Question about Kenmore Refrigerators
2001 Kenmore side-by-side model 106.52769100 filter housing leak
Kenmore side-by-side model 106.52769100. (year 2001) Water is leaking from back of the the water filter housing, where the 2 hose lines connect. Can I replace this myself? How?
4 Suggested Answers
  • 126 Answers
SOURCE: kenmore refrigerator leaking at water filter
make sure old gasket came of with old filter or make sure it is real tight you should have got a wrench with the refrig.
Posted on Dec 14, 2007
SOURCE: kenmore coldspot model 106: top freezer leaks
Have you tried adjusting the freezer temperature to a higher level? This worked for my Kenmore. It will take a couple of days to quit leaking.
Posted on Dec 19, 2010
imufo2
  • 3773 Answers
SOURCE: Kenmore side by side ref
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 12, 2011
My 2004 Kenmore leaks water at the water filter housing. I put a new filter in but when I wish to get water it overflows at thde top.
Fist issue, plumbers putty should not be used on any water connection for potable (drinking) water, use Teflon tale if you need to. If the leak is at the housing most likely the housing is bad, replace it.
Feb 05, 2015 | Kenmore Refrigerators
Water leaking from hose on water filter housing
shut water off to ref and try cutting the end of the tube off, but only 1/8 to 1/4 of an inch.. insert back into housing firmly and turn water back on and see if leak stopped.... if still leaking order and replace the filter housing..... hope this helps....... ken
Oct 09, 2014 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Kenmore refrigerator water filter bypass
That is a tough one. You can remove the water hoses from the housing but it won't be easy. Unless the housing itself is broken I don't think I would recommend bypassing it. Now if you really do want to go this route, here's how I would do it.
1) Turn off the supply
2) Carefully remove both lines from housing
3) Using the proper fittings, splice enough line so that you can position the new inline filter at the rear of the unit.
4) Attach the proper quick connect fittings to the new lines.
5) Install the new inline filter .(You may wish to secure the new assembly to the back of the unit)
6) Turn supply back on and check for leaks
As far as which filter, there are many to choose from. I would just get an inexpensive, inline filter made for ice makers. just be sure you get the correct quick connect ends for your new installation.
You can also purchase a complete kit which comes with mounting hardware, a filter and everything you need. This won't be inline though. It will be a separate housing which you will just mount remotely.
Good Luck!
Feb 02, 2014 | Refrigerators
Kenmore side by side ref model #58582891 water line leaking in bottom front of refrigerator, replaced the filter housing, stopped the leak that went into the drip pan. Water drips in front when push the...
Leo Ponder
imufo2
Aug 11, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Water is leaking out of filter housing does this mean its time to change the filter
no it's probably the o-ring seal at the housing. i would try taking it out inspecting the seal and replace if needed. if not i would put it back on and make sure the housing is on tight and it should seal off.
Aug 31, 2010 | Kenmore 53632 / 53634 Side by Side...
Refrigerator gushing water through ice maker filter
Filters themselves don't usually leak. Check full insertion of filter, cracked filter housing or cracked supply line.
Aug 14, 2009 | Whirlpool Refrigerators
Leak at filter
Nope. You can't bypass the tube style filter... it's the housing that cracked. That has to be removed and replaced. Sorry to give ya bad news, Mariner.
SG
May 30, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Water leaking
I guess it was water from drain lines, or leak from water lines.
Aug 01, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
Water leaking at filter
If this is a Pure source 2 filter in the upper right hand side of fridge, Purchase an Electrolux filter bypass, P/N 241944302. This is a empty cartridge that lets water flow without water drip when filter is clogged. Fridgidaire/Electrolux made no bypass in these filters, so when clogged they leak. Plus they NEVER last more than about 30/60 days. If you use the bypass, you will need a separate filter elsewhere such as in water line under sink or behind fridge. Call me at 816-560-8545 if you need more info.
Feb 26, 2008 | Refrigerators
Refrigerators Logo
42 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
