I just bought a pair of "istar" USB speakers which came with no instructions. I have put the usb into a port at the back of the computer and plugged the little green (sorry not real tech savvy lol!) plug into it's socket too. The speakers turn on, but how do I now get the sound to come out of the speakers. I have been trying to test it listening to youtube and nothing comes out - it's still coming out of my computer and the sound in my computer is quite distorted (which is why I got speakers). Can anyone tell me what changes I need to tell the computer in order for the speakers to function? Cheers, MUMOF4
    Genius:
  • 1,226 Answers
Hello.
You can go to the control panel and then double click the sounds and audio device. On the audio, under default device select the newly installed device audio or what ever indicated in the selection.
like this picture below
If not seen the newly installed device you install the driver of you hardware. may this help.
Posted on Mar 26, 2008
  • 3,037 Answers
You should be able to choose the speakers in start > control panel > audio devices > hardware
  • Benjamin Patri
    Benjamin Patri Mar 26, 2008
    if you are unable to fix the problem from within the the audio devices, let me know, but that should work
    other things to check
    1. do the speakers have their own volume control which may be turned down or on mute
    2. is there any setup instructions with the speakers
  • Benjamin Patri
    yes, it is under audio, not hardware
    Guru:
  • 1,894 Answers
First of all soon after connecting you need to a configration of the speakers.
  • 1 more comment
  • dewan nafees ahmed Mar 26, 2008
    first of all soon after connecting you need to a configuration of the speakers.
    go to your audio driver settings and change the settings for the new set of speakers you have attached.
    you wil hear clear sounds automatically.
    good luck
    thank you
    first of all soon after connecting you need to a RE configuration of the speakers.
    you will hear clear sounds automatically.
    good luck
    thank you
    good luck
    thank you
  • 4,889 Answers
Can you tell me the brand and model number of your speakers please..?
Multimedia HI-FI Speaker Systems model #SP710a setup
Computer speakers get their signal from the phone jack (maybe from USB port). They have a power cord (if USB powered connect to a USB port on your computer) to connect to a wall outlet.
Nov 15, 2013 | Computers & Internet
HMDX Jam wireless speaker cannot be paired with my computer
Go to your Bluetooth settings, go to the "Audio/Video" tab, under the "Content Protection" section uncheck the "Connect to content protection enabled headset only" and your bluetooth speaker(s) should now work.
Feb 02, 2013 | Audio Players & Recorders
Winxp sp3 andwin7 cannot recognized its USB adapter saying that it is an unknown device, i've tried to remove it from device manager and reboot, i also tried to update the driver through windows update...
The easiest way to figure out what is going on is to try the adapter on a different computer. If it is still good it will be detected. Usually when a usb device fails it may be recognized or is recognized only as a usb device but it will not work. You don;t have to install any drivers just to test this on another computer unless you want to make sure it is fully functional. It is also possible that the usb ports on the computer are not working or one isn't. Simpley use on of the other ports.The usb port controller usually operate a pair of usb ports so try all the ports. You may get a problem with one port or pair but rarely all at the same time.
I think you will find that the adapter itself is your problem and will probably need to be replaced.
Sep 15, 2011 | EnGenius EUB-9701EXT2 Pre-802.11n Wireless...
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
None of my usb ports function as "high-speed" 2.0 , and I constantly get the message that my device can perform faster if I connect it to a high speed USB 2.0 port. I bought this computer brand...
you usb ports are to slow for the usb 3.0 device that message keeps coming up saying that the device is better then your usb ports you have on your computer...almost every computer now have 3.0 usb ports that have very fast transfer rates for data back and forth. well i tell you the message you get is not trouble with your usb port it just trying to tell you the transfer rate will be slower with your usb 2.0 port... i hope this helps you.
Jun 13, 2017 | Sony VAIO Digital Studio PCV-RZ22G PC...
New pair of La Cie speakers. Dell pc. Not sure whee o plug in varous leads, but it now does the beefs etc on Windows. But when I put a CD in there is no sound at all
I think you were disconnected from our conversation. Anyway, the LaCie speaker is USB powered so you dont have to plug it into a power source because they will be powered by the USB port. You dont need to plug them into a speaker output on the computer as well. Just plug the USB cable of the speaker into your computer's usb port. As for the other speaker, there is a cord that used to connect the speakers together. Just plug it underneath the first speaker, that says "speaker" source. Then go to your Control panel >> Multimedia >> Audio and choose them as your Audio Output device.
Mar 04, 2010 | Computers & Internet
Acer Speakers not functioning
if you do have a reinstall disk you might want to disconnect the speakers ,run the install disk follow the instructions .This might take care of it.
Good luck
Aug 29, 2009 | Acer (90.18612.36B) Computer Speakers
Headphones with mic / external speakers
Does your computer have front audio ports? If so, you can just plug it in there. Otherwise you need a single male 2 dual female converter to plug into the speaker port.
Jun 21, 2008 | Computers & Internet
Multimedia pc speakers
the usb plug is on usb socket... the green jack if there is, is on the line-in... if its the only jack it certainly plugged on the laptop 's speaker port colored green.. the pink is always the microphone... rate me if this helps...
Jan 21, 2008 | Computers & Internet
Downloading from pc to digital photo frame
Solution:
1. I don't think the USB Cable was given to Download Photos from the computer - I think it was given to upload photos to the Computer.
2. The manufacturer has either gave you the wrong cable for a different type of Operating system or you are trying to put it in the wrong port.
Suggestion:
1. Call a Technical Support Line (Probably found on back of instruction booklet.)
or
2. Send the Product back to the company.
Dec 18, 2007 | Cameras
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
