Question about RIM BlackBerry Curve 8310 Smartphone
My blackberry doesnt ring and goes right to voicemail
  • 270 Answers
Hello
You have to unlock that BB first
This unlock code provider generate full LEGAL unlock code direct from Blackberry server which wont void your warranty, & generate code based on your IMEI, means individual code for every blackberry set.
After unlocking from this provider's code your blackberry not only work with single network, you can use your Blackberry in any part of world with any network including your browser & MMS picture messaging to work, yes with just one time entering code from your keypad.
They unlock from network who locked your blackberry
This site will help you a lot & good email & 24/7 phone support
http://blackberryimeiunlockcodes.com
Posted on May 12, 2010
Why does my driod go right to voicemail
It could be that the phone is delayed in ringing. Try placing a test call and see how many times it rings in the phone you are calling from before it rings on the phone. Then you can determine if the phone is delayed in ringing. If you hear ringing and the phone rings once and then it goes to voicemail then there may be a setting on your phone that is causing this.
Mark
Motorola Support
Jun 01, 2014 | Motorola Mobility DROID RAZR Maxx 4G...
Phone doesnt ring, it goes straight to voicemail
Hii pls chk for all saved contacts, the option "send calls directly to voicemail" is unchecked.
and also verify that the following are unchecked under: Call Settings-->Call forwarding
1-Forward when busy
2-Forward when unanswered
3-Forward when unreachable
If the problem still occurs contact your customer care executive.
Jun 07, 2012 | HTC Status
Blackberry phone goes right to voicemail
did you try the menu and settings, some cell phones you can set your phone to go directly to voicemail?
Apr 20, 2012 | RIM BlackBerry Bold 9000 Smartphone
NEED HELP SETTING VOICEMAIL.TRACKBALL IS STUCK, GOES LEFT,RIGHT,& DOWN,NO UP.NEED INSTRUCTION MANUAL.
You can download the user manual (as well as other guides) here:
http://docs.blackberry.com/en/smartphone_users/subcategories/?userType=1&category=BlackBerry+Smartphones&subCategory=BlackBerry+Tour+9600+Series
If the trackball won't go in one direction, try putting one drop of denatured alcohol onto the trackball and then moving it all around, that should fix it. If it doesn't, lift the trackball up slightly -- very gently -- with the blade of a small pocket knife and blow compressed air underneath it.
Jan 22, 2011 | RIM BlackBerry? Tour 9630 Smartphone
Phone only rings twice then goes to voicemail. How do I change settings to allow longer before going to voicemail?
You need to contact your carrier, ask customer service if they will change the ring time. The number of rings before vaoicemail is not controlled by the phone it is set at the cell phone switching office so they have to do it. Some carriers will some won't.
Good luck,
Buddy
Corporate Computer
WWW.CCL-LA.COM
Jul 10, 2009 | RIM BlackBerry Pearl 8100
I have the same problem. Any ideas??
Hi, the setting is controlled by your mobile service provider. You will need to ring them and get them to extend the time which it will ring before going to your voicemail. Another option is to totally disable the voicemail function. On your blackberry, enter the phone screen, then press the blackberry logo button to open the menu then select options. Once in the options, select the call forwarding option. Change all settings to "do not forward". Please rate this solution if it helps. Thanks
Jun 08, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Phone rings once, then goes to voicemail
Yes, turn off call forwarding or set up longer delay. at least 15 sec.
Apr 14, 2009 | Sanyo MM-8300
Call forwarding only rings once
You will have to have the admin lengthen the voicemail answer time, i would add another 15-20 seconds.....but this will make all calls ring your phone longer before going to vociemail
Mar 09, 2009 | Avaya 5400 Series 5410 Phone
Length of time phone rings with incoming calls
get your mailbox number then type in **61*44then mailbox mumber*11*then a two digit number between 00 and 30 (seconds delay).
Feb 19, 2008 | RIM BlackBerry 8800 Smartphone
RIM BlackBerry Curve 8310 Smartphone Logo
82 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
