Question about Whirlpool Duet GHW9150P Front Load Washer
No power It's not an outlet problem. The power to the washer doesn't work anymore. Is there a reset button on washer. No lights come on at all and we can't get our clothes out. The cord has no frays or damage.
  • 141 Answers
I hope so you are having the problem with the door lock i cannot advice you to remove the lock because it is not easy to explain through message it is better to contact your nearer expert and get the help
Posted on May 03, 2010
My washer wont fill up orturn on
First test the outlet your washer is plugged in to..it is likely a ground fault interrupter outlet that may just need to be reset. You can try plugging a known working item such as a small lamp or power tool into the outlet your washer uses to make sure it is working. If the outlet is dead and does not have a reset button, Check your circuit breakers.
Sep 26, 2014 | GE WBSR3140DW Top Load Washer
My wii went off after a thunderstorm and doesn't get on anymore, can I do something to fix it? I've already changed the battery inside but nothing cheanged.
First make sure the circuit is live - Are there other things on that circuit? Do they work? If not, check that the breaker hasn't tripped, and reset it if necessary. Next, check that that specific outlet wasn't damaged. Plug something else into it. Does it work? If not, the outlet needs to be replaced. Also plug the Wii into another outlet. If it works, this also confirms the original outlet has been damaged. If the Wii still doesn't power on, the power supply has probably been damaged. Unless you can replace it yourself, it probably isn't worth having it repaired.
Apr 21, 2012 | Nintendo Wii Console
I have a Epson stylus DX4450, and the scanner doesn't read anymore. Is it possible to reset it?
Try disconnecting the power supply from the electrical outlet and the usb connection to the computer for 10 full minutes and then reconnect both. This usually works.
Feb 08, 2012 | Epson Stylus DX4450 All-In-One InkJet...
Power does not turn on when i push the power button
first make sure there is power to the outlet if it is agfi outlet push the reset button if it clicks its working but inany case plug something in to the same prongs that you know works(eg; lamp,radio,etc to make sure it is working. If it doesn't work go to the circuit breaker and look for a breaker that is not in the on position and turn it off the turn it on to reset it. If the outlet works,check the power cord for cuts fraying or any signs of damage and replace it if it is damaged. if the cord looks fine, check tho door switch(usually a pressure switch that must be fully depressed for the machine to start working. also is ther a power light on the unit? is it a top load or front load? what brand and model # is it?
Jan 09, 2012 | GE WCVH6260FWW
There is no power on the machine outlet works breaker works
Very likely there is a GFCI type outlet somewhere in the kitchen/bathroom or even garage if you have garage that has a reset button on the outlet find that outlet and push the reset button.
Gene..OldTech2332
Aug 18, 2011 | GE Spacemaker WSLP1100D Top Load Washer
After power outtage my f/p washer is dead -no lights nothing
Only reset is to unplug it. Are you sure you have power at the outlet? If you have 120V at the outlet the power surge may have blown the controller, not a cheap fix :(
Apr 12, 2009 | Fisher and Paykel Fisher & Paykel Washer
NO POWER
do any of the lights come on when you press the power button? if nothing comes on, then check the GFI outlet and see if it has tripped. quick check would be to unplug the washer from the wall and plug in a lamp. if the lamp doesn't work either, then the outlet doesn't have power.
either the GFI needs to be reset or the circuit breaker at the main panel needs to be reset. one GFI will control a couple of outlets that could be exposed to water (eg, bathrooms, laundry rooms, outdoors, etc). you'll need to find the one and hit the RESET button on the outlet.
if the GFI outlet is reset and still no power to the lamp, then find the circuit breaker panel (usually in a garage, basement or outdoors). open the door and see if one of the breakers has tripped. reset it (or replace if its an old style glass fuse) and see if power is now restored to the outlet cause the lamp now lights up.
if power is there to the outlet, but the washer still will not come on (and either work or display error codes), then one more thing to check is the connection at the machine/motor control unit (connector P13 at the unit). disconnect the washer from the wall outlet. to access P13, you'll have to remove the top console panel (its the one that has all on the buttons on it). its held on with 3 screws on the back that you can get to from the top (no need to move the washer out from the wall). loosen the screws, tip the the panel forward and lift it up. it will be connected to the computer board, so just move it out of the way. P13 will have the large black wires going to it. give it a push to see if its not locked in place. if you hear a "click", then it was not properly connected. you can remove it and reinstall it if you want, but make sure the machine is not plugged into the wall outlet.
put the console back together, plug the washer in and see if it works. if it still doesn't power up, then sounds like the computer board is dead and you'll need a new one. its about $150 from searspartsonline. replacing it is easy, but sears may pay $150 towards labor and $100 towards parts. give them a call.
good luck.
Jan 31, 2009 | Kenmore Oasis HE 27082 Top Load Washer
KENMORE Elite HE 3T
no but there is a control bd it is probably gone
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Reset Button
your testing the no fault short or motor overload feature. the red light indicates you have power. no light no power.
Apr 02, 2008 | Karcher 2500 PSI Pressure Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
44 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
