Question about Leviton Decora Light Dimmer Switch
Volex 1 way remote control switch LOAD SLAVE and LIVE two wires please help
Slave will not open with Master.
switch leads for master and slave to see if its a wiring issue. if the same gate fails to operate, it may not be your controller.
Jul 05, 2014 | Eagle 100 DC 1/2HP Swing Gate Operator w /...
Would like some troubleshooting help with a ceiling fan that the switch turns the light on/off but the remote won't control the fan. Can anyone help with wiring questions?
Is the remote control function an add-on to the fan, or is that built into the unit? If it's built in you'll want to go to the manufacturer on that one. As for wires in the wall, black is "usually" the 'live' wire, while white is the cold line. I'm no expert on wiring, but have done some outlets and light fixtures before. Good luck!
Dec 07, 2013 | Dryers
Wiring instructions are terrible. Ceiling wires = Red, Black, White, Copper. Fan wires = Black, White, Copper. Remote wires = Neutral in(Black), Live In(Black), Light out(White), Fan out(White),...
That is dificult to follow .. here is the usual wiring plan for ceiling fans .. green to green or bare and mounting bracket ... ceiling black and red are live from the switches, fan and light.with a remote you really only need one of these , so cap off the red and use the black as your input to the remote .. the neutral to the remote should be the white .. there are only 3 wires from the fan so I am assuming that there is no light , or the light will be activated from the remote .. the black for the fan and the black for the lights connect to marked wires on the remote. .. lights out, fan out
or looking at your description .. ((Remote wires = Neutral in(Black) white ceiling wire, Live In(Black) blaxck ceiling wire, Light out(White) blue Fan/Light wire, Fan out(White) black fan/light wire, Common(White) white ceiling and white fan/light wires.
May 21, 2010 | Hunter 27148 Remote Control
Am fitting new ceiling lights have 1 live 1 neutral 1 earth wire to connect . the ceiling connection has 2 live & 2 neutral wires as well as the connecting wires what do i do with spare wires do i wrap...
the 2 live wires are 1 for lights,1 for fan,keep them separate if you want control from 2 wall operated switches,if you only want control from the switches on the fan you can tie these together,as for the2 neutral wires they can be tied together at the fan box,and the 1 earth wire goes to the metallic surface ground screw on the unit
Feb 09, 2010 | Gb Electrical 100 Amp GE Load Center
My Daughter needs a timer placed on her front out side lights. I've puchased a GE 7 day digital timer. She has a plate with three switches ( left-right ) 1 switch, I haven't a clue what's it for ? Tried...
If you are in Australia, you are required by law to get a licenced electrician to do this work.
I cannot speak for other countries, but anything electrical behind a plate should be done by a qualified electrician.
If you are confused about the wiring, you are definitely not qualified. Either it is beyond your skill, or it was done in a non-standard way or before the current standards. Either way, please get someone qualified to fix it, for your own safety, and that of your family.
Dec 03, 2009 | GE RM24948 Remote Control
Tricity bendix aw1001w door lock wiring...
If you have multimeter and can use / 1 wire = live feed 1 wire is switch, 3rd is a netural idea is door lock gets 240 volt live netural feed energises the lock which in turn switches feed over to other connection..look at interlock to get idea what wire goes where....
Oct 31, 2009 | Tricity Bendix AW1000W Front Load Washer
Led light turns red and the turns off but the amp
In Car Amplifiers have 3 main power wires:
Live +12v (Fused wire direct from the + side of the cars battery)
Ground (Direct to car earthing point (anywhere cleaned of paint for good connection)(I tend to use boot lock)
Remote (This wire should be connected with the switched live wire coming from the back of the stereo, this is Only live when the cars ignition is on)(there should be 2 power wires coming from the stereo usually red live +12v and yellow switched live, depending on the cars original wiring, try moving the remote wire from where you have it, to the other live wire
Hope this is of some help
Aaron
Aug 08, 2009 | Nitro BMW-482 Car Audio Amplifier
Heath-zenith sl-6107 wiring diagram
hi there the wirings colour codes for nz are as follows
OLD WIRING CODE
Green = Earth
Black = Neutral
Red = Phase Or Live
NEW WIRING CODE
Green/Yellow = Earth
Blue = Neutral
Brown = Phase or Live
============DANGER 230VOLT ===============
Electricity can kill.
You should use an Electrical contractor for this repair job,
Caution always turn off power first before touching any wiring,
The Live wires always carry power,from one point to another,
the black neutral is your return path from the live phase wire
the green wire is always the ground ,
In this example
the sensor will have four wires as follows
Green = Earth Wire
Black = Neutral
Brown = Phase (incoming supply) 24 hrs
Red = Phase Load (outgoing supply) from sensor to lights triggered
Notice there are to phases in the circuit.Brown and Red
Always treat them as LIVE or Active Power.
Brown will normally be the Live incoming power and
Red will be the load side of the sensor,
Check the brochure supplied by manufactuers or their website to confirm the wiring order is correct before commencing any installs or repairs,
Always Safety first.
Safe a live today and you'll remembered forever.
Jul 06, 2009 | Heath Zenith Occupancy Motion Sensor Wall...
How do i wire a potterton programable controller
All you need to do is look at the wiring diagram on the back of the old room stat, you will have the following:
(normally wired with these colours)
OLD COLOUR CODING
Live (sometimes called common) - Red
Neutral - Blue
Switch Live - Yellow
NEW COLOUR CODING
Live - Brown
Neutral - Grey
Switch Live - Black
All you need to do is wire up the new stat with this in mind. (please note: if the wires are not colour coded like this then do not proceed and get an electrician)
Any problems or questions let me know
I hope this helps
Steve
Apr 23, 2009 | Honeywell Programmable Thermostat Heater
Hotpoint wd64
Check power is at these Points.
  1. Mains filter at top right - Check for live and Neutral Presence.
  2. ON/OFF Switch - Check for Power in and Out when switched on.
  3. Door Lock - Check for Power down 1 wire and when Locked, Power ( Live ) present in 2 wires. The third wire is the Neutral for the door locking circuit. Check this Neutral is OK. - Let me know.
Mar 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Leviton  Decora Light Dimmer Switch Logo
70 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Steve
Hippy_dd
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
