posted on Nov 24, 2013
MicrowaveSvc
  • 9047 Answers
SOURCE: GE microwave error - PROBE
Chances are the keypad (membrane switch) is shorting, or the control panel as an assembly may need repair.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting. It shows you how to test the keypad.
Also, we repair these for $39.95 (in most cases) for customers nationwide via mail. If yours needs a keypad, we could also give you the estimated total repair cost if you contact us with your exact model number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 30, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE JES1344SK01 countertop microwave, no power
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall, in which case you can download GE owner's manuals and installation instructions here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams by entering your full model number here. Once you have the part numbers, though, I would suggest ordering parts here at a much lower cost.
Posted on Dec 17, 2008
  • 396 Answers
SOURCE: ge microwave HVM1540DN1BB button control pad stopped working
I am not familiar with the Whirlpool microwaves; however, I just had the same problem with an LG over the range microwave. Several of the positions on the touchpad quit responding to touch. In our case, it was the touchpad itself that was the problem.
The touchpad on our microwave was held in place with adhesive. We pulled it off and replaced it with a new touchpad. Everything works now. The only complication is getting to the connector which carries the signals from the touchpad to the microwave controls. We had to remove and dissassemble the door to get to that connector.
The touchpad cost about $26.00.
Posted on Oct 09, 2009
SOURCE: I own a GE over the range microwave, model
This model from GE is a ****..they replaced the keypad once wihtin first 2 months..now just after warranty..same issue again. Never buy GE products. The replacement key bad is $44+shipping in many onlne parts store..I am giving it one more try..next time this happens..GE will be out my door!!
Posted on Mar 24, 2010
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave ge spacesaver touchpad does not work except for the
You have a failed membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
But please note that for some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
Either way, we can let you know what your options and costs would be and send you other helpful info.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 04, 2010
Testimonial: "Thank you for your detailed response. Nice to know you are there for support."
Ge profile microwave oven touchpad not working
The touch pad is more than like the problem. This is common. Try removing the ribbon connector and reinserting it back in the receptacle. If this doesn't fix the problem then replace the touch pad.
Oct 06, 2014 | GE Profile Spacemaker Over-the-Range...
HOW DO I CHANGE OUT THE TOUCHPAD FOR JNM1731DPBB
I'd suggest you contact Matt Fadorsen at eM-Ka Ventures in Chesterland, Ohio. He just repaired my GE keypad on a Model JVM2070CH02 microwave (GE doesn't make just the membrane keypad available--you have to purchase the entire control panel ($548.00 through a local parts distributor). Matt's turnaround from the time I removed the keypad to the time I re-installed it was only 8 days--and it only cost me $100, which included the return shipping. I'm sold on Matt!
Jun 29, 2013 | General Electric GE JNM1731DPBB 1.7 cu ft...
I have GE JVM1540DN1BB microwawe. It beeps all the time and says "keypad sorted" and service needed. The beep sound is annoying and it beeps every 30 seconds
see this causes and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | GE Microwave Ovens
My microwave oven touchpad does not respond
Hi!!
Try unplugging the microwave for about 5 min. to reset unit. If problem persists, a new touchpad may needed, check on the following site http://www.repairclinic.com/ for price and availability of the touchpad using the unit's make and model. Some times you'll be better off buying a new unit.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Apr 15, 2011 | GE Microwave Ovens
Hello i am worried our g e over the range microwave oven will not heat model # HVM1540DN1BB
dont worry yourself, it isnt a major expence, either the capacitor and diode need replacement or the magnatron need replacement.( Please dont do it yourself, as serious injury will occur due to the high voltages that sit in the system).
Aug 09, 2010 | GE JES1039 Microwave Oven
I own a GE over the range microwave, model #HVM1540DN1BB The touch panel doesn't work at all. I can't even set the clock. I even umplugged it for a couple of DAYS, and still nothing. I called GE, and they...
Dec 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave touchpad does not respond but clock is showing
You need to unplug the microwave and leave it like that for a day or a few hours it probaly just needs to be reset !
Nov 11, 2009 | GE Microwave Ovens
Ge microwave HVM1540DN1BB button control pad stopped working
Oct 09, 2009 | Whirlpool MH7140XF Microwave Oven
I have an over the range microwave oven Spacemaker XL1800 that came with new house that I bought in July 2007. The control panel has a clear cellophane covering that is bubbling. Should this be removed...
Maybe I misunderstood what this site is all about. I thought you were from GE. This microwave is still under warranty and I want it fixed by GE. Please let me know what this site is. Thank you.
May 10, 2008 | GE Microwave Ovens
Whirlpool MH7140XF Microwave Oven Logo
1,061 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
