Question about NetGear WGR614 Wireless Router
I can access the internet when connected directly to my cable modem, but cannot when I am going through my router. What are some basic troubleshooting tips to try?
    Genius:
  • 1,354 Answers
Set up a Linksys Wireless Router
Configure the Router 1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
Posted on May 03, 2010
  • 749 Answers
Make sure the router is not using the same ip address as the dsl modem, this is a very common problem as some router and modem have a habit of using the default addresses
I can not get internet access to my router, I have internet access but only by directly connecting my desktop to the modem. The modem will not send internet access to my new router.
I understand that you are not able to go online through the router WNDR3400. Please perform the below task to reset and reconfigure the router:
RESET:
With the help of a paper clip, press the reset button on the back of the router for 20 seconds (please refer to the label on the bottom of the router for reset button location). Release the reset button after 20 seconds and turn off the router. Turn the router on after few seconds.
CONNECTIONS:
1. Connect an Ethernet cable from the modem to the WAN port of the router (isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that there is no direct connection between the modem and the computer (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights to come on and then power on the router.
RECONFIGURE:
1. Open a web browser like Internet Explorer, Mozilla Firefox or Safari.
2. Access the router's GUI by typing http://192.168.1.1 or http://www.routerlogin.com.
3. When prompted for Username and Password, please enter 'admin' for the Username and 'password' for Password.
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
Please revert back for any further clarification.
Regards
Anand
Oct 03, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Tip
How to configure a wired/wireless home network
In this guide I will go over the steps needed to setup a basic home network. In this network, we will have a desktop computer, a wireless laptop, printer, router and cable modem.
*All devices should be turned off at this point*
1) The cable modem which is usually provided by your internet service provider, should be connected to your coaxial cable(broadband internet) that is active, and can be anywhere in your household. This modem can also be for DSL connections(phone line).
*If you only have one device you wish to connect to your home network, this device can plug directly into the modem and you will not need a router*
2) Next, you will need to connect the router to the modem. You will use a Cat5 cable to do this. It is also commonly referred to as a Ethernet cable or patch cable. On the modem, you will see a Ethernet port, plug one end of the cable to this port. On the router, you will see many Ethernet ports. The port you wish to use to connect the modem to the router is usually separated from the other ports and may be labeled (modem or internet). The ports labeled 1-6 for example are your LAN ports and normally for computers etc. So, plug the other end of the Ethernet cable into the port labeled modem or internet that is away from the other ports.
3) Now, for each device you wish to have wired network access(computers, laptops, game consoles) you will need to plug an Ethernet cord into each one, and plug the other end into one of the LAN ports on your router.
4) Power on the cable modem, wait 30 seconds then power on the router.
4) Next, you will need to power on your desktop in order to configure the router. Please consult your routers manual in order to do so.
5) Once your router is configured, you should be able to access it from any of your devices and these devices should have access to the internet. If you wish to have wireless access also, you will need to setup wireless security, password and a SSID. Your SSID is the name you give the router, and this is the name that will show up when you search for routers within range of your computer. Below is a picture of a list of wireless access point SSID.
6) At this point there are several ways to connect a printer. For simplicity, you can connect it to one of the computers, and give access to the other computers. The following guide will go over this step,
http://windows.microsoft.com/en-US/windows7/Install-a-printer
I hope this guide helps you in your quest to setup a basic home network. There are many factors that come into play and additional steps may need to be taking but this will get you started!
Regards,
G33k
on May 04, 2011 | Computers & Internet
My acer aspire one wont connect to internet. it says it is connected to wireless, and i have wired it to modem but the problem still persists. please help.
Based on your description, the following is assumed.
1. The service to your Internet Service Provider is through a cable or DSL modem.
2. Internet service was initially set-up with your netbook directly connected to the modem.
3. A wireless router was since added and is using the direct wired connection to the modem.
4. The netbook is connected to the wireless access point being provided by the router.
5. The netbook says it is connected to the wireless access point but still no internet access.
The problem is likely due to the modem capturing the MAC address of the netbook when access to the internet servce was initially set up using the netbook directly connected to the modem and now the modem will only allow access with the netbook directly connected to it. You can check this out by reconnecting the netbook directly to the modem. It may be possible to "flush" the captured MAC by unplugging the AC power to the modem, waiting a few minutes and then powering back up with the router connected in place of the netbook. To make it easier, you may want connect your netbook directly to the router's LAN side to check if you now have internet access through the router. If you still don't have internet access, you will need to use your netbook to log onto the router to clone your netbook's MAC address for the router's WAN connection. The router's user guide/manual has directions on logging in and doing the MAC address clone. It will also have an explanation as to what is a MAC address.
Jan 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
Unable to access internet thru router
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 15, 2010 | D-Link Computers & Internet
I have netgear wnr 2000 the router is not reconizing the internet.when i go directly to pc it works
Perform the below steps to reset and reconfigure the routerWNR2000:
RESET:
At the back of the router you will find a small tiny hole(which has a small button inside it). Press the button with the help of a paperclip. and hold it down for 30 seconds. After 30 seconds, please release thebutton and power off the device for 5 seconds.
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN portof the router(isolated port).
2. Connect the computer to the router using any one of the 4available ports. Please make sure that THERE IS NO DIRECT CONNECTION BETWEENTHE MODEM AND THE COMPUTERS (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making theconnections.
4. Power on the modem and wait for the lights, then power onthe router.
RECONFIGURE:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router, usually with http://192.168.1.1 orhttp://www.routerlogin.com.
3. Login to the router with the Username as"admin" and Password as "password" (please note that theusername and password is case sensitive).
4. Click on 'Basic settings' from the left menu and select'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem andthe router. Power on the modem and wait for the lights, then power on therouter.
Hope this allows you to go online through the router WNR2000.
Regards
Anand
Mar 21, 2010 | NetGear Computers & Internet
My internet exployer windows will not reconize my wireless router. I changed from Knology to Mediacom cable. Before I changed I was able to go wireless. I called Mediacom and I was told to contact Netgear....
Hey Sheila,
Follow the below steps to reconfigure the router:
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router (isolated port).
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
5. Click Apply.
Hope this helps.
Oct 12, 2009 | NetGear WGR614 Wireless Router
Cant connect to internet
Configuring router for Cable Internet (LINKSYS)
To configure your router for Cable you will need to set your router's WAN (INTERNET) port to 'Dynamic IP' (DHCP) option. The router is set to this option by default.
Configuration Steps:
Step 1
Connect the cable modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, default is `admin' for password and username is blank (nothing).
Step 3
After logging into the router select Setup. Set Internet Connection Type to 'Automatic Configuration (DHCP)' option. Under Setup, click on MAC Address Clone tab. Enable it and click on "Clone My PC's MAC". Do this from the computer which the cable modem was directly connected the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router.
Step 4
Click on SAVE SETTINGS and then on REBOOT THE DEVICE including the cable modem to apply the new configuration.
If you are having difficulties accessing the Internet, you need to:
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.1.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.1. You can do this on your router under Setup > Basic Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Uninstall your antivirus/firewall software (sometimes disabling or closing the software is not enough) and reboot your PC. After establishing the Internet connection through the router, reinstall your antivirus/firewall software.
Sep 02, 2009 | Linksys Wireless-G WRT54GS Router...
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to...
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Feb 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
Wireless Router Setup
There are a few things that might be wrong here. So let's go over the basics.
First off, make sure that everything is connected in the same way that it was previously. You have probably done this, but double check.
Second, try connecting your computer directly to the DSL modem through the ethernet cable. This will confirm where the problem has arisen. If you can get internet this way, but not after going through the router, than move onto the next step, otherwise, something has gone wrong in the DSL modem, or somewhere else, and it does not concern the router.
Lastly, your cable modem may have been only a modem, which means that it did nothing other than give you internet access. However, with many DSL providers, the "modems" they supply you with are more of a 1-port router than a modem. What I mean by this is that there is a good possibility your new modem blocks it's connection on certain ports.
Many DSL modems have a function to make them act as only a modem, and let a router do its job separately, but this will be specific to your modem. You may want to contact your ISP about this further.
Anyway, I hope this helps, and I wasn't too confusing. Good Luck!
Nov 15, 2007 | NetGear RangeMax WPN824 Router
NetGear WGR614 Wireless Router Logo
81 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
