Question about Kenmore Dryers
Kenmore Heavy duty/extra large capacity. Could
Kenmore Heavy duty/extra large capacity. Could you tell me how to shut buzzer off.
SOURCE: Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer
catriver, Thanks for the advice....the model number is 110.64972300, serial number is MP5012063. Please provide the door hinge P/N and my husband will order and pick up the part. Cutiepie
Posted on Mar 02, 2007
SolutionGuy
  • 331 Answers
SOURCE: Kenmore heavy duty 80 series
The buzzer is wired through a switch on your dryer motor. The switch is NOT a normal switch... it's a centrifugal switch meaning that it is mounted on the motor shaft and rotates along with it. When it "spins up" centrifugal force flings it outward to make contact with the terminals on the outer edge of the inner motor housing (This tells the timer that the motor is functioning properly and it can now begin to heat the clothes. This is also the switch that keeps you from having to hold in the "Start" button 'til the clothes are dry) When the timer kills power to the motor, the buzzer sounds off because of this switch. As the motor slows, springs retract the switch from the contacts and shut off the buzzer. Make sense so far? Sounds like your centrifugal switch is getting stuck. Unplug the dryer and gain access to the motor. Then use Contact Cleaner in a spray can to spray and clean every inch (inside and out) of the motor. This should get you going again.
Posted on Jul 29, 2007
  • 833 Answers
SOURCE: turn off buzzer
Assuming you mean the end of cycle alert. The only way to do this is to follow the wiring diagram and install a switch to cut it off.
Posted on Dec 21, 2007
jsrock516
  • 5911 Answers
SOURCE: kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Posted on Aug 12, 2008
SOURCE: Dryer only blows cool air
my dryers works just blows cold air,can you help?
Thanks,
Xavier
quirozx@pella.com
Posted on Jan 02, 2009
I have a stackable kenmore washer dryer heavy duty extra large capacity 2 speed motor. The dryer has been making squeeling noise and has stopped toumbling around what can the problem be.
Could be the belt which connects motor and dryer drum. Could be the drum support rollers. Replace both either way -- common problem.
Jun 03, 2011 | Kenmore Dryers
How much to fix my Kenmore Heavy Duty Extra Large Capacity Top Load Washing Machine, the lid plunger is broken.
you need to ring round and find this out,,,one firm may charge the earth and yet another may be a lot cheaper,,,so sak more than one firm or repair man,
Nov 28, 2010 | Kenmore 15864/15862 Top Load Washer
How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Capacity of Kenmore Model: 110-9155120 Washer and 97566200-75662
3.6cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 30, 2009 | Whirlpool GEW9250 Electric Dryer
GE Six Cycle Automatic Dryer just buzzes when I push start
most of the time when the syary button just busses it means the motor is gone,you can take it apart and clean and lube itmake sure nothing stuck in it,let me know if you need more help-mike
Mar 19, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Turn off buzzer
some models have a buzzer in control panel which can be unpluged wire sealed off ather built into time and can not be turned offf good luck
Mar 04, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Turn off buzzer
Dec 20, 2007 | Kenmore 73952 Gas Dryer
Dryers Logo
62 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
