Question about Panasonic SC-AK220 CD Shelf System
Hifi shelf system cd carolsel keeps ejecting and won't rotate
Is it worth fixing? Problem with 5 cd disk player. Keeps ejecting and won't close on its own. Won't rotate to other cd tray. Also radio won't play...
  • Mirage Dec 29, 2012
    Hi Nickjules - did you get the problem with the ejecting CD carosel solved? I have the same problem. dalrinz.oz2@gmail.com
  • 130 Answers
SOURCE: CD player
All this cd systems have the same problem. If you're using burned cd's sometimes they don't work so you need to close the session after burning in your burning program. If you're using original cd's it means that the device needs to be cleaned up (especially the lens) because the structure of a 5 cd combo device gets very dusty after a while. Also from my experience after cleaning it put a cd in each deck (even if it's off) so they could prevent it getting dustier again. Hope it helps, good luck!!
Posted on Feb 12, 2006
techman
  • 3130 Answers
SOURCE: 5 cd changer locked on cd and stays ejected
Nope no loose springs.. Its a problem that happens alot of times when you dont follow the manufacturers instructions. What happens is when you pushed on the tray assembly, you pushed the nylon cam gear out of mechanical timing. Unless you get the mecanical manual for this player, you most likly will not be able to adjust this yourself. probably a shop would charge you more then it is worth. Sorry. Good Luck.
Posted on Aug 13, 2006
techman
  • 3130 Answers
. Nope no loose springs.. Its a problem that happens alot of times when you dont follow the manufacturers instructions. What happens is when you pushed on the tray assembly, you pushed the nylon cam gear out of mechanical timing. Unless you get the mecanical manual for this player, you most likly will not be able to adjust this yourself. probably a shop would charge you more then it is worth. Sorry. Good Luck.
  • 275 Answers
SOURCE: CD player problem
Seems like the Timingfor the Tray Open / close has got disturebed. Could be a bad drive gear, or as simple as a loose Drive belt. Get it checked by a professional.
Posted on Sep 20, 2006
SOURCE: cd won't play
Easy fix, look at the front of your CD player, you should see a little pin hole, insert a paper clip into it and the pop the CD tray open.
Posted on Nov 28, 2006
How do I fix my Sony cd player with 5 disc carousel changer in which the door keeps opening up? When I close the door the carousel moves around a bit but then the door opens up again.
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
I have a Sony mini hifi stereo(pixy) and when ever I close the tray it continues to ... my cd player drawer opens ...
ToddFun.com: Repairing a 5 disk CD player - YouTube
? 10:09
https://www.youtube.com/watch?v=aKE1CbHOBVo
Nov 23, 2011 - Uploaded by Todd Harrison
ToddFun.com: Repairing a 5 disk CD player ... Sony CDP-CX300 300 Disc Changer Belt Repair and ...
Jan 01, 2016 | Sony Audio Players & Recorders
How do I keep the CD player from ejecting by itself?
This will be a fault in the ejection circuit. It will need a trained technician to investigate it.
Feb 16, 2015 | Aiwa Audio Players & Recorders
Aiwa NSX-A888 Stereo System CD Player
Cleaner disks are a waste. You're better off cleaning the lens with a cotton swab and rubbing alcohol
Apr 14, 2013 | Aiwa NSX-A888 CD Shelf System
Cd keeps coming back out
Hello
The loading mechanism should be replaced. It has gear wheel trouble. It will be best to replace the loader mechansim, as it won't cost more. OK.
Dec 22, 2011 | Philco (R) 841.205 CD Shelf System
My RCA Stereo system 5 disc cd drawer keeps opening. When I put a cd in it, the unit opens and keeps opening. It only stays closed when I turn off the unit and manually push it closed. What could be...
These units are actually nice units. There is a "loading belt" inside that controls the tray movement as well as the final "load" of the mechism into the play position. If the load does not complete, the unit will "eject" or open up. This is most often cured by replacing the loading belt. This is a common problem with any rubber component. As it ages, it gets a little slippery and thus will not have the grip to complete the loading sequence. The belt for this will run about $5.
Dan
Aug 26, 2010 | RCA 100-Watt Stereo System With 5-CD...
Cd player stop playing... Message....no disc,...no data or it simply keeps searching for the tracks on the cd. How can this be fixed?
Try cleaning the lens with a CD lens disk cleaner, see if that rectifies the problem. Hifi systems are notorious for dust buildup being an enclosed system with an exposed cd drive deck.
May 24, 2010 | Panasonic SC-AK100 CD Shelf System
How do I get my cd to eject? What can I do? I don't have any money.
On these systems with the CD player being on the top, you can get the disk out by either removing the top cover via 6 screws , ( 2 on either side and 2 on the back ) or the screws on the side and back of the hifi that hold the case on, they will need to be removed. Then pull the cover up and slide out. Then if it should be easy to pull the disk out.
May 21, 2010 | Aiwa NSX-AJ20 CD Shelf System
Cd keeps ejecting when i put one in
hi, the lens is bad or weak, cleaning will not help sometimes with a disk cleaner, try cleaning it with a earbud gently,, if still...same then you will need to get it repaired.. let me know
Dec 16, 2007 | Sony CMT-HP7 CD Shelf System
TECHNICS SC-EH750-CD KEEPS SKIPPING
replace travers assy ,because spindle motor is faulty. If you can get spindle only it will be chiper solution for you.
Nov 10, 2007 | Technics SC-EH780 CD Shelf System
Panasonic SC-AK220 CD Shelf System Logo
66 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
