Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
How do I unlock my weed eater? My son didn't put
How do I unlock my weed eater? My son didn't put mixer in it.
KMusselmann
  • 247 Answers
SOURCE: starter rope on bv2000 weed eater blower needs to be replaced.
Hi, Try the following, But make dure you can wind the spring. If not the spring is broken.
Kurt
This usually happens at the most inopportune time. You go out mow the lawn, pull the rope and it comes out in your hand. Here's how to fix it yourself.
First, we'll talk about a simple rope replacement. In most cases you will have to remove the blower housing from the engine to get to the underside of the rewind starter where the rope is. We'll assume at this point that the spring is ok and you can just wind it back up again. You can check the spring by turning on the hub in a counter-clockwise direction and see if the spring gains tension. Do not try to remove the spring from its holder or you may end up having to take the mower in for service.
1. Remove the rope from around the hub. Since there is no tension, it should come right out. If you are lucky and it broke near one end, you can probably just re-use it. If it is badly frayed or too short, you will need to find a replacement at a local hardware store.
2. Attach the handle or tie a knot in one end of the rope so it will not wind all the way into the hub. You also may want to burn the rope ends to keep them from fraying and causing a problem in the future. Set the rope aside where you can grab it once you wind up the spring.
3. Wind the hub in a counter-clockwise direction using your thumb to keep it from unwinding, until the spring is tight. Then let it come back slightly so the rope hole in the starter housing lines up with the rope hole in the hub.
4. Stick the rope through both holes while holding the hub from unwinding. This is tricky because you don't want the hub to unwind on you before you have the rope secured in it. A pair of needle nose pliers or a small screwdriver or pick may help get the rope through.
5. Tie a half hitch knot in the rope after you have it through both holes. While holding the rope, release your hold on the hub and let the rope slowly pull itself back into the starter.
6. Put the blower housing back on and your ready to start the engine & mow.
Posted on Mar 23, 2009
bulldogchief
  • 388 Answers
SOURCE: Can't get weed eater started. Have an older weed
This is a common problem on older Poulan models. Press the primer button 10 times and pull the starter rope twice, then pull the spark plug and examine it. If the plug is wet that means gas is definitely getting to the combustion chamber. Next thing is to use a compression tester. If you do not have a compression tester but have an AutoZone anywhere near you, you can get a loaner from them. Screw the compression tester into the plug hole and pull the start rope 4 times. If the tester reads anything below 90psi, you have a bad ring and will have to take the motor apart to clean the piston and ring or replace the ring.
Keep me posted on what you find, ok? I can walk you through the procedure to replace the ring if necessary. Good Luck!
Posted on Sep 17, 2009
Testimonial: "thanks...I will give it a try and keep you posted"
wadembly
  • 513 Answers
SOURCE: Powerpro 17" McCollich weed eater
hey harry the float inside the carb is stuck i would suggest rebuilding the carb
Posted on Jun 28, 2010
suzukiracing
  • 200 Answers
SOURCE: my weed eater starts but won't stay running. what
Try a new spark plug.Thanks for asking and I hope it helps
Posted on Jul 21, 2010
  • 63 Answers
SOURCE: My poulan gas weed eater won't start. It has gas.
Check spark plug and H T lead then the air filter
Posted on Jul 24, 2010
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Ss30 ryobi weed eater fuel ratio
    I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
    Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
    How do I remove the spoolhead so as to afix the pivotrim head
    I installed the Pivo trim head yesterday. The info that came with the unit will show you how to install it on ANY Weed Eater Unit. Also they have videos on their web site at: https://pivotrim.com/
    Look on the end of the shaft of your weed eater at the head. Mine was a 25cc Poulan/weed eater SST45 and it has a hole that you need to stick a HEX KEY in so the shaft does not move when you try to remove it. ALSO it has a BACKWARDS THREAD!!! So "Right is NOT Tight." Left is to tighten and turn towards the right to get the head to unscrew so you can put on the Pivotrim Head. Also you can use ANY Weed Eater line on the unit. As I tried several different lines and found different uses for different lines. Such as edging and trimming against fences. Best after Market Weed Eater head I have EVER used. :-)
    Enjoy! :-D
    Jul 28, 2011 | Craftsman 25cc Gas Line Trimmer
    What ratio of oil and gas do I mix together? How do you start it? I bought the weed eater used.
    If you bought it used, you can bet that they didn't run it out of fuel before they stored it, so the gas evapoated out of the carb and all that was left was oil, so mix your fuel 8 to one eight parts gas and one part oil, you'll have to hit the primer botton several times.
    Jun 16, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
    Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
    I have weed eater model FX26SC it starts and when I put it to run the weed eater doesn't spin but is running
    Either the clutch is worn out or the flexible drive shaft is broken. Either repair is likely to cost almost as much as a new unit.
    May 16, 2010 | Garden
    Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
    207 people viewed this question
    Top Poulan Garden Experts
    Jim Parker
    Jim Parker
    Phil Walker
    Phil Walker
    Are you a Poulan Garden Expert? Answer questions, earn points and help others
