Question about Panasonic Viera TH-46PZ85U Plasma TV
I have a Th-46pz85u panasonic plasma tv that is blinking the power light 10 times. I was curious to see what the replacement part is to fix that problem. I have the Panasonic error codes and that error code points to a power supply. I have measured the voltage on the emc filter output and I only have 120V. Should I have 250V output on that emc filter and could the emc filter be my problem and not the power supply? Adam
  • Anonymous Mar 12, 2014
    HOW TO TEST PART TDK EMC Filter RPEN-02908FA-00 HB TO SEE IF IT IS WORKING- IT HAS 120v ac GOING IN BUT NO POWER OUTPUT. DOES THIS MEAN THIS PART IS BAD?
    HOW TO TEST a TDK EMC Filter RPEN-02908FA-00 HB TO SEE IF IT IS WORKING- IT HAS 120v ac GOING IN BUT NO POWER OUTPUT. DOES THIS MEAN THIS PART IS BAD?
  • Panasonic Master
  • 8,457 Answers
Yes,this codes is a 100% correct is ur power supply board.U searches all around the power supply board and it supporting boards for those leakages gases capacitors?These capacitors alway have bulges on it top or puff on it top.Replaced these bad capacitors,u will get ur power voltages stable and ur power supply board will work.Not,than one or more of ur power transformers have a shorted power pins legs.The power transformers,coil is dead.The transformer must be replaced.
Posted on May 03, 2010
PANASONIC TH-50PX75U PLASMA TV LED LIGHT BLINKING 10 TIMES
That is a power suuply problem,i have the same problem i looking for a solution to fix my or i gonna buy a new one,also new onw is spensive on ebay some people offer the repair service good look
Sep 03, 2012 | Panasonic TH-50PX75U Plasma HDTV
10 blinks code
I don't know what to do with 10 blinking of my Panasonic TH-46PZ85U.
I bought It in summer 2008...is it already kaput ? I'm not sure any more to want to make repair my tv set. I wonder how much could it cost ? Bye-bye plazma.
Aug 18, 2012 | Panasonic Viera TH-46PZ85U Plasma TV
Panasonic plasma th42pz85u blinking light 10 times
This is the error code, indicating a failure inside the board. Might need attention by a qualified service technician.
Jul 30, 2012 | Panasonic Viera TH-46PZ85U Plasma TV
TV no longer powering up. Red power light blinks 10 times, stops, then repeats. Tried holding down the power button, turning off the tv for a while, plugging directly into wall instead of surge...
Bad or blown capacitors. Look on circuit board for domed, bulging or leaking capacitors. USE CAUTION!! high voltage capacitors can electrocute you. They should be properly discharged before working on circuit board
Jun 28, 2011 | Panasonic Viera TH-46PZ85U Plasma TV
Panasonic - TH-46PZ85U - Will not power up, either from the remote or from the TV on-off power button. With the TV plugged in, a light on the bottom left corner flashes 10 times, pauses and then the...
Could be a cooling fan failure, there are five fans across the back of this tv ( i think) if even 1 fails the power supply shuts down. If so fan needs replacing,
pete
Nov 11, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
I have a Panasonic TH-46PZ85U Plasma TV with a two blinking light code, no picture. How do I fix. I Have removed the back panel and looked for damaged caps but I do not see any.
hi; the blinking light code means that you have a fault in the power supply unit, unplug the tv from the power source, check all transistors you will find some of there shorted, just replace them; if you need a help about repairing i'll help you
Nov 06, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
My panasonic th-46pz85u has 2 blinking lights and wont turn on
The power supply board it dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 21, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic TH-46PZ85U when i turn on tv does not go on but red power light flashes. What can I do to fix this?
Power supply board is dead.Must change the power supply board to solved this.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 19, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
7 blinking Red Light. Power Supply problem??
Need replaced su.sd and sc board
Panasonic TXNSC1RKTUS SC BOARD BOARD, SCAN DRIVE ASSY
Panasonic TXNSU1RKTU SU BOARD BOARD, UPPER SCAN OUT ASSY
Panasonic TXNSD1RKTU SD BOARD BOARD, LOWER SCAN OUT ASSY
Dec 09, 2009 | Panasonic Viera TH-46PZ85U Plasma TV
Panasonic th46pz85u wont power up and red led light blinks 10 times
10 blinks can be a host of problems with the television. Something has failed and tripped the SOS detect circuit (causing the 10 blinks).
You would have to take this thing apart and trace down voltages from the P, A, D, SC, SS boards to determine what could cause it. Hell, even the memory card reader on the front can cause a 10 blink error.
You will want to see a professional.
Jul 27, 2009 | Panasonic Viera TH-46PZ85U Plasma TV
Panasonic Viera TH-46PZ85U Plasma TV Logo
1,210 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
