Question about Maytag Neptune FAV6800AW Top Load Washer
Wahser jumps around during spin cycle - Maytag Neptune FAV6800AW Top Load Washer
  • 526 Answers
Rking9847
If your machine model is an FAV6800A or FAV9800A the issue could be a Clutch malfunction.
Does the Spin cycle error out with unbalance errors such as dC or uC if your machine is one of the above machine models?
If so see this post Clutch Fix for a step by step to Clutch maintenance or replacement if necessary.
Post back if you have additional concerns with your FAV6800A or FAV9800A.
Rich
Posted on May 03, 2010
    Guru:
  • 351 Answers
Hi .. usually this will happen when the load gets unballanced. Check inside when this happens and shift some clothes from the loaded side so the washer is more ballanced. You may also have to re-level the washer, using a level adjust the feet so the washer is level and solidly suported on all four feet.
My kenmore 417 wahser making too much noise, it looks like the inner tub hitting the outer plastic housing. How can I fix it?
Have you tried moving the clothes around in the drum to balance the drum BEFORE you was them? If that works, you have solved the problem! Most people forget that when cloth gets wet it gets heavy so leaving the clothes unevenly placed in the drum dry will make a real problem when they get wet!
Dec 26, 2012 | Kenmore Washing Machines
My washer is off balance during the spin cycle it jumps, and moves around
With the washer empty, tilt it front a few inches and drop it back down. This will re-level the legs. If it still jumps around, replace the drum snubber, inside the front of the machine. It's a rubber pad that keeps the drum from moving around too much. Snubbers dry out with age.
May 07, 2011 | LG WM-2277HW Front Load Washer
How do you keep washer from jumping around during spin cycle? The washer is on one of the Maytag storage stands. It is leveled on a concrete floor but jumps around when on medium or high spin cycle. Any...
first of all if this is a new washer you need to make sure all the shipping straps or bolts are off. one way to find out is to open the door reach and grab on to the tub it supposed to be able to move up down and side to side. if not then the shipping bolts has not been removed.
Nov 05, 2009 | Maytag EPIC MFW9700S Front Load Washer
Machine makes loud banging noise during the spin cycle
The load is out of balance. Open the lid and redistribute the contents. When it's empty, grab the basket and give it a slight push sideways. It should move a little but, not free swing. If it doesn't have much resistance, the "snubber" has dried out and should be replaced. It is simply a piece of rubber in a metal bracket, that rests on the tub. When the basket spins,the snubber keeps it from jumping around.
Aug 31, 2009 | Frigidaire FWT449
Wahser stopped after wash cycle, burning smell
Hi, it is possible that something got into the pump and stopped it from turning. Let the drain hose down so that it drains into a bucket or a floor drain if possible.
If water does not drain then it is deffinetly plugged. Once you get the water out of the washer, tip it against the wall and try to remove the pump off the motor. There are two clips that hold the pump on. You will also need to remove the hoses.
With the pump off, you can set the washer back down and try to run the spin cycle. If the motor runs, it must be the pump.
Please let me know if I can assist you further.
Thanks
Vic
May 23, 2009 | Roper RAS6233KQ Top Load Washer
Water refills after a complete cyle. GHw9100L
Had similar problem and ended up being the valve. Try shutting the water off to the wahser during the spin cycle. If the water doesn't refill, that is the issue.
Mar 28, 2009 | Whirlpool GHW9100L Front Load Washer
Kenmore 110.92195110
those parts come as a complete kit. order a brake assembly.
Jan 06, 2008 | Kenmore 22422 Top Load Washer
Leak during tumble cycle
more than likely that the seal for your condensing chamber has become faulty easy fix undo any screws that hold the condesing chamber on get some bath/shower sealant that is waterproof put this around the chamber and put it back on you will have to leave it for a couple of hours but this should fix the leaking problem its not totaly common but this does happen m8
Dec 27, 2006 | Bosch Classixx WVF 2402 Front Load...
Maytag Neptune FAV6800AW Top Load Washer Logo
81 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
