Question about GE WBSR3140DW Top Load Washer
How do I replace the suspension rods for my GE Adora Top load washer (model WHBRE526E1WW)? When I replace the suspension rods should I also replace the shocks?
SOURCE: GE ADORA model WHDVH626FWW
you have to clean out the filter on the bottom by removing the lower panel and twisting the cap... careful lots of water comes out but will work great after
Posted on Dec 13, 2007
SOURCE: GE Adora Front Load Washing Machine Problem
I had a similar problem...with the added issue of the door not locking at all. I cleaned the filter and all is well. However, it took me hours to find the 3 screws everyone was talking about The screws are at the very bottom of the washer, under the lip, facing front. If your machine sits on a pedestal drawer like mine, they are located between the machine and the pedestal. I hope these pics save someone a little time...
Posted on Aug 27, 2008
SOURCE: Front loading ge washer won't drain?
Similar problem fixed in less than 5 minutes. Here's a post that was very helpful. http://www.foobert.com/blog/2007/04/02/ge-adora-front-loading-washer-does-not-drain/
There's a trap located under the front panel (3 screws) I undid the filter and pulled out 21 coins, 2 buttons, a 'letter h', zipper parts, a broach, and a whole lot of lint.
My wife said that the unit never got the clothes so dry afterwords, she said the almost didnt need to throw the clothes in the dryer.
NOTE: Have a ton of towels ready, and if you can fit a bucket or dish under the filter, go slow and steady. I opened it up and had several gallons all over the floor!
Posted on Jun 04, 2009
  • 512 Answers
SOURCE: GE top loading washer does not spin out water
The belt could be broken, if not. Unplug washer for 2 minutes, plug back in, open and close lid 7 times, this should reset electronic motor.
Posted on Jun 12, 2009
SOURCE: ge adora top load washer won't spin,
the water in my washer will not empty, and it keeps pausing its self.
Posted on Sep 30, 2009
It is starting to squeak and was wondering what you suggest I do to fix it p
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
Apr 02, 2015 | GE Dryers
GE Adora GHWN5250D0WS beeps twice, wont start
Sounds like the lid switch is broken if you need more help please let me know
Mar 28, 2014 | GE Adora 3.9 cu. ft. Top Load Washer in...
My ge washer shakes alot
The washer has 4 rods that support the tub for suspension and four rubber straps to keep lateral movement to a minimum. With time the straps which are called bungys get stretched and worn out. Some times water sloshes over the top of the tub . SERVICE MANUAL
Jun 12, 2012 | GE WJRR4170E Top Load Washer
GE Adora front load washer turns until water is added then won't turn or spin
You should contact GE or qualified appliance repair center to be looked at professionally.
May 06, 2012 | GE Wh12x10309 Heater for Adora Front Load...
Washer squeaks When washing and rinsing on the right side upper drum.
There are four suspension rods that the tub hangs on. When the washer is agitating the tub will rock back and forth and the rods will move back and froth as well. To fix this noise, lift up in each rod and put some lubricant in the cup that the rods fit into at the top of the washer.
Note that it is best if you use a lithium-based lubricant rather than silicone based lubricant.
Dec 23, 2010 | GE WBSR3140DW Top Load Washer
Ge profile washing machine
Feb 18, 2010 | GE WBSR3140DW Top Load Washer
I have a top loading GE model WBB3300 that is making noise
Use a putty knife to push in the retaining clips (2) in the seam between the front panel and the washer's top, allowing front panel removal. Push tab at back of lid switch forward to allow lid switch to be removed from washer top. Remove screw on each side near top, allowing washer top to be removed. One at a time, you can unhook the suspension rods at the bottom by lifting up on the tub support frame and unhooking the rod. Lift the rod a little at the top and apply a wad of lithium grease in that ball and socket joint. Rehook the rod at the bottom, and move on to the next rod. Reassemble.
Nov 23, 2009 | Dryers
Ge adora top load tub leans to one side, but works
There are 4 suspension rods that hang the outre tup from the top frame. One is the came off during the off balance load. Easy to put back on...Remove the front panel by inserting a putty knife where the top of the machine and the front panel meet inline with the lid opening while pulling towards you. You will then be able to see the front rods. The back two are harder to see but hopefully it is only one of the front rods that needs to be reset. When you see it and compare to one of the ones that didn't come loose, it will be obvious how it is attaches.
Dec 19, 2008 | Washing Machines
GE WBSR3140DW Top Load Washer Logo
175 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
