Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
My saw chain will not turn when throttle is pressed. I can barely turn the metal wheel that the rear chain loops around with a pliers. Should I attempt to take it completely apart to see for obstruction or is it frozen-up.
    President:
  • 2,220 Answers
Mornin' Bob;
Did you ensure the chain brake is disengaged? Grasp the forward most upper handle (hand guard) and move it toward the nose of the bar (forward). Did it click? If no the brake is engaged. Move it slowly aft (it may require some force at the rear extreme to latch) until it clicks. Wear gloves and try to rotate the chain. If it latched and you still cannot rotate the chain please post back (below), and we will explore further.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 03, 2010
Chain saw starts but cuts out as soon as i press trigger
This I just a wild guess but here goes.
Most chain saws have a on off switch located fairly close to the throttle. The switch kills the engine by grounding out the wire attached to it. If the insulation has been rubbed off the wire and the metal linkage for the throttle touches it it will short the wire to ground and kill the motor the same as the switch. Remove the air cleaner cover and check wires for bad spots .tape up any bare spots and relocate wiring away from throttle linkage if necessary .
Hope this helps.
Bobalix
Jan 17, 2015 | Garden
My esr 750 ex goped just had its card brush
Chain may be sticking, rear wheel may not be lined up straight. Check brake pads to see if they are worn out like metal on metal, hopes this helps you out
Sep 27, 2014 | Motorcycles
Elu tgs172 motor stopped running and makes whirring noise and will turn very slowly if the saw blade is turned
Sounds like a worn out bearing.
Instead of the shaft turning concentric with the outer bearing, it roles around in the worn bearing like the wheel of a stunt car going around a loop-de-loop --except the relative sizes are closer so it makes a lot of racket.
That Elu is a cool saw concept. They came out in the 1960's before commodity Miter saws hit the market so big. I've used one before.
I suspect the bearings can be pressed out and replaced. Take the saw to a motor repair shop and you might get them replaced for $15 a bearing. There's one bearing at each end of the motor.
Sep 25, 2014 | Saws
I have just bought a brand new Mac cs 400t and upon assembly the chain won't move freely once the chain tightening outer nut and bar nob are in place. I've started the motor but when I give it some...
With the cove off you should be able to turn the sprocket easily, if not the brake is on, grab the hand guard and pull it fully back toward the rear of the saw until the brake clicks and the drum can be turned.
Sep 18, 2013 | McCulloch Garden
Replace chain onchainsaw
As you do not say what model this is we will talk about generic replacment, start by making sure the chain brake ( if fitted ) is off, do this by pulling the hand guard fully back to the top handle, next remome the nut/nuts holding the side cover on, wind the chain adjuster screw fully back and remove the side cover, loop the chain over the nose of the bar and take away, loop the new chain over the sprocket and lay around the guide bar, making sure it is in the bar groove,the sharp edge of the cutters on the top of the bar should face away from the saw ( as you look at the saw the chain turns clockwise ) if the bar adjuster pawl is in the crankcase make sure it sits through the hole in the guide bar, if the adjuster pawl is in the side cover make sure this enters into the hole in the guide bar as you re fit the side cover, re fit the side cover nut/nuts finger tight, turn the adjuster so as the chain touchea all the way around the guide bar, with a gloved hand pull the chain around the bar, now re tention the chain if required, now lift the nose of the guide bar and fully tighten the nut/nuts, run the saw, there will be an initial stretch, so re tention as required, do not over tention the chain, it should pull around the bar by hand readily but touch the bar rails, not sag on the bottom of the bar.
Feb 11, 2012 | Garden
Change the chain instructions
General instructions are, if the machine has a chainbrake make sure this is off, loosen the side cover nut/nuts, wind the bar adjuster screw back to slacken the chain, remove the side cover, push the bar back to the sprocket, the chain should now be lose enough to lift it off the tip of the bar and un loop off the sprocket, now loop the new chain over the sprocket and around the tip of the bar, make sure the cutters on the top of the bar are facing away from the saw ( a pushing chain )now re fit the side/chainbrake cover, if the bar adjuster pawl is in the brake/side cover, make sure this aligns with the adjuster hole in the bar, re fit the bar nut/nuts finger tight, wind the adjuster screw in so as the chain sits snuggly all around the bar, with a gloved hand pull the chain around the bar manualy, it should pull smoothly, lift the tip of the bar up and fully tighten the nut/nuts, run the saw, there will be an amount of initial stretch, slacken the bar nut/nuts and re tention.
Aug 24, 2011 | Poulan Pro Chain Saw 46cc 20"
How to install the guide bar on a chain saw
Most saws are preety standard, pull the hand guard fully back to the top handle to ensure the brake is off, take away the cover nut/nuts, wind the chain adjuster fully back, now remove the side cover, loop the chain over the nose of the bar, and then loop it over the sprocket and off the saw, the bar will now lift away, to refit, place the bar back onto the bar bolts, push it fully back toward the sprocket, loop the chain over the sprocket and lay it around the bar ( the cutters on the top of the bar should be facing away from the saw ) if the adjuster is in the crankcase make sure it locates into the hole in the bar, now refit the side cover, if the adjuster pawl is in the side cover make sure it locates into the bar hole, refit the bar nut/nuts finger tight, adjust the chain so as it touches snuggly all around the bar, with a gloved hand pull the chain around the bar to make sure it is located into the sprocket correctly, re adjust if required, now fully tighten the bar nut/nuts.
Apr 16, 2011 | Ryobi 10" Chain Saw Repl Chain Model P540a
How do I refit chain
Start by removing the side cover held with one or two nuts ( make sure the chainbrake if fitted is de activated by pulling the hand guard fully back toward the rear of the saw until there is an audible click ) if the chain has de railed you need to check for damage to the drive links, file away any burs, or fit a new chain, screw the chain adjuster fully back, assemble the guide bar onto the bar bolts and push fully back toward the rear of the saw, loop the chain over the sprocket and into the guide bar rails with the cutter teeth on top of the bar facing away from the saw if the bar adjuster pawl is in the crankcase make sure it fits into the hole in the guide bar, assemble the side cover, if the adjuster pawl is in the cover make sure this lines up with the hole in the guide bar ( adjust the pawl screw if required ), assemble the bars nuts finger tight, now adjust the pawl screw so as the chain sits snuggley around the guide bar, pull the chain around the bar with a gloved hand to make sure it is sitting into the bar and sprocket correctly, lift the nose of the guide bar and tighten the bar nuts.
Jan 22, 2011 | McCulloch Garden
In the wheel gear adjuster for chain does not thighen chain when turning wheel like little gears are not matching up, what would be wrong?
The three hundred series saws have side adjust consisting of a small assembly, if the gears are worn it will require replacment, the hobby saw ( 235/236/240 ) had a plastic gear on the early models in the side cover, this has now been replaced with a metal gear, the semi pro saw has the assembly in the crankcase, this will require removing the clutch sprocket and bar plate to gain acsess to it.
Jan 22, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chain came off
remove side cover of chain, loosen bar nut, there is a screw on the front of the saw under the sawdust and oil. Turning it one way tightens the bar. The other way loosens it. Loosen it til you get the chain back on, then tighten it til there is about 1/2" slack in the bottom of the chain between it and the bar. By the By, semi tighten the nut before any major adjustments, then adjust the chain to above and tighten bar nut. You should be set to go. BE CAREFUL! Dont forget personal safety!!!
May 10, 2009 | McCulloch Garden
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
140 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
