Question about Maytag Neptune MCE8000AY Electric Dryer
Tumble dryer has no heat
Tumble part of dryer will not create any heat. Is it easy to repair or should I get a service tech.? Thanks
Serial numbers
Posted on May 03, 2010
My candy condenser dryer isn't heating up. I have cleaned it and emptied the water canister. The drum is turning ok . just will not heat and all six lights flash after around 15 min.
What To Do If Your Tumble Dryer Is Not Heating Up - YouTube
? 2:33
https://www.youtube.com/watch?v=uWtRXie82oY
Nov 17, 2011 - Uploaded by BuySpares
For all your tumble dryer spare parts and accessories, visit: http://bit.ly/1K45iyb If your tumble dryer isn't ...
How to repair tumble dryer when is not heating or drying ...
? 8:52
https://www.youtube.com/watch?v=75l_AtpGkks
Dec 6, 2009 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/repair-guides/tumble-dryers/ This usually means ... Up next. Whirlpool ...
Tumble dryer not heating - White Goods Help
Nov 28, 2015 | Candy Dryers
Tip
Tumble dryer not heating how to fix heater, thermostats, Ntc sensor.
We have all these tutorial guides that will help you with your Whirlpool 6th sense
How to clear error codes
How to service a pump unit on condenser tumble dryer.
How to replace belt, motor or bearings.
Tumble Dryer Not Turning, How To Replace Capacitor
We have all repairs guides on these Whirlpool 6th sense Tumble Dryers
http://www.how-to-repair.com/help/tag/6th-sense/
on Jan 21, 2015 | Whirlpool Dryers
The dryer heats on and off. Sounds to be laboring to turn the drum. Service tech came out and did not know how to fix or approach the problem with why the dryer heats and dries a load and then may not on...
drum roller,drum glides, or idler assemblage which is located next to motor(might be motor going out). Here is a website that will help:
for glides/roller: http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
for idler/motor: http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Nov 29, 2010 | GE Profile Harmony DPGT750EC Electric...
The tub doesn't tumble. heats up, no tumble. Belt? easy to fix? Thanks!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 26, 2010 | Dryers
My hoover tumble dryer Hnc175 wont heat up,is still working as normal, just no heat, i have cleaned out the filters and still not working
Heating elements can fail. These are relatively easy and economical to replace. The heating element is not necessarily the culprit if your tumble dryer does not get hot, however. There are thermal overload cutouts fitted to many machines. If they fail, the current will not be passed to the heating element. Replacement is again, fairly straightforward.
Tumble dryers will often have thermostats fitted. A heater control one, and an exhaust thermostat. The first keeps the temperature correct. The second, as its name suggests, monitors the temperature of the exhaust (in case the airflow in the machine is impeded) Once again, replacement is not too much of a problem.
http://www.repairclinic.com/Dryer-Troubleshooting
Please look, at the link above, it will show you how to perform troubleshooting. procedures and repair.
If you feel you don't want to do it yourself, please call a Hoover Tech, and get it looked at. Ask for a "Quote" for the repair, so you get an idea of whats what.
Apr 08, 2010 | Dryers
My white knight tumble dryer does not heat up,tried pressing the reset button but still does not heat up
you have a heating element burnt out. You will need to remove the back of the dryer and in the bottom of the dryer casing you will see the element Looks like a toaster element. Take model and serial # to an appliance parts house for replacement. An appliance tech shouldn't charge you that much to repair if you dont want to do it yourself.
Good luck hope this helped you some
Dave
Jan 28, 2010 | Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
My Maytag dryer tumbles but there is no heat.
check your heating element and thermal cutoff. Check the breaker on your house make sure both breaker to the dryer is on. Check your cord that connects to the back of dryer. If every thing is good then you will need a service tech.
Oct 31, 2009 | Dryers
Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
May 25, 2009 | Dryers
Kenmore Elite HE4 Electric Dryer Model 110.85087-400
Do you have a volt-ohm meter to check the heating element and thermal fuse??? I take it the dryer comes on and tumbles but doesnt heat up???
Jan 19, 2008 | Kenmore Elite HE4 Electric Dryer
Maytag Neptune MCE8000AY Electric Dryer Logo
524 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
