My external harddrive (plug and play) has always been working well but is now not recognized by my brothers computer after a trip by airplane from amsterdam to portugal. the only thing a hear is a ticking sound, the power is working well. i can only plug it in a usb hub that is connected to my brothers computer, could this hub be the problem? please help me with some advice? thanks
    Problem Solver:
  • 6 Answers
Were you using the hard drive while in flight? High altitudes, usually around 10,000ft depending on the speed of the drive, can damage the drive. The clicking noise could be a couple of things, but is almost always the reading arm hitting something on the inside. With problems like this it's best to backup the data if you can and buy a new drive. (I would recomend an SSD drive to prevent future problems like this, but be warned they can be a bit pricey.)
If you have data you'd like to save, try plugging the drive into another usb port, or another computer if you can get access to either. Sometimes other operating systems can have luck accessing the drive, but for damaged drives it's mostly hit or miss.
If you have mission critical data that you absolutely must have there are many hard drive recovery companies that can get anything off of anything. Another warning though, they can be very pricey ($300+).
I hope this helps, and remember to be very careful with hard drives, they can be very sensitive.
Posted on May 03, 2010
Can not get computer to recognize hard drive any more?
You could try using another USB port on your computer. Perhaps that USB port you have the IOmega external harddrive plugged into is bad.
More than likely not, though.
The problem is usually inside the IOmega's case. (External enclosure)
Inside that IOmega external harddrive's case is a regular harddrive as used in a desktop, or laptop computer.
To explain;
Harddrives are physically rated in width, as well as type, and size.
A laptop harddrive is 2.5 inches across in width. (2 and a half inches)
A desktop harddrive is 3.5 inches.
The larger desktop harddrives are usually used in external harddrives that are 500GB, and larger.
(Not always the case when it comes to the 500GB size)
Harddrives have two technologies, or types.
IDE (PATA) or SATA.
You didn't state the Model Number so I can't even hazard a guess at this point.
The harddrive inside the case plugs into an Interface.
The Interface may be separate, and connected via a cable to a small circuit board, or the Interface may be soldered directly to the small circuit board.
It is this Interface, and circuit board which go bad.
The solution is to remove the harddrive inside, purchase an inexpensive external enclosure, and install the harddrive into it.
The external enclosure has a USB cable just like the IOmega external harddrive did.
As stated the harddrive inside is just a normal harddrive. Made by a harddrive manufacturer.
Could be a Western Digital, or Seagate, or Hitachi, or Maxtor, or Fujitsu, or IBM, just to name a few.
(Seagate bought out Maxtor)
On the harddrive will be a decal with it's specifications.
You will also be able to physically measure the width.
This external hookup will support harddrives that are 2.5, or 3.5 inches in width, (And 5.25), plus will support both IDE (PATA) or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7220658&CatId=3770
This external enclosure is for a desktop sized harddrive, 3.5 inches, and will support either IDE (PATA) or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1951866&CatId=2780
This external enclosure example is for laptop sized harddrives, 2.5 inches, and will support either IDE, (PATA), or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7041055&CatId=2783
Just one example of how to disassemble an IOmega Select Portable harddrive,
http://www.youtube.com/watch?v=NvUvz5Qb4vw
Other styles are listed in the Suggestions column down on the right.
Not a good source for information on disassembling an IOmega external harddrive, but there is very little info available.
(It isn't that tough for any external harddrive enclosure. The screws are usually hidden under labels, and the case pops apart in two halves. Just a little different design here, and there)
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 14, 2011 | Iomega Computers & Internet
Do I need a disc to install
This is a external hard drive and no need for you to install any software to a computer in order for it to work , this is a plug and play device you just need to wait for the computer to recognize it after you plug it to a USB port and once its recognize its ready to use.
Jun 11, 2010 | Western Digital WD Passport 250GB Portable...
Why won't my computer recognize my removable device
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
May 19, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Why can't I access anything that was copied onto my Toshiba 500G external harddrive. The computer doesn't recognize the program that made any of it, even though it's the same computer.
It is very possible the voltage on your computer's USB port is not handling the load. I would buy a "powered" USB 2.0 hub, plug it into your computer's usb port and plug the harddrive into the powered hub.
Apr 18, 2010 | Toshiba 120GB USB 2.0 Portable External...
Computer does not recognize Portable Harddrive
restart you system then plug it into different port if still not working then change the wire of ur hardrive...
Plz dont forget to rate
Sep 07, 2009 | Electronics - Others
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
Aug 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
External Harddrive Not Recognized, May be hardware problem
Caution:
When unplugging your exdternal hardrive using USB, always "Eject" that device such as your HDD.
Connecting it to another USB port (if not done yet) is an alternative.
Connecting to another computer might be a good solution and see if it will be recognized.
Re-installing the manufacturer's driver migth do the trick (if it has a driver because normally, nowadays it is Plug and Play).
Checking connectors for obvious damage will also solve this problem.
Last but not the least, these external hardrive will mal-function just like any other electronics. If it is covered by warranty, ask the manufacturer to replace it otherwise just buy a new one. The only drawback is your files or data written in that HDD.
Good Luck!!!
Jul 23, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Maxtor Basics 320 GB external harddrive cant be recognized
There's a good chance the shop you bought the drive from didn't have SP3 installed. For some reason, SP3 has an issue with USB peripheral devices. Windows has created a patch to rectify the problem. Click on the link below and install the "Fixit" patch to enable your PC to recognize your HD. Best of luck.
Greg
http://support.microsoft.com/kb/925196#fixit4me
Jun 18, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Windows XP will not recognize my WD 250GB Harddrive
Just plug your USB HDD directly into your MBoard's USB port...
Feb 09, 2009 | Western Digital 250GB MyBook External USB...
Unrecognizable USB External Harddrive
dear jpaws check your computers device manager. ithink you need drivers please install a driver.
Feb 25, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
