Question about Samsung LE40R74BDX 40 in. LCD Television
LE40R88BD SCREEN FLICKERING
LE40R88BD LCD TV screen flickering, started out with power off/on and clicking
SOURCE: screen problem
call samsung...had the same problem with my HP-R5072...and they cant seem to fix it !!!! ... If your lucky you should get a replacement TV within 2 to 4 weeks ... :(
Posted on Jan 30, 2008
SOURCE: Samsubg Monitor flickers
My samsung 740N lcd Monitor is flickering. can i get a solution of this problem?
Posted on Nov 05, 2008
  • 17 Answers
SOURCE: Gateway Flat Screen FPD1830
My Samsung 215TW started flickering like a strobe light when I would turn it on... then after a while, the speed of the flashing would change, and eventually, it would go out. After turning the unit on/off several times, I could get it to stay on, but after a while, it would start to get odd video noise (strange colors appearing on the screen), and then it finally quit.
Once the monitor went dead, I noticed that I could still see the image on the screen, albeit very dark, so I took my desk lamp, and placed it next to the screen, and I could see that the monitor was still active, meaning that there was an actual image on the screen, it was just that the fluorescent lamp that lights the screen was not staying lit.
I got tired of waiting for Samsung's customer service (thats a story all within itself), so I took the monitor apart in search for the problem (I am an electrical engineer and electronics specialist). I saw that there were two circuit boards, one being the power supply board, and the other being the video signal board. Knowing that there was still a video signal present, I focused on the power supply board, as it contains the transformers to ramp the voltage up to the necessary voltage to light the lamps.
I instantly noticed that several of the radial electrolytic capacitors on the board were bulging and looked like they had swollen and then blown. There are 5 caps on my monitor that needed to be replaced: (1x) 47uF/50V, (2x) 820uF/25V, (2x) 330uF/25V.
The 47uF and 820uF caps are on the power supply side of the lamp power circuit, and the 330uF caps feed the control signal into the IC chips that control the ballast of the lamps themselves, one for the upper lamp, the other for the lower lamp.
Once I replaced these units, my monitor started functioning correctly, and I dont have to give Samsung my absolute most favorite monitor ever for a refurb unit that most likely will have 15 dead pixels on it (mine has ZERO).
Posted on Dec 08, 2008
tray06606
  • 59 Answers
SOURCE: The tv will not turn on.
hi right now samsung is the best tv maker out right these problem dont happen with samsung what would be good to do is call them and let them know your problem cause you have a year protection on it thats if it less than a year
Posted on Jan 10, 2009
CAYPIANAN
  • 227 Answers
SOURCE: LN-T405H Samsung LCD TV
yes you are right it is the power supply, look for bad capacitors.
Posted on Jun 14, 2009
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Jan 16, 2016 | Samsung Televison & Video
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
https://www.youtube.com/watch?v=FUqdi7lwmcE
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
Jan 08, 2016 | Televison & Video
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
What causes flickering on 2/3rds of the screen on my SONY BRAVIA KDL-32L5000 MODEL?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 27, 2014 | Televison & Video
Luxor 40 914 tvb
- Flickering screen
- Dim screen
- Slow start
Apr 13, 2014 | Televison & Video
Flickering screen on lg m2362d
If you can hear sound, then screen is gone.
I'll bet you don't.
If you see an image, hear sound, just won't hold.
I'd bet on the T-Con board.
Not knowing what is really happening here..
If willing to dive into electronic's.
Open her up and start testing power side, starting with capacitors.
Feb 03, 2013 | LG M2362D 23 in. LCD TV
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
Flickering monitor
Flickering screen display
Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software, but it can also be caused by interference from external devices. The following examples describe situations in which your screen could start flickering:
  • Screen starts flickering because of interference caused by devices which generate magnetic fields, for instance:
    • a TV set
    • a laser printer
    • another monitor
    • fluorescent lights
    • hidden power lines
  • Apart from interference, an incorrect setting in your system CMOS setup can also cause flickering. On some systems it is possible to distinguish between interlaced and non-interlaced monitors. The setup of your system should always be colour non-interlaced.
  • Proximity to the monitor of fans, air-conditioning units or other devices with rotating motors.
  • The number of devices using power from the same electrical line. Are you overloading the plug?
  • Monitor placed on an unstable surface.
  • Improper video drivers, this is a software problem, see section B
  • An improperly configured or a defective video card.
Sep 30, 2008 | E-Machines E17T 17" Flat Panel LCD Monitor
Monitor flickring
  1. Flickering screen display
      • a TV set
      • a laser printer
      • another monitor
  2. Reinstalling the video drivers
    1. Start the computer.
    2. Click Start, select Settings, and click Control Panel.
    3. Double-click the System icon.
    4. Select the Device Manager tab in the System Properties window.
    5. Make sure that View devices by type is selected and locate Display adapters and Monitor in the list.
    6. Click the plus sign (+) in front of both items to get a list of installed devices.
    7. You need to remove every device by highlighting it and clicking the Remove button and OK when the warning message appears.
    8. After doing so for both items, they should disappear from the list.
    9. Close the Device Manager by clicking OK, and you will return to the Control Panel.
    10. Double-click the Add New Hardware icon.
    11. Click Next, select Yes when it asks "Do you want Windows to search for your new hardware?", and click Next twice to start searching for new hardware.
    12. This will take a few minutes and, after it is finished, you will have to restart the computer. Windows 95 or higher will automatically set up the correct monitor and video drivers.
    13. If the screen is still flickering, click Start, select Settings, and click Control Panel.
    14. Double-click the Display icon and select the Refresh tab.
    15. Change the Monitor Refresh Rates until the flickering disappears.
    16. If the flickering remains, go to step C.
  3. Troubleshooting
    1. If it is possible, connect a different monitor to the computer. If the flickering disappears, it is a fair indication that the monitor is defective, otherwise go to the next step.
    2. Set up the computer and the monitor on a different place in your house. If the flickering disappears now, it is most likely an interference caused by something in the original location. Check for devices which can cause interference.
    3. If the flickering persists, check the setup of your system. If available in the setup, make sure that the option Monitor Type is configured as Colour Non-Interlaced.
Dec 24, 2007 | E-Machines E17T 17" Flat Panel LCD Monitor
Samsung LE40R74BDX 40 in. LCD Television Logo
120 people viewed this question
Jerry Greenberg
Jerry Greenberg
