Question about Proform LX660 Treadmill Walking Belt
How to align the treadmill belt - Proform LX660 Treadmill Walking Belt
TREADMILL ERROR MESSAGE
A proximity sensor is telling you the belt is incorrectly aligned. Probably too loose. Bolts on end of shafts control belt tension. Turn in if loose, out if too tight.
Sep 03, 2014 | Proform Freespirit 814 Treadmill Drive...
How to align treadmill running belt (TM1390)
see the video and fix it. God bless you
Jul 27, 2013 | Exercise & Fitness
How to replace treadmill running belt
First, you have to loosen the belt using the adjusting screws near the back of the belt assembly. Then you have to take the side moldings off.
Once the belt is totally exposed, you can take the belt off. Reverse the procedure to tighten the belt and align it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 07, 2012 | FreeMotion treadmill t7.5
The tread belt moved to one side how do I fix ir
HI,
Check the following video to know how to align the treadmill belt which is going to one side. All trad mills have the same procedure to align the belt.
Ajin
Jan 18, 2012 | Epic View 550 Treadmill
Treadmill rubber tread has strong odor
Turn off and unplug the unit before making any adjustments. Check the belt alignment on the treadmill. If the treadmill is making noise or you smell burnt rubber, the belt may be loose or out of alignment. There should be a belt roller on the side or the front of the unit. You can use a hex wrench or an adjustable wrench to loosen the belt so it can be properly aligned. Make sure you tighten the belt so it does not rub against the machine. Consult the user manual for specific instructions in adjusting the belt.
  • 2 Reposition the heart rate monitor. If the monitor does not show a reading, it may need to be repositioned. The monitor should be placed against your skin so the sensor is facing toward your body and the HealthRider logo is facing away from you. The monitor will only work if you stay on the treadmill, walking in the middle of the belt.
  • 3 Test the hand grip monitors for a correct reading. These are the metal plates that are secured to the hand railing. If the plates are dirty, they may not function correctly. Wipe them clean with a damp cloth. Your palm will need to wrap completely around the plates at all times for a proper reading.
  • 4 Reset the unit if the treadmill still does not function correctly. Unplug the unit from the electrical outlet. Leave it unplugged for about one minute and then turn the machine back on. Remove the safety key from the treadmill and reinsert it into the key slot. Taking out the key will reset the unit, clearing all memory and resetting it to factory defaults.
  • Nov 09, 2011 | Exercise & Fitness
    I currently replaced the walking belt on my C954i/C956i treadmill. When I plugged it back in and turned on the power, the treadmill has no power. What could have happened?
    Dear Sir:
    I can read you trouble, and follow the next steps:
    ALIGNING AND ADJUSTING THE RUNNING BELT
    The correct alignment of the running belt is critical to the smooth operation of the treadmill. The belt is properly aligned at the factory. However, during shipping and handling or by use on an uneven surface, the belt may move off center and require a few simple adjustments. Before aligning the running belt, check its operation by following the procedure in Checking the Alignment of the Running Belt. If you determine that the belt needs alignment, follow the instructions here. CAUTION: Special care must be taken when aligning the running belt. Turn OFF the treadmill while adjusting or working near the rear roller. Remove any loose clothing and tie back your hair. Be very careful to keep your finger or any other object clear of the belt and rollers, especially in front of the roller and behind the deck. The treadmill will not stop immediately if an object becomes caught in the belt or rollers. Realigning the belt takes a few simple adjustments. If you are unsure about this procedure, call Precor Customer Support (see Obtaining Service.) Take the following steps to align the running belt on the treadmill. To ensure your safety, make all adjustments while the treadmill is OFF. 1. Make sure the treadmill is OFF and the running belt has completely stopped. 2. Locate the right belt adjustment bolt in the rear end cap of the treadmill. (To determine left and right, stand at the rear of the treadmill and face the display.) See Diagram 24. The direction you turn the bolt depends on how the belt is tracking. Make all belt adjustments on the right rear corner bolt using the hex key provided. • If the belt is off center to the RIGHT, turn the adjusting bolt ¼ turn clockwise, which moves the running belt to the left. • If the belt tracks off center to the LEFT, turn the bolt ¼ turn counterclockwise; this moves the belt to the right. Important: Do not turn the adjusting bolt more than ¼ turn at a time. Overtightening the bolt can damage the treadmill. 3. Turn the unit ON. 4. Stand beside the treadmill and press QUICKSTART. 5. If you are prompted for a password, press INCLINE ??¼, SPEED ??¼, SPEED ??². The running belt starts automatically after the 3-second countdown appears on the display. 6. Press the SPEED ??² key until the display shows a speed of 3 mph (5 kph). 7. Walk around to the rear of the unit and observe the running belt for a few minutes. The belt should run centered along the running bed. If the belt drifts off center, you will need to make adjustments. CAUTION: If you hear any chafing or the running belt appears to be getting damaged, stop the running belt immediately by pressing the red STOP button. Contact Precor Customer Support. 8. If the belt needs additional alignment, repeat steps 1 through 7 until the belt is properly aligned. 9. After aligning the belt, press the STOP button and RESET. Turn OFF the treadmill. Tighten any loose fasteners or other components on the equipment. If you hear unusual noises or you feel that the treadmill is in need of repair or service, contact Precor Customer Support. Refer to Obtaining Service.
    Finally, check if the power cord is loose, connect it again. a) See if the breaker of Home is tripped? b) See if the breaker of the Treadmill is tripped. If do the Belt is very Tighted! loose a little. Try again.
    Thank you in advance, if you need assistance, you can contact me, Blessing. sincerely.
    E. CUADRA Managua, Nicaragua. C.A.
    Sep 26, 2011 | Precor C954i Commercial Treadmill
    Belt is slipping.... does this mean I need a new belt?
    Typically you can tighten the belt with an allen wrench at the rear of the belt, treadmill be sure to align belt before tightening. Alternate each side as you tighten
    Nov 25, 2010 | Proform XP 580 Trainer Treadmill
    My weslo cadence 200 treadmill belt keeps slipping to the left. i keep tightening and loosing it to keep it even but i keeps sliding to the left
    please look under the bottom of the treadmill and be sure that your alignment brackets are not benmt/missing. (put the machine in the storage position and look about 2/3 way down the side of the belt) you should see a metal bracket on each side pressing in on the belt. They should be pressing in about 1 1/2 -2 inches to help track the belt.
    Nov 24, 2009 | Proform XP Weight Loss 620 Treadmill
    Tread is sliding and rubbing agianst right side of track.
    Make sure treadmill is running when you adjust belt. The treadmill belt tracks as the belt goes around. I usually put machine on 2-2.5 if belt is not rubbing instantly. If belt is already against plastic, turn adj. counterclockwise on the opposite side about one full turn. You can usually move belt with your foot to see if it aligns any with turning on the treadmill. Once belt is not rubbing, turn treadmill on and continue alighing the belt.
    Jul 20, 2009 | Nordic Track NordicTrack Treadmill, A2550
    Proform LX660 Treadmill Walking Belt Logo
    87 people viewed this question
    Top Proform Exercise & Fitness Experts
    Ross Metcalfe
    Ross Metcalfe
    Matt Olenzek
    Matt Olenzek
     Atlanta Fitness
    Atlanta Fitness
    Level 1 Expert
    Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
