Question about Kenmore Washing Machines
Kenmore top loading washing machine model 4021092, keeps filling
Kenmore top loading washing machine model 4021092, water just keeps filling up and won't stop and agitate
    President:
  • 949 Answers
It is most likely siphoning out. Here is a link that will help explain it and how to correct the problem, let me know if this helps. Thanks
http://www.fixya.com/support/r4621172-clothes_washer_stop_filling_water
Posted on May 03, 2010
Fills with water and then nothing kenmore washer model 23822100 type 111
Top load machines will fill with water while the lid is open. Your problem starts when you close your lid. NOTHING happens. I believe this to be your LID SWITCH . Replace or have replaced and you should be OK. GOOD LUCK.
Jul 26, 2011 | Kenmore 23822 Top Load Washer
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
My kenmore top load washer keeps filling, watere
the fill valve is bad or there is a hole in the tubing that attaches to it, this tube goes from the pressure switch to a bulb on the side of the tub only air pressure goes through this tube one small mouse bite and it is damaged
Jul 06, 2009 | Kenmore Washing Machines
Kenmore 70 Series washing Machine won't stop filling with water
filling and never stops and never agitates? then check level switch and hose, any hole in the clear hose to the level sw can cause this. if airtight then replace level sw.
Apr 27, 2009 | Kenmore 22422 Top Load Washer
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Kenmore top load (model # 110 82370120) drain problem
Could you please rephrase the question. I'm not sure if I'm understanding this correctly
Dec 01, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
103 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
