Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
My unit comes on for a few inutes then turns off. It is blowing but not really cooling
    Problem Solver:
  • 12 Answers
It sounds like you have a refrigerant leak somewhere and your unit is low on refrigerant. You need a pro's help here to find the leak and recharge your unit properly.
Posted on Jul 21, 2010
  • 34 Answers
Has unit lost gas charge ? Remove shroader valve cap on outside gas pipe connection and depress shroader valve quickly to see if there is a good high gas pressure. If no, or low gas pressure, need to find leak and repair it and regas unit to correct pressure.
Posted on May 21, 2010
    Problem Solver:
  • 19 Answers
You may have to check the timer on your remote it may be set at a shot time period to come on and off if not the senceing bulb under the cover of the inside unit may be touching the coil if the unit if not so check the remote and see if it is on AUTO if so change it and put it on cool
Posted on May 03, 2010
Unit not working correctly. The unit worked for the winter, few days ago I turn on the AC and noticed that it wasn't cooling like it should.
It's could be the board or a heat relay. See if you have 24 volts on "x2" im assuming, emergency heat when in cool mode if so it's the board. Or unhook black or x2 or your emergency heat from board and run unit in cool. If heat stays on its a relay
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 02, 2016 | Heating & Cooling
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
I bought a DeLonghi PACC120E portable a/c with no manual. The unit does not cool, and it dumps water. How do I get it to blow cool air?
I would drain the water out of the machine via the plug on the back once the unit is drained turn on, wait a few minutes. If compressor does not come on or comes on and does not cool, you need service beyond diy.
Jun 18, 2014 | DeLonghi PAC C120 Portable Air Conditioner
Window air conditioner cools (very icy cool air) for a minute or two then switches to fan. Will then stay on fan for about 10 minutes and then once again get "very cold", but only for a minute or two
Before I even read that far into your post, I was thinking "thermostat" replace it...It seems to be failing badly. If you take it into logical perspective...normally the unit gets turned on, then takes a bit to get cold, then once it reaches its pre-determined temperature, turns the unit either "off" or just blows the fan...by kicking off the compressor. This unit you have is getting this cycle done within 5 minutes instead of a few hours...replace the thermo and you should be fine. Now if you could post the exact model number here I can go look up the part for you.
Jun 20, 2012 | Amana AH123E35AXAA 11,600 / 11,200 BTU...
My air conditioner starts blowing like a fan before my apartment is cooled off, why does it kick off and on like this?
When you first turn it on the fan runs and after a few minutes the outside unit comes on, once the outside unit comes on it take time for it to cool the coils which cool the house, And a/c does not really cool the air,It removes the heat that is in the air.
Aug 04, 2010 | Kenmore Heating & Cooling
Unit cools for a few minutes then stops cooling. Even fan stops blowing air but the unit remains 'on'
unit may be short of gas. will run for a few mins before low pressure switch turns the compressor off. you will need to get an engineer to check gas pressure
May 21, 2010 | Samsung AW1003M Air Conditioner
Rv unit blows cold for a few days then blows hot.
make sure temp sensor stuck in coils or unit low on Freon cannot refill
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
Wont no water to empty or drain
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
Apr 01, 2009 | GE APN08AA Portable Air Conditioner
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
236 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
