Question about Motorola Mobility H700 Wireless Headset
Purple light on H700 will not stay lit
I just recently purchased the Motorola H700 bluetooth and I'm having a hard time keeping the bluetooth in pairing mode. I do the pairing as said, with pressing the call button till it turns purple, and then I quickly pull up the boom mic, but the light quickly disappear. I'm wondering if this is a defective device or is I'm doing something wrong. Please help because I brought this off ebay and I doubt it if I can return it. Thanks.
  • Sarahdise Apr 21, 2008
    i've tried everything... and I can't fix it.
  • Anonymous May 16, 2008
    while the boom was closed I held a few seconds until the purple light can on and then i opened the boom and the light went off. I did this several time without any success. What else can I do?
    New Friend:
  • 3 Answers
Same here idk what's going on with this type of device
Posted on Jul 23, 2012
I was having trouble with the same thing. The light would flash purple when closed, I opened and it stayed lit only for a second. Give it another second, I found it flashed off then came back on steady for pairing mode.
Posted on May 27, 2008
6ya staff
SOURCE:
How to pair motorola H700 wireless Headset with my treo 650
Open the headset boom: it will flash steadily purple, it it's not paired ever. If it was paired turn that devices off; open the headset boom, blue will steadily lit; after 5 seconds, it will steadily purple lit. Now find Motorola H700 on bluetooth and type password: 0000. Done!
Dec 18, 2010 | Motorola Mobility H700 Wireless Headset
Bluetooth serial # 6809501a26-0 need
1.Switch on the bluetooth on your phone.
2.Open the headset boom to initiate easy pairing. After a few moments, the indicator light will be steadily lit in purple to indicate headset is in pairing mode..Motorola H700 will be detected.
3.Go to handsfree and select 'look for devices'. 4.Select Motorola H700.Select Yes to bond. Enter the passkey 0000 and select OK.
Thank You
Sep 01, 2010 | Motorola Mobility H700 Wireless Headset
The pairing light won't stay
Open the boom of the reciever right after the light turns purple... if you do it fast enough it will stay lit.
Jun 17, 2009 | Motorola Mobility H700 Wireless Headset
The purple light would not stay lit
Hold the call button till the purple light comes on, then release the button and immediately open the boom. It will stay on then.
Mar 08, 2009 | Motorola Mobility H700 Wireless Headset
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Purple light will not stay lit
I signed up JUST because this solution worked:
"Hmm this may sound like a stupid solution that doesnt work but what i did is...,
#1 I Held the button to make the violet light go on
#2 when the violet light is on dont just flip the boom mic, flip* the earpiece with it.
*note: when fliping the mic and earpiece, dont open slowly, flip it open fast and keep it there." I do want to note that my passcode was reset to nothing during my 3 months of troubleshooting.
Not going to mess with it.
Mar 26, 2008 | Motorola Mobility H700 Wireless Headset
Purple light wont stay lit for pairing
Make sure the microphone is closed and the BlueTooth is off. Hold the button in until it turns purple. As soon as it does release the button and flip out the microphone. The purple light should stay lit all the time now. That is until the pairing process is done with the phone.
Mar 18, 2008 | Motorola Mobility H700 Wireless Headset
How to do pairing
Thank you. I called a 1-800 number for tech support but they told me I had to wait 14 days from the date of purchase before they could help me. Your suggestion was right on the money. Thank you.
Jul 18, 2007 | Motorola Mobility H700 Wireless Headset
Motorola H700
First, you will need to put the H700 into pairing mode. Look at the last digit in the part number for your headset (there are 3 versions). If it "A" or "B", do the following... 1. Starting with the headset powered off (flip closed), hold down the Call button for 1 to 5 seconds until the light is steadily lit in purple. 2. With the light steadily lit, flip out the boom. The light should remain steadily lit in purple. If the light is flashing, or if the light starts flashing anytime before completing the steps below, the headset is not in pairing mode, and these steps will need to be repeated. If you part number ends in a "C", do the following... If the headset has never been paired with another device, simply open the headset boom. The indicator light becomes steadily lit in purple. If the headset has previously been paired with other devices, first ensure those devices are turned off. Then open the headset boom and the indicator light flashes in blue. After about 5 seconds, the indicator light becomes steadily lit in purple. And finally, you will have to follow these instructions on you A900... 1. While in standby mode, press the Menu/OK button 2. Select Tools (9) 3. Select Bluetooth® (4) 4. Highlight Yes, using the navigation keys, on the Enable Bluetooth® prompt 5. Press the Menu OK button to enable Bluetooth® 6. Select Bluetooth® (4) 7. Press the left soft key for Add New 8. Highlight Search, using the navigation keys 9. Press the Menu/OK button to begin search for new device 10. Highlight the desired Bluetooth device, using the navigation keys 11. Press the left soft key for Add to List 12. Enter Passkey "0000" press the Menu/OK button, you will get a brief message stating pairing 13. Press the left soft key for Done 14. At the Trusted Devices screen, press the left soft key for Connect 15. You will get a brief message stating connecting 16. After being connected you will return to the Bluetooth® Trusted Devices screen Hope this helps. Good luck
Jun 24, 2007 | Motorola Mobility H700 Wireless Headset
Motorola H700 Problems with BB Pearl 8100
Steps to pair a H700 headset with any bleutooth pone:
  1. Make sure the H700 fully chared (very important)!!
  2. Make sure the microphone boom is folded closed, i.e. power is off!
  3. Hold the call button for 1-5 seconds until the light is steady lit purple
  4. Flip out the microphone boom, the light should stay lit purple!
Now you are ready to pair the headset with your phone, so follow the pairing instructions of your phone.
Note: When prompted for the Passkey; it is most likely 0000 but the correct Passkey should be on the headset accessory instructions.
I must add that indeed my headset on occation (once or twice every three months) also loses its connection with the blackberry (a 8703e) . At which time I have to remove the headset from my phone bluetooth device list, and start the above described steps to pair my headset with the phone again.
Jun 02, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
215 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
