Question about Kodak Easyshare 1725043 M893Is Digital Camera
My lens on my kodak 8.1 does not come out when i turn it on also when i tried to charge it it was not charging itkept on turning back off when i would turn it on . whats the problem
    President:
  • 2,761 Answers
If you've recently dropped the camera you may have lens damage that is preventing the camera from powering up. That problem will require professional attention, but try these fixes first.
If you battery is more than a year old, chances are that it needs to be replaced -- especially if the camera has not seen regular use.
Check the contacts on the battery and inside the camera's battery compartment for corrosion. Even if you don't see any, wipe the contacts firmly with a clean dry cloth, replace the battery, and then try charging again. If you see heavy corrosion, you may need to clean it with a fine wire brush, steel wool, or sandpaper. If you do the heavy cleaning, be sure to remove any residue from the compartment before installing the batteries.
If the battery fix and replacement don't work, I suggest that you take the camera to a Kodak dealer (NOT the camera department at a chain store) and also check online at www.Kodak.com to arrange professional repair. Be sure to get a firm price, not just an estimate, before you commit. The cost of a fix can approach the price of a new camera, and repairs typically only carry a 30-day warranty. Also, beware of Kodak's trade-in offers. You can often find a new or factory refurbished (full warranty) camera on eBay for less than the trade-in price - and keep your old one for parts.
HINT: Always remove the battery if your camera will be used for a week or more. Doing so will extend the life of the battery and prevent potential camera damage.
Bill B
Posted on May 03, 2010
My camera will not stay on is off and stuck with lens out
If the lens doesn't retract on most digital camera the camera also will not turn ON. It is connection or wiring between camera power and camera lens.
What Kodak Rep will ask you to do are:
1. Remove the battery and the memory card of the camera
2. Check if your using a recommended battery and if its new or fully charge. batteries for Z1275 are Ni-MH rechargeable; CRV3 Lithium; 2AA Lithium
3. Insert the batteries back in the camera in correctly
4. Set the camera in Auto mode (its the camera icon on the dialing mode of the camera)
5. Try to turn it ON
If still will not turn ON and the lens will not retract
6. If your using a rechargeable battery Kodak Rep will ask you to charge the battery until its fully charge.
If your using a disposable battery they will ask you to try to use a new battery out from the box.
After all those steps still the camera failed to work, it will be send for repair. The number of the Kodak support line is 1 800 235 6325 (23KODAK)
Nov 20, 2009 | Kodak EasyShare Z1275 Digital Camera
Camara shuts off as soon as it turns on. Lens
I believed that you are using the battery came from the box the KLIC-7004 which is very good. Now since the battery indicates its charge, first thing you need to do is to removed the battery and Memory card, Now wipe the 3 metal contacts of your battery then reinsert only the battery in your camera then Turn It On. If the camera shuts off try to used 5V AC adaptor to Turn On the camera, If this failed to turn On using the AC adaptor It means the camera needs of service call Kodak Tech support toll free 1 800 421 6699 ext 12
Nov 09, 2009 | Kodak EasyShare M1033 Digital Camera
Camera turns on then off immediately
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 04, 2009 | Kodak Easyshare M893 Digital Camera
My camera wont turn on and lens stays out
are you using the battery that came from the box KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7001
first charged the battery for 4hrs and make sure when you charge it theres a light indicator in the camera., you may also try to turn On the camera while its charging in a AC adaptor., If its did the same thing call kodak toll free 1 800 235 6325. it means the camera gear lens is already defective thats why your camera will not stay On
Oct 31, 2009 | Kodak EASYSHARE M1063 Digital Camera
I am able to transfer images to my computer, but when I try to turn the M893 camera on when it's not connected to my laptop, the screen comes on for a second or two, lens comes out, green light is on and...
It has problem on the lens. Lens doesn't extend when transferring pictures that's why it works. Kodak cameras are designed to automatically shut-off when the lens is struggling to go in or out.
Follow step-by-step solution and repair on www.kodak.com/go/stepbystep if the guide did not resolve the issue proceed processing the camera for repair under the same website if it is still under in-warranty otherwise call Kodak @ 1800-235-6325 extn 1-12-2
1-English
12-Camera Dept.
2-Hardware and service dept.
Lester
Kodak Technical Support
Oct 04, 2009 | Kodak Easyshare M893 Digital Camera
My camera turns on then turns back off right away!
Hi Most proberly the batery is shot. It wil be fully charged but it does not have "the amps" in this case miliamps to do the job. Pushing out the lens uses alot of the amps "miliamps" and the fact that it can't even rectract the lens back is a sure sign. If possible take the camera to a digital shop and test it with a known good batery!
Strongs
Aug 16, 2009 | Kodak EasyShare M863 Digital Camera
Kodak v803 wont turn on
i had the same problem, if you try to turn the lens in as if you turning a dile, the lens will go back in manually once you have the lens completly in again, as if the camera is switched off, then turn the camera back on at the power button and the camera will operate as normal, this worked for me i hope it works for you too.
Jul 28, 2009 | Kodak V803 Digital Camera
Won't turn on after charging; lens just sticks out
Charge it again with a new batery and the 5 volt charger.
3 hours.
Vitally
Apr 21, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak Easyshare 1725043 M893Is Digital Camera  Logo
120 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
