Question about Kenmore Dryers
Kenmore 110.63022101 (Whirlpool) electric dryer, seven years old. When I push the ''Start'' button, there is a faint ticking sound but the dryer does not start. I've checked the door switch and the belt. Both work as expected. What next?
    Genius:
  • 1,122 Answers
Check the start switch with a meter,ohm it out
Posted on May 03, 2010
Whirlpool electric dryer will not start when start knob is pushed
First check beaker flip it off than back on next check the door switch if tab missing or loose it should spring back when pressed next the dryer may have over heated the thermal fuse may have blown
Nov 03, 2015 | Whirlpool LER4634J Electric Dryer
Kenmore 70 series model 97576200
You have a bad thermal fuse , usually caused by lint blockage from the filter or vent hose .
Jul 06, 2009 | Kenmore 659 Electric Dryer
Start button doesn't work properly
Hi, You have a motor going bad. The start winding is out on it.
The motor will need replaced.
Vic
Jun 25, 2009 | Kenmore 659 Electric Dryer
Kenmore dryer not running
Ticking sound is the timer running--so it is not the problem unless a contact has failed or a wire has come loose.  Broken door switch, thermostat failed in open position, or clogged lint filter/exhaust vent/outlet would keep unit from running.  If you can hear the motor running but the drum is not turning then the drum belt is broken.
Jun 04, 2009 | Dryers
Stops running and/or won't start
sounds like the little control board in the console either two screws on right and left side and lift up console or the screws could be on the backside there will also be a tech sheet in there to coach you thru diagnostics
May 11, 2009 | Dryers
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Whirlpool Estate Dryer won't work
the thermal fuse on the back is probably out the humming is from the timer tale off the back panel and look for somthing that looks like this and test it for ohms http://us.st12.yimg.com/us.st.yimg.com/I/yhst-39356578169075_2030_2317267 it should read 0
Dec 09, 2008 | Whirlpool LER4634J Electric Dryer
Kenmore Dryer Model 66801692
at leas 15 yrs old??? think it's done its time, its a great machine andwould reccomend replacing with a whirlpool/kenmore unit again.no tworth servicing in my opinion, average call here in new york 150-225, anbd those are for simple issues. id rather put money into new unit! bit be sure to check your venting id say 85% of dryers taking too long to dry are vent related issues
Nov 13, 2008 | Kenmore 62872 Electric Dryer
Dryers Logo
247 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
