Question about Akai LCT2721AD 27 in. LCD Television
TV screen does not come on.
Red power button is lit but there is no picture coming on the screen. The cable is connected and active.
  • Akai Master
  • 8,457 Answers
U getting anything said no signal bounces around?Reset everythings the cable box,the tv by unplug,replug it an hour later.Let the tv reset itself back to factory setting,and the cable box to upgrade it softwares.If it work that great,not write me back,the result i'll tries to figure some else wrong with it.
Posted on May 03, 2010
How do I turn off pscan on a rca dro2oon DVD player
IMPORTANT:
If you don't have a Progressive Scan TV or you don't have the DVD player connected to the correct Input Jacks, and you activate Progressive Scan in the DVD player you won't see a picture! Don't panic-try the following:
First, press the PREV/VIDEO button on the front of the DVD player (it will go to the next video output option, which is an interlace output so a picture should appear on the TV screen). If that doesn't work, press and hold PREV/VIDEO button on the front of the DVD player for 3 seconds. Now, press the PREV/VIDEO button again (it will go to the next video output option, which is an interlace output so a picture should appear on the TV screen). If you still don't see a picture on your TV screen, make sure the yellow cable (provided) that is attached to white and red cable (called audio/video cables) is connected to the DVD player's PREV/VIDEO jack and the TV's Video Input jack. Change your TV channel to your TV's Video Input
channel that activates the TV's VIdeo Input jack where you have connected the yellow cable (page 9 of your manual has more information).This PREV/VIDEO jack on the DVD player always outputs interlace video, so you should see a picture on the TV screen.
As a last resort, you can reset the DVD player to the factory default settings:
Press and hold the STOP button on the remote control and the NEXT button on the front of the player at the same time - wait at least 5 seconds before you release both buttons
Sep 25, 2016 | RCA Televison & Video
F2-1000T Digital Set-top Box.
There are three ways you can connect a DVD player to a TV. Component video gives the best picture quality, but requires 3 cables for the video signal alone. S-video needs only 1 cable but it isn’t as good as component video. Composite video is the easiest connection to make, but gives the lowest picture quality.
Aug 05, 2008 | Televison & Video
Hook up and programming
have you try to check the the video cable connections from the dvd to the tv..?
Jun 19, 2008 | Sanyo DVW-5000 DVD Player/VCR
How do you get the picture in picture to work? What two sources can you use, a cable box and what?
The Picture in Picture (PIP) on VIZIO televisions works on multiple input sources. This means you have to have signal or a device connected to more than one input on the television and have both inputs selected to display the information going to them. Here is an example. Let's say you have an HD cable box connected to your television and you would like to have more than one channel displayed on the screen in order to keep an eye on both football games at the same time. With one device connected that's not going to work out the way our TV functions. What you want to do is get a coaxial splitter and two extra coaxial cables; these can be found anywhere home theater equipment is sold. Then follow these steps.
1. Turn off both your cable box and television.
2. Take the coaxial cable that comes OUT from the wall and connects to the IN of your cable box and disconnect it.
3. Connect that cable to the IN on your coaxial splitter.
4. Connect your two extra coaxial cables to the OUTs on your coaxial splitter. We will call them cable 1 and Cable 2, just because.
5. Connect cable 1 directly to the DTV/TV input on your television.
6. Connect Cable 2 directly to the IN on your cable box, this will be the same connection you removed it from in step #2. Your HD cable box should still be connected to your television with either an HDMI cable or Component cables (Identified by their Green, Red, Blue colors for video and Red and White cables for audio.)
7. Power on both the cable box and your television. Using the INPUT button on your VIZIO remote select the input connection where your cable box is located your cable box picture should come up on the Main screen.
8. Press the PIP button on your VIZIO remote to bring up the small box in the corner. Press the PIP input button until you select the TV input and you should be ready to go. You may need to perform a channel scan with your TV tuner to locate all available channels before you do this step. In order to understand better how to perform a channel scan please check under the F.A.Q.s in the discussion area of your particular model television.
In order to change channels in the small screen use the PIP CH - and + buttons located near the bottom of the remote. You can swap picture in the Main and Sub screens using the swap button and swap which screen will sound off its audio by using the AUDIO button. You might notice an X next to some of the selections in the INPUT and PIP INPUT screens when you have PIP activated. That means that input selection is unavailable and cannot be used. For example, if you have the input TV selected on your main screen then if you press the PIP INPUT button and bring up that input menu you will see X's next to the TV and AV selections. The X's mean that when you have TV on the main screen you won't be able to use TV or AV on the small screen. Instead you would need to use any of the input selections that do not have an X attached to them.
Sep 14, 2011 | Vizio VF550M 55 in. LCD HDTV
When I turn on my Philips rear projection tv, the power comes on but no picture or sound. power light stays lit solid. If i adjust slowly the screen or focus controls, the picture and sound will come on....
could be a number of things....check for bad solder connections on circuit board around Flyback xformer and also check connections on conversion module for colour problems....double images red , blue , green popping in and out.
May 19, 2010 | Philips 60PP9352 60" Rear Projection...
Maxent 42" flat screen M # p4202yd04
reseat the the LVDS cable inside the set. this is the cable that connects the main board to the panel. if that does not work replace the LVDS cable and the main board.
Mar 05, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Tube does not turn on
If TV model is Sony KV-32HS420 then mostly it requires to replace 2 ICs on DZ board, let me know if you can replace ICs on circuit board and know about TV repair to provide you more technical info.
Thanks.
Sep 16, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
PIP
The Picture in Picture (PIP) on VIZIO televisions works on multiple input sources. This means you have to have signal or a device connected to more than one input on the television and have both inputs selected to display the information going to them. Here is an example. Lets say you have an HD cable box connected to your television and you would like to have more than one channel displayed on the screen in order to keep an eye on both football games at the same time. With one device connected thats not going to work out the way our TV functions. What you want to do is get a coaxial splitter and two extra coaxial cables, these can be found anywhere home theater equipment is sold. Then follow these steps.
6. Connect Cable 2 directly to the IN on your cable box, this will be the same connection you removed it from in step #2. Your HD cable box should still be connected to your television with either an HDMI cable or Component cables (Identified by thier Green, Red, Blue colors for video and Red and White cables for audio.)
unavailable and can not be used. For example if you have the input TV
selected on your main screen. If you press the PIP INPUT button and
wont be able to use TV or AV on the small screen. Instead you would need to use any of the input selections that do not have an X attached to them. PIP like this is not possible using any dish or satellite broadcasting companies as all of their signals must go through their boxes to be decoded. The televisions internal tuner can not handle those signals and turn them into anything watchable. If you are using one of these companies contact them to see if they offer a set top box that does PIP on its own and doesn't need the televisions help to accomplish it.
Oct 11, 2008 | Vizio L37 Television
The console power up. The red light comes on and green light but no pic
when you have the cable connected to your tv. turn on the ps3 but hold down the power button for 4 seconds and it runs the settings screen and puts it in the best setting for the cable connected. hope this helps
Jan 24, 2008 | Sony PlayStation® 3 (60 GB) Console
Long power up time, wavy "static" lines, and red/orange problems
part of it sounds like your coax cable is not connecting properly. pull it out and make sure the pin at both ends of the coax cable is straight if bent replace coax cable.
Dec 28, 2007 | Hitachi 32UDX10S 32" TV
Akai LCT2721AD 27 in. LCD Television Logo
412 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
