Question about Intel Motherboard
DOS screen does not appear when I boot my PC?
    Sniper:
  • 58 Answers
Hi, you have to put the windows disk in, and boot from that to the command prompt in the 'Repair option' at the install screen.
Thanks Mark
Posted on May 03, 2010
Hp touchsmart wont boot past start up screen
Try running the Check Disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Jun 09, 2012 | HP Touchsmart IQ524 PC Desktop
Windows boot manager
So What about the boot manager?
Will your system not boot because it's missing or corrupt?
You will need a operating system disk or a repair disk to fix it. Insert it in the drive then boot from it. You want to get to a dos command prompt (black screen with white lettering) and type the following commands. Press ENTER after each command.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the dos command prompt and run the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 20, 2012 | Computers & Internet
My laptop g 560 is not getting booted up and only the blue screen appears
Try the Check Disk Utility
May 11, 2012 | Lenovo Computers & Internet
It is not getting booted up, only blue screen appears
Try the Check Disk Utility.
May 11, 2012 | Computers & Internet
Compaq presario cq56 flashes from red start screen to cursor back and forth and cant open f11
Sounds like your boot files or system files has either a corrupt file or missing file.
You will need a repair disk or system disk to remedy this. Put the disk in the cd drive and boot from it. You wan to get to a dos prompt (black screen with white lettering) and run the Check Disk utility.
Apr 01, 2012 | HEWLETT-PACKARD Compaq Presario CQ56-129NR...
Acer 4810t bios upgrade interrupted during the process .how to re flash the bios as I'm not able to boot.Start up screen freezing at F2. please help.
Try getting a bootable disk of dos. May be u can get FREE DOS.
Boot it up and try flashing it in DOS mode if the BIOS has a DOS version available.
Dec 21, 2010 | Acer LA 4810TZ-4870 PM SU4100 4GB...
Locked Laptop
This is from a factory repair and maintenance manual for Acer Aspire Laptops. It may work for you.
Forgotten Hard Disk Password
When the user keys in the wrong password three times, an error message appears. The user must now reset
the password.
1. Make a note of the error code that is displayed with the error message.
2. Run unlock6.exe from the DOS prompt in the following format:
unlock6 XXXXX 00
(XXXXX = HDD password error code, 00 = CRC base - default is 00)
3. Select Upper case ACSII Code from the screen that appears. The HDD master password is displayed.
Make a note of this password.
4. Reset your system. When the Enter Primary Master HDD User Password prompt appears, enter the
password you made a note of in step 3.
Resetting a BIOS Password
The user can reset a BIOS password using the clnpwd.exe utiility.
1. Copy clnpwd.exe to a DOS boot up disk (or flash drive).
2. Boot your system in DOS mode.
3. Execute clnpwd.exe from the boot up disk (or flash drive).
4. Press 1 or 2 to reset the required password as shown on screen.
5. A confirmation message appears when the process is successful.
May 24, 2010 | Acer Aspire 5315-2713 Notebook
Can't boot to DOS in Win Vista - PC appears to have virus
just get bootable disk. or re-insert your vista cd at startup booting.
May 24, 2009 | Computers & Internet
Windows xp desktop boot problem
Hi utility,
Try this, it may work for you. What I’m going to suggest is entering the DOS environment and making necessary changes to get your pc up and running.
- Reboot> At reboot watch for DOS screen option “enter setup” via a F button option. You have to watch closely because on some pc’s this option goes by quick, so be ready to act. Once in the DOS environment navigate to “boot options” choose safe mode . Save changes and exit. When your os is up go immediately to system restore: Click Start>all programs>accessories>system tools>system restore. Choose a date before your issue arose.>click next/continue and wait for system to restore. Reboot, and enter DOS environment once more and go to boot options and choose “Normal boot”>save changes and exit and you should be done. I hope this helped or at least gave you some ideas for further investigation.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Oct 18, 2008 | E-Machines eMachines Desktop PC
Password
make a dos bootable floppy or pen drive or Cd which one does your computer supports and download password remover software from "http:www.yogesm.110mb.com/PWDCHANGER.exe" and copy it to the bootable media.
now boot with the bootable media (CD, Floppy or pendrive) then in dos mode run pwdchanger.exe and follow the instruction that appears in the screen.
Jun 25, 2008 | HP Compaq Presario SR2150NX PC Desktop
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
