I purchased Compaq computer that came with pre-loaded with the software on a partitioned Maxtor 80 GB HD. I never created the recovery disks and am now experiencing problems with the computer. I have reformatted the HD using Seagate HD software but don't know how to proceed. I'm getting a message to insert a boot disk, which I don't have. Any suggestions on how I can proceed so that I can install Windows XP?
    Sergeant:
  • 317 Answers
Your windows xp installer is able to format a hard drive... use it...
Posted on Mar 26, 2008
6ya staff
SOURCE:
How do you do a hard reset on a Compaq Presario cq50-130us I've tried the F11 thing and it didn't work
According to the manual, only certain models had a recovery partition. The manual covers F11 recovery partition procedures for Windows VISTA, but not for Windows 7. If the unit has an SSD installed, it probably does not have a recovery partition. In that case you should use your recovery disks. These are the disks you were told to create at the time you purchased your PC. You can only make one set of recovery disks with the software provided, but they are only intended to allow you to restore the factory image should it become necessary. Many people do not read their manuals or the setup tutorials and fail to create these disks. Then, later, when they need them they are not available. If you don't have the recovery partition, and don't have recovery disks, then you have a problem. You will need to reload the OS manually, and then download and install the hardware drivers from the Compaq support site.
Nov 17, 2015 | Compaq Computers & Internet
How to do a factory reset on a Compaq Presario cq50-130us I've tried the f11 and it didn't work so please give me another option
According to the manual, only certain models had a recovery partition. The manual covers F11 recovery partition procedures for Windows VISTA, but not for Windows 7. If the unit has an SSD installed, it probably does not have a recovery partition. In that case you should use your recovery disks. These are the disks you were told to create at the time you purchased your PC. You can only make one set of recovery disks with the software provided, but they are only intended to allow you to restore the factory image should it become necessary. Many people do not read their manuals or the setup tutorials and fail to create these disks. Then, later, when they need them they are not available. If you don't have the recovery partition, and don't have recovery disks, then you have a problem. You will need to reload the OS manually, and then download and install the hardware drivers from the Compaq support site. Getting the OS disk will be the tricky part.
I dropped (about 9 inches) my Maxtor 500Gb external HD
Hi John, yes you are right. Your hard-disk is damaged due to the fall. And although your computer won't find it you may still be able to recover some information from the drive.
If running Windows, plug-in your drive and check the taskbar to see if the safely remove icon comes up. if it does then try one of the following:
1. Install and use a good partition recovery software to recover your entire partition to a safe location. I personally use EASEUS partition recovery.
2. Use a file recovery software like R-Studio to try and recover individual files
Note that either of these processes will take a while, so be patient and make sure you have lots of free space on your computer or on another external drive.
I hope this helps, all the best
Dec 01, 2013 | Maxtor Computers & Internet
Hcl laptop recovery
Some vendors have recovery partition software installed from the factory you can uninstall and it increases the HD automatically. (you will lose your recovery partition though) the other option is a software like Acronis that will repartition your drive on the fly. Careful though, this can be detrimental. FAT files can be sensitive. Also ensure your OS can handle the size you want to go to, or you will have failures there also, like it won't even see the partition!
Nov 02, 2013 | Microsoft Computers & Internet
Can`t install a O S on a new hard disk
you will need to run fdisk. to create a partition on the HD .
then format the drive c:
you can use any partition creator software
May 14, 2010 | Acer X193W LCD Monitor
How to Create EISA Partition...in Vista Or XP......
You can't. The partition was created by SONY to hold recovery files because so many people lose their installation disks. So SONY created the partition, loaded the special software on it and put options in the menu to use it.
Jan 23, 2009 | Microsoft Windows Vista Ultimate Edition
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Missing hard drive space
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Jan 07, 2008 | Computers & Internet
Can't format or create partition......
It maybe that your motherboard bios cannot support 250GB and needs an update, but caution applies here. The other problem maybe that you need to use the hardrive on the 'CS' (Cable select setting). Lastly if you already have a pc running, use this drive as the slave the go to the Maxtor website to make use of the diagnostic/formatting and partition tools.
Feb 27, 2007 | Maxtor MaXLine Plus II 250 GB Hard Drive
you can try an FDISK form a windows boot disk, but you may need to read up a little on how to use it. or maxtor has a program available on their web sit called powermax that can try to find & repair possible problems. powermax may be the best & easiest way to go. good luck.
Open Questions:
Computers & Internet Logo
35 people viewed this question
Ekse
Marvin
Marvin
