Question about BMW 02+ 3 5 X5 M3 Series Car Radio Wiring Harness Wire
My 325i 2001 radio doesn't have good reception to the radio? how can i fix this
  • 12 Answers
Check behind the head unit if the arial cable is pluged in or damaged, then see if u cn follow the wire to the rear of the vehicle far damage, also check of its a motorised arial make sure it extends. beware if its a factory unit like Becker, ull need a security code if the power is disconnected that you can only get from BMW
Posted on May 03, 2010
My 2001 bmw 325i doesn't have power no light no radio and the interior lights are all off
Sounds like you have a dead battery. Try recharging the battery or get someone with jumper cables to give you a jump. If your battery dies again after driving for at least an hour you likely need a new battery. If the battery in the car is the original, it's time to replace it anyway.
Jan 06, 2013 | 2003 BMW 325
2006 bmw 325i radio/cd volume low
It may be the problem of radio/CD, replace it. know more information of cars and auto diagnostic tool, it is good for protect car.
Oct 29, 2012 | 2006 BMW 325i
Am-fm doesn't work on radio 2001 tahoe, everything else works, what could be the problem
Antenna connection is the place I'd start with. Something is wrong with the cable or the connector.
Aug 23, 2012 | ACDelco 2001-2006 AC DELCO-FW311 Chevy...
How do you change the time on the clock in a 2001 BMW 325i. The manual does not say and my clock is running 8 minutes behind.
there is a button located on the end of the turn signal that controls the clock function on the dash and the radio clock.
Jan 28, 2011 | 2001 BMW 325
Need bmw 325i radio code
contact bmw dealer , give them vin #
Aug 02, 2010 | 2001 BMW 325
How do I fix the entire antenna connection (cables, etc.) on a 2001 Volkswagen Jetta? I have a 2001 Volkswagen Jetta, and when I bought the vehicle (used) it did not have an antenna. I recently purchased...
the radio could be bad as well. if the tuner in the radio is bad it wont get reception either. go with a good aftermarket one not a cheapy there no good anyway.
Apr 22, 2010 | 2001 Volkswagen Jetta TDI
Where is the timing belt on a 2001 BMW 325i??? Also, where is the ICV (Idle Control Valve) on a 2001 BMW 325i?
iac valve ( idle air control valve) its located on the throttle body, and timing belt, that year does not have a timing belt, good luck.
Nov 06, 2009 | 2001 BMW 325
Poor radio reception with Jensen VM9512 in 2001 Nissan Altima
If you used the 2 plug nissan radio harness, there should be a blue wire on there which is the (power antenna) even if your car doesn't have a power antenna, this wire needs to be connect to power on the am/fm amplified ant which is used in many nissan cars.
if the jensen has a blue or a blue/white wire, connect it to one of those. if not, you can always connect it to the red ACC wire. that should solve your reception problem..
hope this helps
Aug 25, 2009 | Audiovox VM9512 Car DVD Player
Bad reception w/ Panasonic RF-544
I solved the problem, but I did not "fix" the problem. Rather than rig an antenna to the old Panasonic RF-544 radio, I put it upstairs where it has good reception. I put the new Sony ICF-38 downstairs where it brings in the stations I listen to. The advertsizing claim for the Sony ICF-38 is that it has "Good Sound and High Sensitivity." I believe it does have "high sensitivity" because even in the basement it brings in my desired stations. (I am still curious to know if I could have rigged an antenna to the old Panasonic RF-544.) RL
Dec 07, 2008 | Panasonic RF-544 Radio
Bad radio reception
Problem: Radio Reception is bad to non-existant. AM is usually worse than FM.
Reason: Antenna connector has come loose, and needs to be reconnected. This happens when a passenger pushes the carpet toward the firewall and disconnects the plug.
Affected Model Years: 1997, 1998, 1999, 2000, 2001, 2002, 2003
Permanent Fix:
1. First check to make sure the antenna at the back of the radio has not come loose.
2. Remove the plastic cover on the front passenger door threshold held in place by three pressure clips.
3. Peel back the carpet on the front seat passenger floor.
4. Locate the coax antenna cable running along the side.
5. Reconnect the two pieces of antenna that have come loose.
6. Roll the carpet back, and re-install the threshold cover.
Nov 01, 2008 | Kenwood KDC-119 CD Player
BMW 02+ 3 5 X5 M3 Series Car Radio Wiring Harness Wire Logo
171 people viewed this question
Top BMW Car Audio & Video Experts
xxxxxx xxx
Joseph Hoffmann
Are you a BMW Car Audio and Video Expert? Answer questions, earn points and help others
