Question about Water Heaters
Bradford White hot water heater - burner lights only 30 seconds
I have a 10 yr old Bradford White gas hot water heater producing only slightly warm water. The blower runs constantly and the burner lights for only about 30 seconds very infrequently. When I was able to see the flame very briefly it appeared very yellow.
    Scholar:
  • 102 Answers
The slightly warm water makes me think of a thermostat problem. The fact that the heater is 10 years old I wonder how hard your water is. Calcium build up kills water heaters. But the yellow flame you mention could be the results of dirty orfices. May want to have a Pro look at that.
Posted on May 05, 2010
How do I light my hot water heater?
It is pretty easy - make sure gas valve is open, change control know to pilot. Press the ignitor a few times and once pilot lights up switch control to warm or hot position.
See instructions by downloading manual for MI-403SF6BN from this site
Bradford White Water Heaters Built to be the best
Sep 15, 2014 | Bradford White Bradford MI403S6FBN-337 40...
Need conversion of lp to propane on a Bradford 50 gallon hot water.......
1) Do you mean NG natural gas to propane?
2) Most companies do not support gas-type conversion, especially with modern FVIR-compliant heaters. New burner, gas control are required at minimum.
3) Contact Bradford White and include model number, serial number that appear on label on side of unit.
Feb 24, 2013 | Water Heaters
My Bradford White Defender M-I-30T6FBN doesn't show igniter button on instructions
1) Copy following links to identify gas control valve and read ignition procedure, and access service manual for your product:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Honeywell gas control used on recent Bradford White gas water heaters has red knob that rotates to pilot. Press and hold red knob. Then push red igniter button until status light changes.
Feb 11, 2013 | Bradford White Bradford MI30T6FBN-337 30...
My Bradford White Defender M-I-30T6FBN doesn't show igniter button on instruct8ons
1) Just open the following link to identify gas control, and following instructions for lighting each gas control that appear under the gas control that looks like yours.
2) Otherwise add a comment and carefully describe gas control valve, and then open link and compare your description to pictures of each gas control valve, and then look below each picture for link that says how to light water heater.
3) Call plumber.or local service technician, or local BW supplier who can recommend technician.
4) Call Bradford White to get recommendation of local technician.
I have a Bradford White model# MITW50L6CX10, serial# TA4176718-130-131, 48 gal., gas, power vent. The vent is running constantly, and when the burner lights it burns erratically even going all the way out...
1) First suspects include Honeywell icon gas control valve, loose-or-bad wiring, and dirty burner parts.
2) MITW50L6CX10 blower number is 239-39785-00. Blower is working, but communication between blower and gas control valve are suspect.
Water heater has 6 year warranty
Water heater was manufactured January 1999.
http://www.bradfordwhite.com/findaserial.asp
3) Typical service manuals for M-1-TW-50 TTW series show how to test and replace Icon gas control.
Multimeter is required for testing.
Also shows how to clean burner parts and combustion chamber and air intake to catch up on regular maintenance.
http://www.bradfordwhite.com/images/shared/pdfs/manuals/46238-A.pdf
http://www.bradfordwhite.com/documentation/residential/gas.asp
4) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 09, 2011 | Fasco Bradford White Hot Water Heater...
My Honeywell Water Heater Thermostat will turn on for 30 seconds. Then it shuts down- wait 5 seconds turn it off EITHER with the ON/OFF switch OR by turning thermostat to off & back on immediately! If...
Time to call qualified service technician. And watch what that person does to learn about your water heater.
I assume you have Honeywell Icon gas valve. Honeywell makes different several model numbers.
Here is 'typical' Honeywell Icon gas valve service manual for Bradford White, that may or may not apply to your water heater. It shows testing for Icon and disassembly instructions, and error codes.
http://waterheatertimer.org/pdf/Bradford-white-service-manual-44943-D.pdf
Gas water heaters today require yearly service that includes cleaning burner parts and combustion chamber, checking vent and air intake, electrical connections, testing gas valve, checking gas pressure, bleeding air out of gas line, etc. These are things you can learn to do by reading service manual, and making sure you have a spare water heater around to connect real quick if experiment goes wrong.
If Icon gas valve is problem, that control is modular and can be replaced without draining tank.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 07, 2011 | Honeywell Water Heaters
I have a GPVH 40 100 AO smith hot water heater.The FV (flammable vapor) sensor has been setoff from us painting the floor yesterday. How do I reset the unit?
AO smith manuals
http://www.hotwater.com/lit/im/r-gas.html
GPVH series manual
http://www.hotwater.com/lit/im/res_gas/315465-000.pdf
You can search the manual for FV
The FV sensor shorted because it detected flammable gas
Quote manual:
Flammable liquids (such as
gasoline, solvents, propane (LP or butane, etc.) and other substances
(such as adhesives, etc.) emit flammable vapors which can be ignited
by a gas water heater's hot surface igniter or main burner. The
resulting flashback and fire can cause death or serious burns to anyone
in the area. This water is equipped with a FV sensor for detecting the
presence of flammable vapors, see Figure 3. When the sensor detects
those vapors, the unit will shut down and not operate. Should this
happen, please refer to the troubleshooting guide on pages 28-30.
Troubleshoot step 14-15 says
replace the FV sensor
call tech assistance number that shows on water heater
AO Smith will refer you to a plumber
I don't believe homeowner can buy these parts due to Federal regulations
The shorted FV sensor probably saved you a flash-over
The cost of 2nd degree burns from a flash-over would be astronomical.
Fortunately you're ok, and the other folk in the room are ok.
In the old days.
Two guys I knew, winter 1978 Chicago, were laying VA tile using the black mastic.
They were killed and the house burned down because of the water heater.
Main office marked the event with a memo saying they still owed money on their account.
The only company with a re-settable FVIR that I'm aware right now is Bradford White
http://www.thetankatwaterheaterrescue.com/forums/forum3/2679.html
http://411plumb.com/bradford-white-defender-water-heater-review
Bradford White Defender FVIR is resettable without buying parts.
Oct 24, 2010 | Water Heaters
Noisy water heater blower
It may just need a new pump coupling. Fairly inexpensive. I don't think you need to replace the whole burner.
Feb 14, 2009 | Fasco Bradford White Hot Water Heater...
Water Heaters Logo
279 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
