Question about Siemens WTXD8300 Electric Dryer
My dryier stopped working soem time ago for no apparent reason, recently when we trried again we got, orange flashing lights and a F 11 on the display screen, Anybody got any ideas what this means
  • Siemens Master
  • 43,501 Answers
If you have a gas dryermy dryier stopped working soem time ago for no - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If yourmy dryier stopped working soem time ago for no - 2_bing.gifelectric2_bing.gif..
There could be a number of different problems...
Check out this tip my dryier stopped working soem time ago for no - 2_bing.gifte about this problem...
Dryer Troubleshootingmy dryier stopped working soem time ago for no - 2_bing.gifhttp://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 06, 2010
I have a flashing orange light and cant find the manual, I have changed the inks but its still flashing?
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 02, 2010 | Canon Office Equipment & Supplies
Power button flashing on and off. Maintanence light is on and there is an E, 2, and 4 flashing in the print screen. What do I do? Pleas help!
MP160 resetting errors
button pressing
procedures below.
procedures below.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 20, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I70 wont print & Printer Head won't return to the centre
The first error was waste ink near full which you can bypass with resume button, now the absorber is full which means it won't print until you have the drain pack replaced and the counter reset by a shop.
Aug 01, 2009 | Cannon i70 Printer
Plantronics cs70 nc stop working
Make sure that the power is connected to the headset.  You can tell it's connected because there will be a red solid light on the left side of the front of the charging base.  Check the power cord for any frays and make sure it's plugged into the wall.  If it is, then try the following:
A system reset:
1.  Lift the headset off of the base. 2.  Make sure the headset is turned off.  The green light will not be on on the base. 3.  Hold down the minus button at the same time as the call answer button on the headset.  Hold them down for at least 10 seconds.  An orange light on the headset will flash several times.  It should go off when you let go of the buttons.  If the orange light stays solid, push the minus button once. 4.  Put the headset back in the charging cradle.  Leave it for 30 seconds.  Lift it back out of the cradle and try using it again.
Oct 01, 2008 | Plantronics CS70 Wireless Headset
Sidekick ID.
try a friends battery if that doesnt work then dont buy a battery and sometimes reseting the phone may work like turn the screen to 90 degress and put an earing or pin inside the reset whole
Mar 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Canon ip4000 flashing 12 times
For 11 orange flashes (Canon doesn't list 12) Canon says its an automatic print head alignment error: -make sure ink tanks are snapped in correctly http://www.usa.canon.com/consumer/controller?act=SuprtKnowledgeBaseAct&fcategoryid=184&modelid=10438 -place 8.5 x 11 paper in the automatic sheet feeder, anything smaller will cause this error. -Remove the printer from strong light; apparently a sensor in the paper output slot can be affected. -Also you said you replaced all the cartridges with new ones, were the new from HP? If not I would definitely try replacing them all.
Jul 21, 2007 | Canon PIXMA iP4000R InkJet Printer
Dryers Logo
219 people viewed this question
Top Siemens Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Craig Butler
Craig Butler
Are you a Siemens Dryer Expert? Answer questions, earn points and help others
