Question about Maytag Performa PAV2200
The water keeps running but drains out immediatly.
    President:
  • 949 Answers
Hi, It sounds like siphoning. Here is a link that should help you.
http://www.fixya.com/support/r4621172-clothes_washer_stop_filling_water
Posted on May 03, 2010
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
It seems to run but it not running a full cycle and does not let water poor into the machine
have u checked the water valve in the rear u can do this by seeing if you have power to the water valve using a multi meter also i have seen on a few models such that they have these small screens inside of the water valve that are removeable and if there is any sediment inside of these the water will never hit the drum it goes into the machine and out the drain immediatly never hitting the tub so check both of these thing hope this helps
Jul 21, 2010 | Frigidaire ATF6000ES Front Load Washer
Prewash drains into washer before starting washer
Check the tray before you fill the powder. There should not be any water. Once you switch it will drain along the water when water is showered inside the tray.
Apr 01, 2010 | Samsung WF448AA Washer
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Was ''F35'' now its ''F21''
F21 is drain problem.
Try tripping circuit breaker to reset the appliance.
The next step will be undoing the drain pump hose to check for a blockage.
the pump is accessed removing a panel, usually at the front side of the machine.
Steps are explained on user manual.
Keep a container ready to collect water when you undo pump hose.
Parts and diagrams available here.
Nov 14, 2009 | Kenmore Washing Machines
7KG WD-8050FH LG Clean Master Front Loader (5 stars) No Drain ....won't drain or spin
I had same problem and i have opened the the water pump and found some tissues blocked the fan from spining , i remove it and immediatly worked .
Jul 14, 2008 | Washing Machines
Kenmore ultra wash dishwasher
is the water draining out by itself? or is it getting pumped out by the machine? if this is a ge built machine it sounds like the drain solenoid is burned out and the unit is stuck in drain. a bad timer usually makes that happen so you might need the timer and solenoid
May 07, 2008 | Dishwashers
Wont run properly
make sure sure outlet hose is high up 24 inchs
Nov 24, 2007 | Bosch WFMC 3200 Front Load Washer
F21 Drain Problem with empty washer
Please see what I (royale) have done with my problem.
May 06, 2007 | Kenmore 46462 Front Load Washer
Washing Machines Logo
53 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
