Question about Zanussi ZWF1430W Front Load Washer
We have code e50 on the front off it how do you get it off
  • 269 Answers
E50 is relating to the main motor,it could be the brushes,tacho or something more serious.That error code will not clear until you can find the problem causing it,try checking the brushes first.If you want to try to clear it first follow these instructions and you may get the exact error code displayed if so then get in touch again with the new error code.
Hold the start/pause and skip/reset together then press the on/off button keeping the other 2 buttons held until you get chasing lights,now release the first 2 buttons.Now press the fabrics button until the light goes down t60 degrees or the pump cuts in.Then take it on I think step by step until an error code displays make a note, to cancel hold the 2 buttons start/pause and skip/reset and the error code should go but if it reappears then the fault is still there.Good luck
Posted on May 03, 2010
Electrolux front loader E50 error
Hello Friend, thank you for your post!
I see you are receiving an error code E50 on your Electrolux dishwasher. Is it possible that the code is missing characters? Could it possibly be an E50? May I please have your model number? The serial tag, which lists your model number, is typically located on the right side as you open the door. With this information I can further address the issue at hand. In the meantime, I suggest resetting your dishwasher. You can do this by flipping the household circuit breaker off for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your dishwasher continues to display E50. Thank you - Z.
Apr 12, 2014 | Zanussi ZWF1640 Front Load Washer
Front loader washing machine EWF1087 stopped half way and did not drain, E50 was displayed. Emergency emptying out the water was done and try to restart. Could not start, still displaying E50. What to do?
the error code E50 indicates that the motor has become overheated, you should give it an hour to cool then try running the washing machine again. I'm also including a link to pdf below with the common error codes for your brand of washer in case you have any other problems
http://www.applianceblog.com/mainforums/attachments/frigidaire-electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwashers.pdf
Jun 17, 2011 | Electrolux Washing Machines
Electrolux EWF1090 front laod washer not starting cycle? Error E50 is dusplayed on panel, however product manual has no reference to error E50? - NEED HELP
e50 is a motor error code,, this could be the motor itself of the wiring harness or the main computer board
Jan 26, 2011 | Washing Machines
Error code E50, what does this mean? We select programme, all the lights are on, we press start and E50 appears. What does this mean?
e50 is a motor error code.check the motor brushes are ok and check the insulation on the motor as this will give you an e50 error code.could also be a faulty wiring loom to the motor or a faulty main control pcb
E50 says the motor is overheated, they recomen you let it sit for 30min to clear.
It can be the motor power supply triac has got a short circuit or there could be no signal from the motor tachometric generator, which will uaually mean a pcb fault, or wiring to motor or even the motor. hope this helps
Dec 13, 2010 | Electrolux EW1000i Front Load Washer
E50 message
Here is a link to some good information about your error code.
Zanussi Error E50
Hope this helps you!
Nov 21, 2010 | Zanussi ZWF1230W Front Load Washer
ERROR CODE E50 SHOWING AFTER POWER SUPPLY INTERUPTION
It was probably your washer that tripped the electric . e50 relates to the motor check the carbon brushes they will be worn out. hopefully with new brushes you will be back in action. the programme wont start with a fault on the motor
Jul 24, 2010 | Zanussi ZWF1430W Front Load Washer
Can you tell me what code E50 is please?
Yes E50 indicates that there is a fault on the main motor.This hopefully is worn carbon brushes which can be replaced at reasonable cost.If the main motor is faulty and this machine is out of the 5year parts warranty (2004 from mod. no.)It would be costly so check the brushes first.
Hope this helps.
Good Luck.
Apr 22, 2010 | Zanussi ZWF1430W Front Load Washer
E50 code
hiya
i'm sure that e50/e51 is the insulation in the motor breaking down, in which case its usually new motor time i'm afraid.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Jul 20, 2008 | Zanussi ZWF1640 Front Load Washer
Electrolux ewf 1435 washing machine
i can not find e50 in any of my servive manuals, are you sure it is e50 ?
Feb 16, 2008 | Electrolux EW1000i Front Load Washer
Zanusi zwf 1631 w wont work
all of the e50 codes indicate motor check your brushes. if you still have problems email me
Feb 10, 2008 | Zanussi ZWF1630 Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
296 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
