Question about Targus AMW05US Mouse
Model amw1602eu how do you get the batteries in the mouse
How do I change the battery in a logitech wireless battery. I can't seem to figure out how to open it to even see what kind of battery is needed.
For changing the batteries of logitech wireless.I guess a video tutorial will help you out rather than written instructions. Watch it to lean how to replace battery of the logitech cordless mouse ( Logitech MX 1000 Model). If you are having a different model please specify the details of your model.
Mar 02, 2011 | Logitech Cordless Mouse
How do i replace a battery in a wireless mouse?
I do have a Logitech wireless mouse and keyboard as well its model is EX100. If this is the first time you are replacing the batteries then here are the steps:
  1. Slide the top cover of the mouse downwards.
  2. You need to press it down slightly to unlock the cover.
  3. Replace the batteries
  4. Put the cover back in
  5. If the mouse does not respond after replacing the old batteries press the Connect button underneath it
Here is the link for the detailed manual for Logitech's EX100 mouse and keyboard.
http://www.logitech.com/assets/35687/quick-start-guide.pdf
However if you have a different model, click the link below and select the model you have and click on "Changing the battery on my (Logitech mouse model)"
http://www.logitech.com/en-roeu/support-downloads/downloads/mice
If this doesn't help you, I will continually check on this and if you can provide the model of your mouse, the better. Thank you for choosing FixYa! Enjoy!
Feb 20, 2011 | Logitech Cordless Mouse
How do you turn on a wireless mouse
When you flip the mouse upside down you can locate a battery compartment, please insert a battery in it appropriately. Then next to the battery compartment, you will notice a green button which can be pressed or slided (according to different model) to switch the wireless mouse on.
Please specify the exact model number so that we can show the schema of the mouse from the manual.
Feb 15, 2011 | Logitech Cordless Mouse
How do I change the battery for my logitech cordless mouse? Can't find opening for battery....
hi marlys, i am happy to assist , Ya its not too easy to replace battery in logitech cordless mouse,in the back of mouse, you have mouse pad just remove it , you can see they provision to remove the mouse, there been Four screws been inside that mouse pad, But before going to open your mouse just check you have new battery with you, if you connt find in any shops just go to eBay , you can get it thee, If you mansion the excate model name of your mouse mean i will send video for that particular model itself , no issue just check out this video
Jan 06, 2011 | Logitech Cordless Mouse
Does mouse have a battery? I cannot get the mouse to work.
All cordless mice have batteries. Usually you'll find a battery door on the bottom.
Jul 15, 2010 | Logitech Cordless Mouse
Computer not reading mouse
First.... Plug your reciever into another USB port, wait for it to install itself (Window 7, Vista) you'll know when you see the notification that you software has been sucessfully.
if XP, you'll need drivers by going to http://www.hp.com, select <Support> from top of page, right-most side. Click Driver Downloads and type your reciever model into the search box. Wait for a confirmation i.e.. a page showing a picture of your device and/or choices of potential devices with similar models; pick yours. However, I have not yet come across a wireless mouse or mouse/keyboard combo that didn't install itself.
Next: The Mouse Does Require Batteries. Be sure they are placed correctly; they go into the top of the mouse in older models (the part where your hand rests, slides back to reveal the battery compartment). Newer Models usually have a standard, common, battery compartment on bottom.
The optical laser bulb should light when the batteries are placed correctly. If the light (red in older models, blue in newer models), if no light, check/replace your batteries. No light, check your warranty.
Jun 13, 2010 | HP Wireless Optical Mouse
Battery change for model 98792 wireless GE mouse
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Jan 12, 2009 | GE Wireless Optical Mini Mouse 3087897985
Replacement battery for mouse
well there should be a battery door on the bottom of the mouse directly below where the palm of your hand rests on the mouse and ushally holds AA or AAA batteries if you shoot me the exact model of your mouse I can assist you further if needed
Oct 12, 2008 | Logitech Cordless Mouse
Where's the batteries?
I had a similar problem with my battery going dead in my Logitech mouse. There was a "aa" battery located under the rear top cover. it's the part that has the Logitech logo on it. You simply press the button underneath the mouse @ the back that has a LOCK symbol on it & lift off the cover. Put in a new battery & you should be good to go.
Fred
Oct 01, 2007 | Logitech Cordless Mouse
Targus AMW05US Mouse Logo
Top Targus Computers & Internet Experts
steve morris
steve morris
dhnguyen
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
