Question about Konica Minolta bizhub 350 All-In-One Laser Printer
I need to be able to install my bizhub c350 printer to my dell computer I do not know what to do my IPC # 192.168.2.155
    President:
  • 2,185 Answers
I supposed you might want to connect to the Bizhub using the network?
You need to connect to the server that the Bizhub is directly connected to. You need the IP address of that computer and the username and password to be able to connect. Click Start button and click RUN. Type in \\192.168.2.x (where x is the last number on the server's IP address).
If you have Vista, follow the steps in the link below which has illustration:
http://www.vista4beginners.com/How-to-install-network-printer
Hope this helps, goodluck!
Posted on May 03, 2010
Konica Minolta c350 printer driver install
You need a Ethernet cross over cable. plug that into computer the other in to copier
Feb 06, 2014 | Minolta Office Equipment & Supplies
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How to install the drivers for my Konica Minolta Bizhub C350 to my PC
Go here:
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productname=bizhub%20350
Pick set of software that matches your OS, such as windows XP.
Follow install instructions and the printer will show up in your PRINTERS AND FAXES control panel. You can then go into that and set the options you may have, such as the stapler/booklet maker.
You will need to know the printers IP address, such as 198.162.1.10
prior to running installer.
Mar 15, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Konica minolta bizhub c350 installer for mac
You have to have a fiery unit (external controler) to use the C350 With a Mac because the c350 dosnt come with appletalk in the software. IC-401 Is the model number of the controller you will need to connect the c350 to any kind of mac for printing / scanning.
Mar 14, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
May 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Bizhub Password Reset
Konica Bizhub c350 default password is 12345678 give that a try
Mar 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub C350 - Print spooler not running after power outage
I would print out a copy of the network configuation of that printer and ensure it has the proper network settings (I.E. IP address, Subnet mask and Default Gateway. I just worked on a printer that I accidently pull the plug on and it lost it's network settings and wouldn't print until I changed them back to the correct settings.
Good luck
Nov 11, 2008 | Minolta C350 Printer
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
113 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
