Question about Canon S200 InkJet Printer
Goes threw the motions but not go
It sounds and moves like it printing but theres nothing on the paper. IT has the sound of it printing. Ive tried the deap cleaning.
  • doomedfire Mar 26, 2008
    Ya with a new one
  • Anonymous Aug 27, 2008
    also goes thru the motions no prob. nothing is printed though. how do i find the pads to clean them
You can **** on the prinet and buy a new 1
Posted on Oct 27, 2008
  • Anonymous Oct 27, 2008
    u can buy a new 1
Put warm water on a soft clothe and take your printhead an gently put the printhead on the clothe....If you see ink on it, not the cartridge....maybe a bad contact between the printhead and the carriage...take a Qtip with alcool and clean it....
Posted on Mar 27, 2008
    Scholar:
  • 141 Answers
Did you try to replace your ink cartridge ????
Posted on Mar 26, 2008
SOURCE:
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
On my wheelwriter 6, when i type everything goes through the motion but it want type any letter on the paper. I change the ribbon and install fresh batteries?
There is a part on the print hammer solenoid that falls apart over time. It is a small whiteish cap that
just falls apart so the machine sounds and looks like it is working but there is nothing being transfered to the paper. I have ordered this part from Coleman manufacturing.
Jul 06, 2011 | IBM Wheelwriter 6 Typewriter
Do you think formatting my computer may fix my printer problem??my printer doesnt print.it loads the paper but it just ejects the paper with no print..ive tried to reinstall the printer driver but still...
Hello.
It sounds more like a cartridge problem. if the printer has been un-used for a while it may simply have a blocked head. If it is going through the motion of printing but nothing is actually printing then it is defiantly a cartridge issue.
This link below will help you rectify this. http://www.fixya.com/support/r3986425-unblock_print_heads
If the paper simply feeds in, then feeds out is is a paper sensor issue and I would recommend simply replacing the printer. Fixing it would cost more than the printer is worth.
I hope this Helps Regards GM
Jun 30, 2011 | HP DeskJet 3745 Printer
My Epson DX4000 Printer keeps getting paper jams and wont print
still printing but the paper goes no further?. It may be the paper is locked by paper feeder mecahnics, Open case, check it, and may be there is something "material" broke.
May 24, 2009 | Epson Stylus Pro 3800 InkJet Printer
Will not print in black
Please perform self test of the printer.
Mar 06, 2008 | Lexmark X1270 All-In-One InkJet Printer
Epson c60 printer
Common problem with Epson Printers.
Either the print head is clogged, or the tube that goes from the pump to the printhead fell off.
Open the printer cover so that the ink cartridges are in open view and then UNPLUG THE PRINTER" so that the ink cartridges wont go back to home position. (If there is a change INK cartridge button, then press that then uplug the printer when the cartridge stops moving.)
You can try to clean the print head by folding up a couple paper towels, then saturate it with windex with amonia. Place it under the print head assembly and manually move the print head assembly over the paper towel back and forth to clean the bottom of the print head assembly. You should start seeing ink on the paper towel.
After cleaning, run the cleaning program that Epson has, and try it out.
If it still doesn't work, then you might have to repeat this a couple more times.
If it still doesn't work, then it might be time to get a new printer.
Hope this info helps.
Good luck.
Mac
Feb 07, 2008 | Office Equipment & Supplies
Canon S200 InkJet Printer Logo
62 people viewed this question
Clive
Clive
old marine
old marine
Ekse
