Question about ASUS P5PE-VM Motherboard
I can`t listen music on my computer
I can`t listen sounds on my computer
  • 22 Answers
1st Step - Check the speaker volume to see if it on a audible level.
2nd Step - Check in the sound properties window in control panel if the sound is muted.
3rs Step - Check the sound properties window shows the name of a device or does it say no audio device installed. If it says no audio device that means the sound driver is missing and u can simply install the driver from the driver cd or download it from your computer manufacturer's website. < Missing driver is one of the most common issues for sound problem >
Another thing that you can try doing incase the driver is present, the volume is up and the speaker is also turned on and you still don't get sound, then you try plugging in a headphone to the system and see if you get sound on the headphone, if you do then that means the speakers are bad. If you don't then your sound card in the system is bad.
Posted on May 03, 2010
Music downloaded from computer to device Eclipse sounds terrible!
I suggest that you update the driver in your computer. I'm referring to the sound card driver but it would be better if you cover all possible drivers which might be causing this issue. Scan your computer with RadarSync and install the updates using it to cover all drivers.
I hope this helps!
David
Feb 24, 2013 | Audio Players & Recorders
The music volume is low
Depends what you're listening to. If the sound can be turned up in other locations in your computer, then the encoding of whatever music that you're listening to may just be low. Turn up your volume from both your master volume on your computer, and from the application from which you're playing the music.
Jun 04, 2011 | Computers & Internet
Hi, I have Bose in-ear headphones and the sound is really bad on them since last night. It sounds like the music is really far away and without any base. I can only feintly hear the singer and one...
It sounds like you have a faulty connection between the headphones and the music device. Try fiddling with the port of your computer, iPod, or whatever else you use to listen to music. If the headphones do this on more than one device, it's a problem with them. Fiddle with the cord while you listen and see if you can target the bad area of the cord. If you can manage to listen to the headphones successfully while tweaking the cord, you might be able to use them still, if not they're probably blown or dead. Hope this helps =]
Mar 03, 2011 | Bose in-ear headphones - Black with...
Don't listening to me any sound from my pc. Before i set up windows xp sp2 to my computer. then i can listening any sound from my pc. Today i set up windows 7 to my pc. After that i can't listening any...
Hi There,
You need to update the sound drivers on your laptop, because the sound drivers on your computer is for XP and the drivers that you must be having should be for xp. So download and install the latest version of audio drivers for your computer.
Please follow the below link and download the sound drivers respective to your laptop,
http://notebook-drivers-download.com/
Note : If your computer manufacturer's name is not listed in this website, then you might have to visit the manufacture's official website to download the latest audio drivers for your computer.
Enjoy installing the sound drivers and enjoy listening to some good music. !!!!
Oct 23, 2010 | Computers & Internet
My sound cuts in and out
I'm not sure I understood correclty, but it sounds like you're listening to something on the web. If this is the case, than it mens that the connection is to slow and is interrupted. I would like to request you to listen to audio files on your computer, let's say any MP3 music file, and open it with the Windows Media Player installed on your computer. If it works fine, than there's nothing wrong with the computer.
Apr 13, 2010 | HP Pavilion dv6000z Notebook
The speakers wil not play on the background and the center.
If you connected to a 5.1 surround card and checked and they are connected ok you can hear all the speakers when you play music, movies that are in 5.1 format only. If you want to hear also all of them if you listen to stereo movies/music you must set the sound card to emulate multi channel. Also the player you use to listen music/wath movies must be set to 5.1 and must accept Dolby Digital/ DTS decoding if your sound card doesn't(eg. VLC media player-has integrated DD and DTS decoding and codecs for all tipes/formats).
Oct 13, 2009 | Logitech X-530 Computer Speakers
My speakers wont work suddenly unless I am using my headphones
Make sure in the volume mixer that it is using the right sound device. You most likely have it set to the wrong device output. When you plugged in the headphones in kinda automatically switches, but to use the speakers again you have to do it manually. Just hook up a cheap av receiver to your computer and use this headphone input instead. a 100$ 5.1 av receiver beats any pc speaker system.
Aug 01, 2009 | Toshiba (4CH-VOUT) Sound Card
How to unlock the osd lock so i can listen to music
Easy hold down the menu button for 10 sec after the lock out pop up appears press the sound button
Jun 12, 2009 | HP w1907 LCD Monitor
My computers sound not working.
try new sound drivers for your model pc ok
Feb 07, 2008 | Dell A215 Computer Speakers
ASUS P5PE-VM Motherboard Logo
94 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
