Question about Toshiba 19HLV87 19 in. LCD HDTV
Hi There - the DVD player does not recognize the
Hi There - the DVD player on my Toshiba Flat Screen TV does not recognize the DVD's - it pulls them in and tries to load them and then says "No Disc" - I've tried a few DVD's just to make sure. Any idea what the problem could be? I just received the TV and know that it has had very little wear and tear.
  • 321 Answers
You need to clean the laser lens
usely it solved the problem
hope that will help you..
Posted on May 03, 2010
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
Toshiba Dvd won't work properly with my new TV
if your old tv was an analog one you need a digital converter box to change to the new signal.. new tvs wont recognize the analog signal..temporarily you may be able to use your laptops' dics player as a player for your discs..
Jan 11, 2014 | Televison & Video
How to use the dvd player how to play a dvd how to get a picture
should be with the remote---whatever input on the rear the unit is connected to you have to switch the set to THAT input to see the DVD
Oct 31, 2012 | Televison & Video
My TV doesn't recognize my dvd player. The TV is new-panasonic viera TCP42GT25. The dvd player is a toshiba-less than a year old.
you shuld check the cable you are connecting. may be there is some fault that is restraining it from recognizing. if the cable is ok check whether the connections made are ok or not. if that too is perfect check for the connecting sockets. check in tv as well as dvd player. change the faulty socket. hope your problem will be solved.
Jan 30, 2011 | Panasonic VIERA TH-65PV500 65 in. Plasma...
A toshiba SD-37VSR DVD player that the TV will not recognize
if you are using the hdmi or DVI ports you need to make sure that both the player and tv are HDCP compliant (it will say on the box usually) otherwise, try using a different output from the player going into the tv. (try the composit or component instead of the digital outputs)
May 26, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Toshiba TV fails to recognize HDMI input
If the tv does all those symptoms but after some seconds the tv works and stays doing the job. THen the tv has a slow microprocessor to recognice the different resolutions or video inputs.
But if the tv cannot do anything and stay aout of signal forever. send the tv to the waranty. (no waranty? you have to use the component input instead to have digital signal reproduced
Apr 24, 2009 | Toshiba 40RV525U 40 in. LCD TV
Remove Base from Toshiba Regz 42RV530U
I bought this LG flat TV at Circuit City last week. TV is okay, but I was trying to hook up my portable DVD player and I can not make it work. I can hear the sound that coming out from the DVD but theres no picture from the screen. I believe my connection is correct, because there is the color coding which is red, yellow and white which you just connect at the back of the TV and at the DVD player.
Can anyone help me to figure out the problem. thanks a lot
Jan 31, 2009 | Toshiba REGZA 47HL167 TV
Jvc tv does not recognize toshiba dvd player sometimes....
Which cable type are you using (component, composite, HDMI...)? If it's composite (the white, red, yellow) it may be in "progressive scan" mode. Check the manual to see how to toggle betwixt the two.
Sep 10, 2007 | JVC AV-27530 27" TV
Toshiba 19HLV87 19 in. LCD HDTV Logo
146 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
