Question about Husqvarna 28cc Gas Line Trimmer
Husqvarna pull cord problem
Pull cord won't turn the engine over, just pulls through freely before retracting.
  • 4,234 Answers
I had this happen after about 15 uses. I just exchanged the unit. The pull start mechanism can be ordered and is easy to replace. There are parts inside that are nylon and break easily. Any local dealer can order the part for you.
Dan
Posted on May 03, 2010
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
Pull cord binding when mounted on engine but not when removed from engine
When you assemble the Recoil Starter, push it down onto the blower easily and then pull the cord slowly. It should drop into position as you slowly pull the cord.
May 07, 2015 | Poulan Garden
Pull cord won't engage
remove the sparkplug and try to turn the flywheel if it turns freely then the engine is most likely ok. if it does not turn you have a locked engine that means its toast. If it does turn then you have to look closely at th pull recoil that it is engaging the flywheel.
May 04, 2014 | Echo Blower Nozzle Es 2400 Pb 200 201 2100...
Starter cord will not pull
The pull cord or rope works on a tight spring just under the cover that the rope is in. Usually three to four small bolts on the edge of the cover to remove to repair/replace either the spring or the rope. First I would try to turn the motor manually with your hand on the flywheel, it should move around either direction freely with no effort. If it does not the motor itself maybe stuck not the rope. Then you have a seized engine and a different problem to deal with.
Dec 27, 2013 | Husqvarna 41 141 41 136 36 Recoil Pull...
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
Pull cord pulls hard won't start
Remove the top engine flywheel & pull cord cover
Most likely dirty,as well as worn out. or the cord
is in the wrong place,you will see that,once apart
You can work on it some & down the road
get a new one if you have to
Jun 11, 2012 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
I have a Husqvarna 455 Rancher chainsaw with a 20"
Part of the cord must of got into the clutch if its not the retracting mechanisem or spring you are on the right track. The olny question i have is if its a 2007 why did the cord fail so quickly. rebuild it you will find the answer I can't see it and you sound vary capabale of fixing this
Dec 19, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Problems with pull cord ,pull cord not engageing,pull cord is slipping freely.it acts like a bad spring on a briggs,but iam not familiar with this make.
Pull cords are all pretty similar so if you've seen one then etc.....
Does the cord retract?
If it's a broken spring then the pull cord would not retract.
If it is retracting then it's probably dirt, grass clipping interfering with the spring loaded locking lever.
Either way the only way to be sure is to remove the top cover and inspect it visually and clean it out and spray some lubrication on it.
You should be able to do this without taking apart the actual cord and retracting coil spring. It should come off as a unit.
Once you have inspected it if you you have any other questions please let me know.
Hope this helps.
Jun 16, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
My Husqvarna 232R brushcutter pull cord will not start
There should be several 'dogs' exposed after removing the starter assembly. These 'dogs' should rotate into the flywheel nut when the cord is pulled causing the engine to turn. Check with a Husky servicing dealer for parts. Good luck!
May 24, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 28cc Gas Line Trimmer Logo
1,056 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
