Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Won't start,the battery needle goes (-) when the key is turn to start
Can you hear the Solenoid click when to try to start? If not, I had the same problem it was the Solenoid. Sears insisted it must be the battery even though it was weak but not dead. Replaced the battery but it still would not work. Replaced the Solenoid and did the trick.
Posted on May 21, 2010
    Problem Solver:
  • 16 Answers
Sounds like you have a bad battery.
Posted on May 07, 2010
Automotive electrical problem
Daniel, If battery is known to be good, could be bad connections at battery, starter/solenoid, or ground on engine/frame, battery cables also could be bad with build up of corrosion internally. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Engine Won Crank or Start
Diagnostic flowchart for car that won start or stalls Troubleshooting for...
No Crank No Start Diagnosis EricTheCarGuy
Aug 21, 2016 | 1988 Ford F 150
2005 ford 500, won't start a lock light is
need to reprogram ignition key security system when battery disconnected. turn ignition key to the on position for 3 to 10 seconds until the lock light goes out then start vechicle.if lock light dont turn off turn ignition switch to on position 30 seconds until lock light turn off.
Jun 12, 2013 | Cars & Trucks
Car Won't Work. HELP!!!
did you check battery could be death.Gas pedal is moving,under steering wheel any wires damaged.It is full park position.
Apr 30, 2013 | 2002 Pontiac Grand Prix
Won't start battery is ok.
REmove the starter for checking . IT may require a new solenoid or you may have a dead bar in the commutator which will require a new starter.. This is evidenced by sometimes you can start easy and other time the solenoid clicks every time you turn the key and then suddenly starts. IT comes from the armature stopping with the daed bar under a brush and when it turns just enough to touch another bar away it goes
Mar 09, 2013 | 2003 Chevrolet Silverado 1500
2007 Dodge Caravan won't start.Batt. is good, all lights work, Turn key, solenoid clicks and stops, all gauge needles slowly move to max., and return to min. No codes displayed.
When you try to start it do the lights dim way low, have you been able to start it with a jump from another vehicle, unfortunately, chances are the starter needs to be replaced. How many miles does it have?
Feb 09, 2013 | 2007 Dodge Grand Caravan SXT Minivan
2007 is250 battery died, then was fully chared, now the car isn't detecting the key and won't start
all new cars are set up that if the battery deads it goes into lockout mode. it is so the dealer ships can make money
Dec 16, 2012 | 2007 Lexus IS 250
Starter making whirring noise.
When you say it won't start you mean it won't crank, right ?
If you have a duralast starter from auto zone, that may be the problem.
Aftermarket brand starters and alternators can be lemons sometimes.
A mechanic would check for voltage at the starter with the key in the on and start positions. Also check the ground connections.
Its possible the starter is not getting full battery voltage for some reason.
Jul 31, 2012 | Jeep Cars & Trucks
It won't turn over
Try this procedure:
Check the battery like this:
Turn on the headlights, then try to start the car.
If the headlights do not dim or go out, then the battery is likely ok.
Check that the battery cable plus post, goes to the starter, Minus post to a good ground, like the engine.
If wiring is ok, then look at the starter solenoid for a good connection, and proper voltage at the starter.
Problem is most likely the Solenoid's bendix gear or starting relay, Have someone bang on the starter while you try to start the car. This usually works by dislodging the bendix gear..
Hope this helps.
Jul 27, 2012 | 1994 Oldsmobile Cutlass Ciera
The needles on the battery gage will not go back
you have a short running into your cluster wiring
Feb 25, 2010 | 2003 GMC Envoy
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
135 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
