Question about Yamaha 12V Air Pump
Waverrunner engine problem
2007 Yamaha FX Cruiser High Output, having problems with the power of it. At times it will run at full RPM’s with the throttle fully pulled, and at times, with the throttle pulled, it runs at a lower RPM with less power. At times it bounces back and forth. I was thinking it was possibly the fuel filers clogged, but don’t know how to find it or what not. Thanks for your help.
Ditto problems with a 2007 VX Cruiser. I have two and only one is giving me problems so I don't think its the gas (since I buy for both at the same time). I see no fuel filter between the tank and the injectors. Wondering if I have an injector problem Have used a bottle of fuel injector cleaner to no avail. Additionally, I have had to replace spark plugs with relative frequency in both VX Cruisers.
Posted on Jul 16, 2011
  • Mr Jimbo Jul 31, 2011
    I have the same issue: 2 2007 VX Cruisers, one runs at 6000 rpm and every once in awhile it kicks up to the full 8000 rpm. The other runs fine and I fill them both with the same gas at the same time. I'm wondering if there is an issue with the circuit board that controls the lo mode.
2004 waverunner fx cruiser, ran great last time out. Now hard to start and wont run on high speed. Nothing over 6 mph.
How old is the fuel? Ethanol causes major problems if left too long. You may need to empty the fuel and clean out the fuel system. Try changing the fuel filter and adding some seafoam to the fuel and running seafoam thru the fuel system. Hopoe this helps.
Mar 15, 2014 | Covercraft UltraTech Custom PWC Jet Ski...
My 1999 yz 125 runs well at high rpm but won't idle and when I give it full throttle it bogs.
Hi, Anonymous and the usual suspects are:
1. Severely drained or faulty battery.
2. Faulty regulator/rectifier or high output coil.
3. Faulty power valve, solenoid or installation.
4. Clogged air filter or exhaust.
5. Cracked or incorrect float level.
6. Float needle is not seating.
7. Faulty reed valve.
For more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
UPDATED 2005 YZ125 bog issue with videos
Dirt Rider Magazine
YAMAHA YZ125 Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Jan 09, 2014 | 2003 Yamaha YZ 125
Dirt Rider Magazine
Briggs & Stratton Briggs Stratton 6200 Watt Portable Generator voltage adjust
Usually the cause of slightly low voltage like this is that the engine is not running at full operating RPM. Find the high speed adjusting screw on the govenor linkage and adjust the engine RPM until the output is 220V - 240V
Dec 09, 2013 | Briggs & Stratton Briggs Stratton 6200...
Got my 2009 Yamaha FX sho waverunner under water, drained the water from the hull and tried to start it. Turned over 5 or 6 times and stopped. Pulled the air filter out and of course had water in it....
remove all sparkplugs and hold full throttle and crank over several times to get water out of cylinders ! have a jump pack ready as battery will die ! use carb cleaner on the plugs each time you try to run after this , hope this has only just happened as internal damage might already started ! if all ok check the engine oil also as water normally gets in after this problem ! if oil is milky then change oil several times , run for 15min on hose each change until oil normal colour ! then you must take for a run for an hour to help dry it out !
Mar 19, 2013 | Yamaha 2009 WaveRunner FX Cruiser SHO
Yamaha waverunner won't idle and losing power
L stands for limp mode
it is a mode that the ECM selects to prevent serious damage to the engine ( from you lack of oil )
have the fault codes read then reset with the scan tool
Mar 31, 2017 | Water Sport
2004 fx CRUISER ho WAVERUNNER DOESNT WANT TO IDLE OR RUN AT TOP S
did you mean 900 cause 9000 is overrived and the engine may be blown
Jul 08, 2010 | Boating
Sticky throttle cabel
idle cable out of adjustment and or throttle cable needs adjusting also and they always need to be lubed at 5000 miles adjust throttle cable with wheel striaght forward idle cable to all the way right lock and 2-3mm free play on throttle grip
Mar 03, 2010 | 2007 Yamaha V Star Custom
Diagnostic Code P2074 on 2007 PT cruiser-can't find on OBD list.
P2074-manifold Pressure/throttle Position Correlation
CORRELATION - HIGH FLOW/VACUUM LEAK
When Monitored: Engine Running, during all drive modes.
Set Condition: If vacuum drops below 1.5 Hg with engine RPM greater than 2000 RPM
at closed throttle.
POSSIBLE CAUSES
VACUUM LEAK
HIGH RESISTANCE IN MAP (K7) 5 VOLT SUPPLY CIRCUIT
RESISTANCE TO GROUND IN MAP (K7) 5 VOLT SUPPLY CIRCUIT
MAP SENSOR
HIGH RESISTANCE IN (K1) MAP SIGNAL CIRCUIT
RESISTANCE TO GROUND IN (K1) MAP SIGNAL CIRCUIT
HIGH RESISTANCE IN (K4) MAP GROUND CIRCUIT
PCM
TP SENSOR OPERATION
HIGH RESISTANCE IN (K6) TP SENSOR 5 VOLT SUPPLY CIRCUIT
RESISTANCE TO GROUND IN (K6) TP SENSOR 5 VOLT SUPPLY CIRCUIT
TP SENSOR
HIGH RESISTANCE IN (K22) TP SIGNAL CIRCUIT
RESISTANCE TO GROUND IN (K22) TP SENSOR SIGNAL CIRCUIT
HIGH RESISTANCE IN TP (K4) SENSOR GROUND CIRCUIT
Mar 27, 2009 | 2007 Chrysler PT Cruiser Touring Hatchback
Yamaha 12V Air Pump Logo
542 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
