Question about Panasonic TH-50PZ77U 50" Class Plasma HDTV
Icame accross a screen with all kinds of tv
I came accross a screen with all kinds of tv settings and defaults and wond up turning the tv sound off ,thinking that I would have more volume while watching regular tv with the home theater system on.Now i cant get back to that sceen to change it back, and when I change the speaker output back to tv theres no sound from the tv.
    Problem Solver:
  • 17 Answers
I have experienced this problem a few times with your TV. First check and make sure that the speaker toggle option is set to "on". I have seen this 3 times and ended up replacing the television main board, which restored the audio.
Posted on Jun 17, 2010
Screen went black sound works, also small upper left screen works for some kind of video description.?
If you can get settings menus up reset the tv to factory default. Should it start working autotune it. Ensure it is set to digital output if it is analog/digital. Also check the aerial/antenna installation is properly connected. If there is some display and sound then I suspect the fault is not too serious.
Jun 02, 2015 | Sony BRAVIA Televison & Video
Vizio tv problems
Have you checked the TV without other devices connected to the TV.
Eg. disconnect any home theatre or speakers from the TV.
Verify with audio menu if the settngs of TV speakers is on or off ?
To adjust the audio settings:
1. Press the menu button on the remote. The on-screen menu
is displayed.
2. Use the arrow buttons on the remote to highlight audio and press ok. The AUDIO menu is displayed.
3. Use the arrow buttons to highlight the setting you wish to adjust, then press left/right arrow buttons to change the setting:
• TV speakers - Turns the built-in speakers on or off.
Lastly have you tried restoring the TV to factory default settings.
To restore the TV to its factory default settings:
1. Press the menu button on the remote. The on-screen menu is
displayed.
2. Use the arrow buttons on the remote to highlight system
and press ok. The SYSTEM menu is displayed.
3. Highlight reset & admin and press ok. The RESET & ADMIN
menu is displayed.
4. Highlight reset TV to factory defaults and press ok.
5. If you have changed the default parental control passcode,
enter it now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults and clear all account information."
6. Highlight reset and press ok.
7. Wait for the TV to turn off. The TV will turn back on shortly
afterward and the Setup App will begin
Apr 29, 2014 | Televison & Video
I have a red line going accross my tv screen. Its
Do you have speakers next to your tv sometimes the line on your tv will be from your sound to close to your tv also the red line could mean your tv tube is going out there about 300 to replace but i ould check frist on your sound are something close to you tv that is maken the red line in the middle of your tv
Dec 09, 2009 | Sony KP-51WS510 51" Rear Projection...
Sound only w/1 straight red line accross the middle of the screen
try to replace the vertical ic and resolder the vertical section.
Sep 16, 2009 | Hitachi 36UX01S 36" TV
My screen has lines on it that show up blank accross it horizontally
Since I do not see the kind of screen you have, I surmise (maybe wrongly) that the split screen is activated.
Press [MODE]. Use [DownArrow] to scroll to where is says Full Horiz G-T. Highlight FULL and [ENTER] Then [2nd][QUIT].
If that does not solve the problem
[2nd][MEM] [7:Reset][2:defaults][2:Reset]
Hope it helps.
Sep 09, 2009 | Texas Instruments TI-83 Plus Calculator
Icame home and tried turning on the tv and it isnt
See black light at the back.
If no back light, problem most likely come from power supply.
If has back light, need tech to check and figure out exact problem.
Aug 18, 2009 | Akai LCT2715 27 in. LCD Television
No picture. Just a vertical line accross the screen.
When this kind of set comes in for this problem, it is typically caused by a leaky/intermittent diode D402, located next to the heat sink for the vertical deflection IC. I will typically also replace the vertical deflection IC at the same time, just to avoid repeat failures.
Jul 06, 2009 | Toshiba 32DF46 32" TV
White line accross screen holds when picture goes up and down.
This can be caused by the contrast being set too high. Typically, for a Sky box the TV's contrast should be set to around 65.
If this does not help, then the LCD panel is probably at fault.
Apr 25, 2009 | Philips 32PF5531D 32 in. LCD Television
Samsung HCN653W 65 in. lines.....lines.....help!
My first guess is it kind of sounds like a convergence board problem i know they had some service bulletins on them. hope that helps oh and convergence boards arent exactly cheap and will probably require some soldering
Mar 22, 2007 | Samsung HCN653W 65" Rear Projection...
SET PLAYER to p-scan HOW TO SET IT BACK
Open the user manual see how to change the mode. Try to do wihtout seeing, its some kind of a challenge.
Mar 13, 2007 | Protron PD-800 DVD Player
Panasonic TH-50PZ77U 50" Class Plasma HDTV Logo
70 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
