Question about Cyberhome CH-DVD 300 DVD Player
When on video 1 or 2 only get sound and no picture I have it connected to toshiba tv and am a cox subscriber. Have called cox but they say the fault is not in tv, but in the dvd.
  • guru7 May 03, 2010
    I moved the yellow thing from thecoaxial tovideo and va la it is working and it was not the dvd tha was wrong after all. I hope I can make it work the next time and THANK YOU FOR GIVING ME THE BOOST TO KEEP TRYING,
  • Cyberhome Master
  • 19,396 Answers
Hi.
The fault is probably the DVD and box connection to TV on AV1 and 2, or the settings.
If you are using AV cables you need to check that the yellow video r cable is properly connected, along with thered and white audio cables. The cables must go from DVD or box output to TV input.
If you are using component cables, then the audio may need an additional cable.
To be more specific I need to know the following.
TV model.
Model of each component connected to TV (DVD, box etc)
Type of cable used and what cable connects to what input on TV.
Here list of common cables used to connect TV to devices:
HDMI
AV
e4fa7when on video 1 or 2 only get sound and no picture - 80b4129.jpgss=
Component
S/PDIF optical audio:
Please let me know list and models of connected devices, TV model, and details on how each device is connected to TV.
Thanks.
Posted on May 03, 2010
My toshiba theaterwide hd 51h83 no picture no sound when plug in blue screen come on then go off in 3second then red light next to power button blinking no picture
call toshiba customer care. Seems like software issue. I had the same. I was told to put 2 special files on a usb drive, connect it to tv, to reflash to tv software. it came back to life after that.. just try..
Nov 23, 2012 | Toshiba 51h83 51-inch Hdtv-ready...
Got cox Digital cable box today, cox can not tell me how to hook up to box to make it rec/play. Info I read old cox papers from 2002 says I need a vcr controller, Cox does not know what that is and it...
For a standard VCR which is what most people have, all you need to do is connect a yellow RCA cable for video from the yellow output jack on the cable box rear panel to the VCR's yellow video input jack on its rear panel. Next connect a white RCA audio cable from the cable box white RCA output jack to the VCRs white RCA audio input jack. You can record a cable show by selecting the LINE input on the VCR and selecting the TV show on the cable box.
Now for playback, connect the VCR to your TV. Connect a yellow video cable from the VCR's yellow output jack to the TV's yellow video input jack. Same for the white audio connection. Select on the TV, the source input for the VCR. Its not complicated and you should not need any other devices for a standard setup with a digital cable box and vcr.
Aug 25, 2010 | Toshiba Televison & Video
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
No tv picture just sound using cox cable message
http://www.yamaha.co.jp/english/product/av/down/index.html
Firmware update if your using HDMI. also, check your settings on your Cable box menu for Video and make sure it's set to HDMI. Hope this helps
Dec 27, 2009 | Yamaha RX-V3900 Receiver
No Picture. I do have sound and it will change channels. I have unplugged power cord and let set. Lights flash on front like it is re-setting itself, but still no picture. I have also removed the DVD...
This could be one of several things, the line or frame stage may have developed a fault which would put the set into a protection mode to stop any damage to the CRT. You would need to remove the rear cover & use a mutil-meter to check which voltages are present & which are missing to the timebase stages. It could be the frame IC or the line output transistor/ output stage.
Sep 29, 2009 | Toshiba Televison & Video
How do I get sound on my Vizio SV420XVT 42 Great picture but no sound
I had the same problem. I could get an analog audio signal but no digitial signal. My problem was with the cable box setting. I have Cox Cable. With the Cable remote I went to settings/settings/Audio out and selected HDMI. Worked like a charm
Oct 19, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
Cant get a picture
1st-how do you have your "cox" cable box [you could have said it was a cox cable box!!] connected.Can you 'get a picture' through the TV without the VCR ? Do that! disconnect the VCR from the line and plug the TV directly to the "cox" box.Does it work? Are any of the cables connected from cox to VCR to TV damaged.? Let me know how you have the three(3) equipments connected.
Aug 07, 2008 | Toshiba W522 VHS VCR
Fuzzy Picture when souce is not HD
sounds like you may have a problem with the digital scan card or next hyper module. i suggest calling your neighborhood tv repairman
Mar 30, 2008 | Toshiba 65HDX82 65" Rear Projection...
Toshiba 24AF41 TV won't turn on
The tic tic sound is a device called safety switch that keeps turningyour TV off because an internal fault, such as a defective component ora wrong voltage is detected.
When is like that we say the tv is in protected mode.
Start unplugging TV power cord for one or two hours (it is called hardreset), this will drain power from tv and seset internal circuit, andsometimes can clear the error message, if the fault was only temporary.
If the problem does not go, then you have to troubleshoot the problem,probably some component inside the tv is faulty and may need to bereplaced. If you want to do it yourself is better to buy the servicemanual.
Here you can buy parts and service manual.
If you need to call for repair you can use the phone number listed on the TV owner manual.
Sep 03, 2007 | Toshiba 24AF41 24" TV
Loss of sound when I go to HD mode of tv.
Unplug the Moto box and plug back in after 1 min, as far as the codes, which remote cable/ tv? Cable remotes vary so much you will probably have to call your provider to have them walk you through programming.
Jul 16, 2007 | Toshiba 57HDX82 57" Rear Projection HDTV
Cyberhome CH-DVD 300 DVD Player Logo
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
