Question about Sony Handycam DCR-TRV250E Digital Camcorder
Recording when I turn the camera on to record using the lens there is just a blank screen.
  • the3ayers Jun 21, 2008
    records sound only. picture is blank .
  • Anonymous Jul 22, 2008
    Hi have the same problem where it shows a black screen in cmaera mode but it still plays the tape fine. Is this expensive to get fixed?
  • 10,594 Answers
Hello wonga49,
Your camera has problem of defective CCD Imager IC, and it will be available in nearest Sony repair shop.
Posted on May 28, 2008
What if suddenly i dropped my canon mini dv md140 . still can play in playback mode. but when i turn to camera . try to recording . the screen just blank . im afraid if the lens o any glassy thing b
Your camera is really damaged. For repair, the best thing is to contact a certified Canon repair centre. They can tell you if it can be repaired and how much this could cost. Then you can decide what to do, repair, or save for a new camera.
May 09, 2014 | Canon Computers & Internet
When I turn on the camera, nothing happens and the screen/view finder is blank. i checked the standby switch its off. when i press record it will record but on the tape it is just a black screen? any ideas...
i know exactly whats wrong! the same thing happend to me.
1. turn off the gl1 2.look at the record button with the lock and standby switch 3.flip the switch all the way to standby because it might be stuck in the middle 4. turn on your camera
Dec 03, 2009 | Canon GL1 Mini DV Digital Camcorder
My Sony DCR DVD 108 has no image at all with or with out disc says lens cap may be closed but it isnt flashing E:61:11 top right hand side of touch screen plays previously recorded dvd fine but thats it.
You may have lost your image sensor.
  1. Take lens cap off.
  2. Look in lens make sure there is nothing on or blocking lens.
  3. Find bright room & see if image comes up.
  4. Make sure your in video record mode.
  5. If you have eyepiece lens look to make sure it is off. {Most cams will not let you use both at same time.}
  6. Still no image try recording on blank disk then play back see if image is recording.
If that does not work MSG back.
Mar 07, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Blank Screen When Recording
hi, if you have an on screen display in camera mode you should check into the lens to see if your shutter or iris is opening.
Jul 23, 2008 | Panasonic NV-GS17 Mini DV Digital...
Sony handycam DCR-HC20 Screen blank
i want driver of sony digital 8 ready shot camera
Jul 06, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
Nothing appears in view finder or on screen when recording
I HAD THIS PROBLEM ERROR CODE C31 : 22 WOULD COME UP AND TRV 118 CAM WOULD NOT WORK. I TRIED EVERYTHING TILL ONE DAY I BANGED IT ON A CARPETED FLOOR ON THE BOTTOM OF THE CAMCORDER 5 TIMES QUITE HARD. THEN THE CAM WORKED JUST FINE! MY CAM HADN'T WORKED FOR OVER 7 MONTHS. NOW I HAVE IT BACK. HOPE THIS HELPS SOMEONE.
Jun 18, 2008 | Video Cameras
Records audio but no video
Replace the ccd base assumbly and check.
Jan 01, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Lens cover not open and blank screen
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor..i know it is free for replacing that sensor cause that is one of the model that sony recall produc and the cover not open error message is a poor contact of the lens cover switch...
Sep 09, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Images can't show on the screen
first check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor....go to a sony service center for replacing that...i know it is free for replacing that sensor cause that is the recall product not only on sony but in other brand because the manufacturer of their sensor is only one company...
May 09, 2007 | Sony TRV-285 Digital-8 Digital Camcorder
Sony Handycam DCR-TRV250E Digital Camcorder Logo
65 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
