Question about Xerox Office Equipment & Supplies
Xerox phaser 3500 is printing gibberish, first screen says "printing PCL5e" then says "printing epson"
  • 2072 Answers
SOURCE: phaser 8560 blurr
There is an encoder on teh drum motor that picks up lubricant from the maintenance kit and causes those blurs. It eneeds cleaned or replaced
Posted on Jul 12, 2008
SOURCE: XEROX PHASER 3500. 8220 FUSER
LE HE CAMBIADOS DOS VECES EL FUSOR A LA IMPRESORA XEROX 3500, SE HA DAñADO SUPUESTAMENTE POR CAUSA DE LA ELECTRICIDAD, USTEDES ME RECOMENDARIAN USAR OTRA O SABER SI EL FUSOR REALMENTE HA SIDO REPARADO Y POR ESA RAZON VUELVE A DAñARSE.-
Posted on Dec 07, 2008
  • 117 Answers
SOURCE: XEROX Phaser 8560 - Maintenance Kit
They sell a lot of maintenance kits that way.I worked for a major Tampa are copier company for 10 years and they used every part until it just quit.However, you should line up a maintenance kit at the ready.Sometimes a counter will shut down the copier when it gets to the point where they want it to stop.
Posted on Apr 07, 2009
  • 2072 Answers
SOURCE: Xerox Phaser 7760 Prints White Lines Diagonally Across Page
That is normally caused by a bad developer housing.
Posted on Jul 16, 2009
SOURCE: Xerox Phaser 6250 won't print colour in Windows 7
Hello!
I had same problem and it was driving me crazy. Try this one:
Control panel -> Devices and printers -> xerox printer with mouse right click
Printer properties -> Options
From list you'll select configuration and it gives you drop down menu and from menu you need to select your printer.
I didn't try this one yet because more solid ink is still on the way but this gave me all printing options back. Before basic printing mode was selected.
Funny stuff, uh?
Posted on Mar 18, 2010
Testimonial: "see my added comments - thanks again"
How do i clean printer head on phaser 3500
From what I can remember you can only clean heads via the control panel you can't clean them manually with a cloth if that's your thoughts.
Search for purging heads and keep running off solid test prints.
I'm wondering if the colour head with a problem is Cyan.
If you can't fix it then it could be expensive.
Sorry!
Good luck.
Oct 14, 2014 | Xerox Phaser 3500/DN Laser Printer
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Xerox 3500 config page
To print a configuration page from a Xerox Phaser 3500:
- Press the Menu button
- Information will be displayed on the screen -- press OK
- Go to Info Pages, and press OK
- Go to Config Page, and press OK
To get configuration page instructions for other copiers, printers, or fax machines, go to How to Print Configuration Pages.
Nov 10, 2010 | Xerox Phaser 3500/DN Laser Printer
How do i get a network configuration page for a xerox phaser 3500
1. On the control panel, press the Menu button, then press the OK button to select
Information.
2. Select Info Pages, then press the OK button.
3. Select the appropriate information page, then press the OK button to print.
Note
Print the "Menu Map" to see other information pages available for printing.
Hope this helps
Kevin
Phaser 8560N prints multiple pages when powered on
This was due to the TFTP (PXE) setting on the printer set to on. No more wasted paper at startup/wakeup after changing setting to off.
Jan 12, 2010 | Xerox Phaser 8560N Laser Printer
XEROX PHASER 3500 ERROR CODE TSK-ROOT 1087
most possible cause is the Memory added above the 32MB base is failing. if thats how you have it setup.
Remove the additional memory module from the machine and test the machine. If the machine powers up and prints correctly this confirms the additional memory has failed. Insure the memory removed form the machine is the correct memory for this product and that it was installed correctly. Replace the defective memory if it is Xerox memory. If the memory was purchased by the customer and is not Xerox memory they will need to file a warranty claim with the company they purchased the memory from.
Dec 23, 2009 | Xerox Phaser 3500/DN Laser Printer
Xerox 3500 blank pages xerox 3450 display flashes
Clear all memory under maintenance will solve this
Feb 05, 2009 | Xerox Phaser 3450DN Laser Printer
Problem printing in color on Xerox Phaser 8200 from Mac
That actually should make magazine quality color.
What are you experiencing? Do the colors not match? Are there smears or light streaks?
I will gladly work with you to revolve your problem, I just need a frame of reference to start.
Let me know.
You may simply need to download and install a different driver.
They are on www.xerox.com you should be running the PS version of a driver for better graphics.
Apr 02, 2008 | Xerox Phaser 8200 Laser Printer
193 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
