Lacie big disk 2.0 usb
A problem i have:- my son bought me a LACIE BIG DISK 2.0 USB. i can
get it to mount but can't access the drive. Have set-up as instructed and
when i try to access to format drive to FAT32 the computer hangs and
requires reset before operation. Have attempted various fixes but nothig has worked so far. Please adivise
best regards,
Terry m
when I conect my lacie big disk usb 2.0, it says detect tusb 6250 boot device but my win xp service pack 2 needs driver to install it what can I do about it.
thanks
  • Anonymous Apr 09, 2009
    Same problem. Restart didn't fix
  • 3 Answers
For anyone with a Big Disk drive that doesn't get recognised by Windows and gets a TUSB 6250 message in Device Manager, the cause is very likely to be the power supply. Although the drive will be powered up, it is not spinning at the correct speed. I tried all of LaCie's technical support suggestions, some of which are outlined above and none worked. They finally suggested getting a new power supply. This solved the problem (Wattac, £22). This problem has affected a lot of LaCie Big Disk owners...
Posted on Jul 18, 2011
Thanks this helped m2
Posted on Oct 03, 2008
Please try the following:
# Disconnect all cables connected to the drive.
# Connect the power cable to the drive.
# Connect the USB-cable. First to the drive. Then to the computer.
If the drive is detected correctly the problem was probably caused by improper shutdown or un-mount (unplugging the cable without dismounting first, etc.). When this has happened, the USB-interface needs to reset itself properly. After this, reconnection should be no problem.
Posted on Apr 06, 2008
I bought a LaCie 600GB Big Disk USB 2.0 ( 300990U ) at a garage sale and my Dual 2 Ghz Power PC G5 doesn't seem to recognize it. I am running on OS 10.4.11. The power supply seems to work and I have tried...
Chances are it is formatted in a way that OS X cannot detect. See if you can format it using the Disk Utility and then see if that allows it to mount the drive then...
Mar 27, 2011 | LaCie Big Disk (300990U) (LAC300990U) 600...
My Lacie 500 GB big disk constantly has the flashing blue light. The drive dose not spin all the time, when it does is constantly clicks but does not mount. I use an iMac and a MacBook Pro and neither will...
Hard drive is no good. If new replace under warranty. Given the bad luck you have had with this brand, you might consider replacing it with a different unit.
Jun 19, 2017 | LaCie Big Disk 500 GB Hard Drive
LaCie Big Disk 500GB not showing up
1. the usb connector in the PC may have a broken board contact needs soldering or replacement.
2. there may be a broken USB cord to the external usb drive
3. the electronic controller in the USB case may not be working.
4. A new case may be needed with a new controller.
Jul 08, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Apr 03, 2009 | LaCie Big Disk Extreme with Triple...
LaCie Big Disk
Fixya is unable to suggest parts sources.
Dec 17, 2017 | LaCie 301294U 1TB Big Disk Extreme + with...
You can try by increasing the RAM of ur Machine
Jan 23, 2008 | LaCie 2-Port eSATA 3Gb/s PCI Express Host...
Computers & Internet Logo
2,111 people viewed this question
David Payne
David Payne
