Question about Fuji Road Bike Saddle/embroidery/chromoly Rail
I am looking for a parts diagram for a 2008 Fuji Roubiax - mainly the fork and bearing assembly.
    Genius:
  • 1,788 Answers
If, it was me, I would take it to a dealer and let them adjust or rebuild it. If, you do not have the right tools you can do more damage than good. See it all of the time.
Posted on Aug 15, 2010
Diagram of a 4 wheel drive Silverado 2008
The easiest way is to go to a parts store. They will print off one specifically for your vehicle.
Feb 27, 2015 | 2008-2012 Chevy Silverado 1500 4WD Front...
How do i replace a clutch on a 2008 scion xb
There is a video about this on line
I would suggest that you get a paperback repair manual like a Haynes to help you if you do it yourself. Or sign up at Autozone.com and see if they have any downloadable free guides specific to XBs. Autozone won't spam you for signing up.
Feb 07, 2015 | 2008 Scion Xb
Honda Activa's fork assembly diagram
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Honda Activa fork assembly diagram Google Search
07 Front fork disassembly
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda activa 2009 Owner Manual
Mar 28, 2013 | 2005 Honda Activa
Getting forks off a ZRA to change bearings - when the fork will not pull off
Matt,
The assembly diagrams for the various forks and bearings can be found at this link:
http://estore.tilite.com/ecommerce/CatalogSubCategoryDisplay.aspx?CID=1011
There are hidden screws and bolts for some of their assemblies. Hope this helps.
May 04, 2011 | Tilite ZRa Titanium Wheelchair
I have a 954 that is wrecked and needs forks from what im told is that there is no difference in the 929 fork and the 954 forks is this true
It probably is true. Honda makes the same part for many bikes, bearings, etc. Go to Babbittsonline.com and compare part numbers of the steering stem on both bikes. Go to online microfiche, or parts diagrams and compare front ends with part #s. If the bearings are the same and steering stem is the same it will fit. Check the handle bars too. Chaz Moto DC
Feb 25, 2010 | 2002 Honda CBR 954 RR Fireblade
I need to know how to dis/reassemble a 1974 DT 360?
A service manual ( if you can find one ) is what you need. The second thing you need is repair parts. They are pretty hard to find. Babbitt's, a well known distributor, only has parts left in stock for the top end. Go to their website, www.babbittsonline.com/parts/viewbybrand/parts.aspx
and you can see what is left. There's also a diagram of the crankcase center halves. If you can't get the repair parts, spending hours doing an engine teardown is fruitless.
The teardown will require a flywheel puller, a case splitter, an impact driver, and a torque wrench (somewhat optional). Disassemble the top end then remove the left and right side case covers. Remove the flywheel and related electrics, the clutch, crankshaft drive gear, oil pump, kick starter, shift shaft assembly, shift drum end cap and index pins. Now remove the screws on the center case and you can then split the case. This gives you access to replace shift forks, gears, and bearings. Note that crank seals can be replaced without splitting the case.
I am not trying to be a smart *** here, but re-assembly is just the reverse of dis-assembly. This is why a manual would help. Another potential source for parts is to Google motorcycle salvage yamaha .
The normal things you would need to replace inside the center case would be bent shift forks (if shifting is the problem), busted gears, crank bearings and seals, and sprocket shaft bearing and seal. All else can be replaced by removing just the side covers.
Dec 10, 2009 | 1974 Yamaha DT 360
Pull to left even when just rolling, no damage that i can see
Bad, mismatched, improper tires, Wheel bearings, wheel bearing preload adjustment steering head bearings, steering head preload adjustment. misaligned wheels swing arm bushings or bearings, swing arm bearing preload, worn defective shock, bent frame, rims. forks. misaligned forks. fork stiction.
Prevention is in making all above are correct., a steering damper won't fix it, it will only hide the problem!!!
Oct 31, 2009 | 2008 Suzuki B-king
I'm restoring my classic s10s and am trying to lube the front bearings on the fork. The normal lock nut is some sort of notched part that looks like it takes a spanner type wrench and my local bike shop...
While not ideal this did work. I stabilized the fork and use a nail set and hammer to lightly tap the lock nut loose. Replacing was the same...light taps.
Sep 03, 2009 | Fuji Cycling
Amoroso twin baby stroller
dcseal,
I found their webpage today: http://amorosoenterprise.com/index.html
Best of luck,
Michael from Boston
May 06, 2008 | Amoroso 3236A- Red Jogger Stroller
Fuji Road Bike Saddle/embroidery/chromoly Rail Logo
293 people viewed this question
Top Fuji Cycling Experts
sharky633
sharky633
dante
Donald Ayers-Marsh
Are you a Fuji Cycling Expert? Answer questions, earn points and help others
