Question about DeLonghi Trane 5t Rooftop Air Conditioner Ycy060g1m0ad
Heater,.... AC sends warm air when needed, but changing over time, as now that is hot outside, the cold goes well, for a while, after about 30 minutes, the AC is freezing the two tubes into the external, covered with a rubber one black and one color and thinner copper. same thruster so that is on the outside of the house as it happens ... inside and outside the tubes ... I repeat that the air is going well but then it freezes it does not, therefore I can I do? manually turn off the breaker box.
  • 674 Answers
First check your air filters and make sure the inside and outside coil are clean. If they are clean and you are getting good air flow over the coils then you probably will have to get the unit charged.
Posted on May 03, 2010
Testimonial: "thanks..."
I have a 2007 Saturn, Aura. Heater does not blow hot, slow coolant leak, & it also over heats. Please help! I'm freezing when I'm in my car!!!
You need to fix the coolant leak, then refill and bleed cooling system, then you will get heat and cure overheating problem too
Dec 16, 2015 | Cars & Trucks
I have no heat in my 2004 mercury mountaineer and i have lights that do what they want ,,what is going on with this
number of possibilites for no heat.
1. Your engine thermostat is broken and stuck in the on possistion. In the winter months, if its stuck in the open posistion, the vehicle may never get warm enough for the heater to blow hot air (i had this problem once, 13 degrees outside and even tho we had been driving for an hour, not a single bit of warm air... fixed instantly with new thermostat) this is a cheap repair
2. you have a clogged/broken or something has happened to your heater core, it is located in the dash somewhere and hot coolant flows into it. This is not terribly expensive, but labor cost may be a bit high, sometimes there not easy to get to
3. and least likely is that your heater door wont open. Does your a/c still work fine? if yes, if you leave the ac on, and turn it from cold to hot, does it stay exactly same temp or cold? or slightly warmer? if it stays the exact same tempature of cold and you cant tell that anytinh has changed, the door that closes the ac and opens to heater could be stuck/broken, etc. or the cable or electric wire controlling it could be bad..
that concludes 3 reasons you could be without heat, as far as your electrical goes, I would make sure all your fuses are in good, otherwise, who knows, electrical in cars is a whole nother ball game
Nov 01, 2013 | 2002 Mercury Mountaineer
Air cinditioning wont stay on, it switches to heat and wont shut off
What do you mean when you say it wont shut off? is it blowing hot air or do you just feel a lite flow of hot air even if you have the settings to cold?
If this is the problem that you always feel hot air at low flow and the ac goes to hot air then i would say one of two things, first if you have the selector to cold and you feel hot air then there may be a problem with the blend door, this door move to allow hot or cold air, the door may be broken or just a bad motor that controls it. keep in mind if the ac system shuts down for any reason the air then will be warm, it will be about the same temp as outside and maybe a little hotter.
this problem almost sounds like the ac compressor shuts off and then you are getting the outside air which is hot, there are many reasons for the compressor to shut off, it could be the compressor clutch heating up and disengaging , this would be due to a bad compressor clutch.
another reason is the fans are not working, the best thing to do is when the system starts to blow warm check and see if the compressor is running, start engine and look at the front of compressor, with ac off the front of it will not move, and then with ac on the front will spin, check it out and let me know, if it blows warm air and ac is not working then it may be compressor problem but if you are getting warm air and the compressor is spinning then it may be a door problem.
This is hard to check with out testing the system, so i listed a few things to check and let me know the out come. also the ac blows cold for how long before it gets hot air blowing out of the vents, good day.
May 25, 2012 | 2000 Dodge Grand Caravan
Heater doesnt work
To troubleshoot this types of problem,click the link below :---
Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
This will help.Thanks.
Mar 27, 2012 | 1994 Volvo 960
My heater is not working except on one side in my 2007 impala driver side it blows warm passenger cold
To troubleshoot this types of problem,click the link below :----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the issue.
Heater blows intermittently and temp gauge goes erratic? http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html------------Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
---------Car heater blowing warm, but not hot air? http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html-------- Heater/AC blower motor not working?
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem? http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html---------
Feb 27, 2012 | 2007 Chevrolet Impala LS Sedan New Cars
My 1997 jaguar xj6 blows air but no heat. Can anyone help? I checked all fuses, and AC works.
the only thing that can change the air from hot to cold, or vice versa is the blender door. under your dash is a box which has 2 compartments. one with your heater core which is hot and one with ac which is cold. the blender door basically diverts which on the air in your car is being drawn from. if it is cold, air is moving on the ac side. if its hot, air is moving through the heater core side. if its warm, the door is in the middle. your temperature control knob is conecteted to an actuator, which moves that door. the actuator is a motor, but if it goes out, the door will be stuck on whichever side it is on. i would check that first. hope this helps
Oct 20, 2009 | 2001 Jaguar XJ8
Fluctuating engine temp a/c sends out cold air intermittently
Here's the thing. The ECU will shut down AC if the engine temperature is too hot. If the coolant temperature sensor is malfunctioning (lying to the ECU) telling it that the temperature is hotter than it actually is, the computer will turn the AC OFF.
Sep 11, 2009 | Hyundai Motor 2003 Elantra
Fully warmed up; blowing hot and cold; Suzuki XL-7
Its just a vent damper plate not operating, it's like a gate which controls the flow of air,,usually they are operated by vacuum, or cables.
Service center time, unless you are handy with your own repairs.
Jan 19, 2009 | 2004 Suzuki Verona
Very little heat from heater
the selector flap is not moving all the way to cold or hot position. Under the dashboard on the passenger side is a heat/ac box where all the duct work for the vents originates from. inside that box is the radiator for the heater and the cooling coil for the ac. the selector flap between them is stuck or not moving all the way.
Dec 29, 2008 | 1999 Ford Taurus
DeLonghi Trane 5t Rooftop Air Conditioner Ycy060g1m0ad Logo
130 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
