Question about White Sewing 2999 Mechanical Sewing Machine
Skip stitch problem in a flat lock machine
In bottom hem operation for polo neck tee shirt
    New Friend:
  • 184 Answers
If it seems to sew other fabrics correctly, then you need a different needle for that fabric. It is called a "Stretch Needle" Get a package of Schmetz size 75/11 705HS and that should take care of it.
Posted on May 07, 2010
I have a designer SE it wont stitch tee/shirt material it misses stitches
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Feb 01, 2013 | Sewing Machines
I need to hem a t-shirt but not sure how...ie: type of stitch,length,needle et...do I need to zig zag first then finish off with a stretch stitch ? Thanks
The best way to hem around a garment where the seam is going to receive stretching during wearing is with a stretch twin (double) needle.
Pretty easy, just turn up an even hem of 15mm right around the hem line (I am assuming that the bottom edge is even, if not, trim it up first), and press this hem allowance up, pin if you have a jersey that won't stay flat but many cotton knits are fine and the pressing will be enough.
Then thread up your sewing machine for twin needle sewing, refer to your manual if you have never done this before. You will thread two spools of same colour thread up on top of the machine and bring both threads through all threading points down to your needle, then one through each needle eye. Some machines will have a tension device where you can run each thread on either side of a tension disc, most will have twin spools on top of the machine to hold both spools.
You need a stretch twin needle, Schmetz do these in two sizes,
Stretch Twin
Size:
2.5/75, 4.0/75
Twin needles look like this.
tally_girl_65.jpg I prefer the 2.5mm gap between the needles. Dont try with a regular twin, it must be stretch needle with ball point points. On some computerised machines, you need a twin needle with a blue bridge, on mechanical machines it will have a red bridge (something to do with horizonal hooks I think). But read your manual or look in your accessory box, your machine may have come with a twin needle and if so, make a note of the needle bridgecolour, then buy that one next time.
Now, set the machine for a straight stitch and place the garment right side up, with the folded hem allowance underneath on the sewing machine and align the folded edge on your 10mm marking. Start at a side seam, and stitch SLOWLY around the whole hem line until you get back to the starting point. Stop, cut your threads and press again. Voila done. I never bother to zigzag a knit fabric, just stitch it. Knits don't fray.
Aug 20, 2011 | Sewing Machines
What are the types of sewing machine for t-shirt making?
almost any machine can be used to sew tee shirts. all you really need is a stretch stitch and overlock stitch which event the most basic machine has these days. try using an old shirt that you no longer wear and try different stitches, stitch lengths until you are satisfied with the results,
Oct 29, 2010 | Brother LS-2125 Mechanical Sewing Machine
I've just got janome 634d serger, how can i make the bottom of a T-shirt ? Thank you so much
If you want the bottom of the T to look like RTW with the double row of stitching, you cannot do this on a serger.
You can achieve the effect by using a twin needle, two spools of thread, bobbin and a straight stitch.
Make sure the double/twin needle will pass through the presser foot and opening in the needle plate below the presser foot.
Practice on a double layer of a scrap of the T shirt material as the tension may need to be slightly looser than the normal setting.
Apr 05, 2010 | Janome MyLock 634D Mechanical Sewing...
Hemming stretch fabrics
You can use a twin needle if you want the look of top stitching (like t-shirt).
For the blind hem, you need to baste the hem and then the fold so they do not shift as the machine stitches the hem.
I like to test each of these techniques by making a sample with the same fabric and adjusting length when using the twin needle or width and length when doing the blind hem.
Twin needle does limit the stitching to a straight stitch or a very, very narrow zig-zag - this has to be hand walked to be sure neither swing hits the presser foot or needle plate before stitching.
Feb 22, 2010 | Sewing Machines
Using twin needle with Janome dc3050
you can just use the straight stitch.If you want to use a fancy stitch you have to be careful that the throw, as I call it is not too wide as you could break the needles and put the timing out. Also use a longer stitch than normal.Also use the stretch twin needle.
Jan 30, 2010 | Janome Sewing Machines
Skipping stitches on coverstitch machine
To avoid skipped stitches on a coverstitch machine you need to use ELs (extra long) or SUK (stretch) needles and good quality thread. Poor quality thread is too fluffy and varies in thickness which can cause stitch problems. Try Maxilock thread from a cone or use maxilock on looper and regular sewing machine thread through needles and see if this improves the stitches. Also loosen off the lower looper tension to zero and see if this helps. If you are hemming around a garment and sewing across an overlocked seam then you need to minimise bulk too. lightly press the seams into the diretion you want them to sit when garment is finished, press the hem up, then force the seam allowance in the hem turnup area to the opposite direction. This spreads the seam bulk in both directions.
There is a knack to coverstitch machines but a good cover finish is quicker than twin needle on SM.
Apr 04, 2009 | Janome 900CP
How do I do a stretch stitch?
The bes way to hem a t-shirt on a household machine is to use a double needle, straight stitch. You will see two straight stitches on top and zig zag on the back. Just make sure the zig zag catched the top of the hem.
Feb 19, 2009 | Kenmore 12102
Coverstitching on White Speedylock serger
Your machine cannot do a cover stitch. Check the Brother website, they make a cover stitch only machine, it works much better than any of the serger/cover stitch combination machines, and it is a lot less money.
Nov 19, 2007 | White Sewing Speedylock 1600 Mechanical...
White Sewing 2999 Mechanical Sewing Machine Logo
127 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
