Question about Dell Dimension 8200 PC Desktop
Replace on/off switch dimension 8200? - Dell Dimension 8200 PC Desktop
  • Dell Master
  • 5,660 Answers
The On/Off switch is the Power On switch.
The switch itself is tiny, and is located inside the plastic Power On button assembly.
There are plastic tangs on the Power On button, which hold the switch in place.
I use a hair dryer set on low heat, to gently heat the tangs so they will spread easily, to remove the switch. (Move the hair dryer slowly back, and forth)
You can also set the Power On assembly in a bowl of Very warm water, to temporarily soften the tangs.
(The switch is no good anyway. Dry the plastic Power on assembly before installing the new switch)
This switch is usually a replacement,
http://www.directron.com/atxswitch.html
To remove the Power On button assembly the computer case is opened.
BEFORE you start, the computer Must be unplugged from power, and you should observe anti-static precautions.
Your body carries Static electricity. Static will fry out (Short Circuit) the components inside a computer.
You can either,
1) Buy a $6 ESD wrist strap, connect the wrist band to your wrist, and connect the alligator clip to the metal frame of the open computer case,
OR,
2) You simply touch the metal frame of the open computer case to relieve your body of static.
(Again, computer unplugged from power.
Also, IF you get up, and walk away, when you return TOUCH the metal frame again)
This is Dell Support, and the Service Manual for the Dell Dimension 8200 desktop computer,
http://support.dell.com/support/edocs/systems/dim8200/
To open the computer case:
Click on Opening the Computer Cover
The computer cover opens like a clamshell.
Observe where the cables (Wires) go to the motherboard, from the Front of the computer case.
You may wish to make a drawing, and notes.
Dell DOES NOT state where the wires go.
If any wires are accidentally bumped loose, you will have a schematic made by you, of where they go.
As you proceed, state any problems you are having, and let's see if I can rectify them with information. Simply state in a Comment.
Posted on May 03, 2010
I was replacing the light switch in my bedroom and while turning the screws on the metal cover, accidentally the screw touched a live wire and made the circuit braker in my apartment to go off. Together with it, my Dell dimension 8200 went off too (I was playing music on my Dell desktop). Since then, I have not been able to turn on my desktop again. When I press the on/off buttom, nothing happens. I gess I messed up some part of it, but I don't know which part so I can replace it. Does anybody know what could be the problem? or what part do I need to replace?
Posted on Sep 29, 2012
3 Suggested Answers
  • 111 Answers
SOURCE: Possibility of using Dimension 8250 memory in a Dimension 8200
Probably not, but to confirm go to this link. When you're there plug in the info for both machines and compare the memory configurations.
Posted on May 25, 2009
joecoolvette
  • 5660 Answers
SOURCE: Dell Dimension 8200 does not power up.
1) It could be something as simple as the 4-pin ATX +12 Volt power cable isn't plugged into the motherboard.
The 4-pin +12 Volt power cable supply's power to an Intel Pentium 4, and above, processor.
Looks like this,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The connector can be Black or White in color. However, there will always be two Yellow wires, and two Black wires.
(Yellow is 12 Volts. Any Black wire is a Ground wire)
Looking at the motherboard with the Processor to the top, Ram Memory to the right, and the AGP graphics card expansion slot, towards the bottom.
The connector for the above power cable is white in color, and square shaped. (May be Black) It has four socket holes in it.
This connector is located in-between the Processor, and the AGP slot, towards the I/O ports on the motherboard.
This is Dell Support, and the Service Manual for the Dimension 8200,
On this main menu page left-click on - Technical Overview
Scroll down the page to the second illustration. (Under the heading - System Board Connectors and Sockets)
Where the arrow that points from, + 12VDC power connector (JC51), is the connector on the motherboard for the above power cable.
2) It could be something as simple as the Ram Memory modules, or module, has been jarred loose. (Ram memory 'Stick')
3) It could be that the Power On switch has failed.
There is a way to bypass the Power On switch to test if the switch is bad, or not.
This has been lightly touched upon already, but not fully detailed, and not in a safe manner.
There is always 5 Volts present at the Power Supply. When the 5 Volts are redirected to the Soft Power On part of the Power Supply, the power supply turns on.
The 5 Volts are redirected by the Power On switch. (Located behind the Power On button)
The Dell Dimension 8200 Desktop PC uses a 20-pin ATX main power cable connector.
This is a close up view of that style of connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
View the photo to the far right. You will see a Green wire. This Green wire is the Soft Power On wire.
You will see many Black wires. ANY Black wire is a Ground wire.
If a jumper wire is touched briefly from the Green wire to Any Black wire, the power supply will come on.
(Provided the power supply is good)
The contact of the jumper wire, should not last any longer than 2 seconds.
There is a Spark involved, which is why safety guidelines should be implemented!
Advise using a wire that has insulation around it. Wire thickness, or gauge, should be close to one of those power supply wires.
Length approximately 3 inches.
The insulation is stripped back off of each end of the wire. Usually about 1/2 inch stripped off, will do.
The jumper wire is then bent into a U shape.
The jumper wire has to go in the socket hole of the Green wire, and Any Black wire.
The 20-pin main power cable connector remains connected to the motherboard. Just like in the photo to the right.
The photo to the right shows the back of the connector. The back of the connector is where the wires enter.
The front of the connector is plugged into the motherboard.
The jumper wire goes down in the socket hole, from the Back of the connector.
The bare wire ends must be long enough to touch a metal connector, that is way down in that socket hole.
My method:
Computer unplugged from power.
I twist both bare ends of the jumper wire until they are tight. One end goes down in the Green socket hole. I try to make sure it is a good connection, and will stay there by itself.
Then I plug the computer into power, and push the other end of the wire down into a socket hole, of ANY Black wire.
You just need a momentary contact.
4) For a time period Dell was a Proprietary computer manufacturer.
They wanted THEIR computer parts used in THEIR computers.
They switched the color code around on the 20-pin ATX main power cable connector.
A) Yellow is 12 Volts
B) Red is 5 Volts
C) Black is a Ground wire
D) Orange is 3.3 Volts
E) The Green wire usually designates the Soft Power On wire.
(PS_ON....Power Supply_ON)
Look to see that the color code of your new power supply ATX main power cable wire, match that of the old Dell power supply.
Would appreciate hearing about your findings. You can post this in a Comment.
Posted on Feb 18, 2010
My Dell Dimension 8200 will not power on after a short circuit
Starting piont would be the power supply. Any power there at all? Test with a voltmeter.
Sep 29, 2012 | Dell Dimension 8200 PC Desktop
How to replace the motherboard
The procedure to replace the motherboard for the Dell Dimension 8200 is explained in this document under the section "Replacing the System Board":
http://support.dell.com/support/edocs/SYSTEMS/dim8200/replace.htm#1114089
Nov 28, 2009 | Dell Dimension 8200 PC Desktop
I want to replace CD drive on Dell Dimension 8200. My options are serial ATA, parallel ATA & ATAPI. Which one do I need?
This computer has 2 IDE connectors. These are parallel ATA connectors.
See: Dell Dimension 8200 Specs
If you get a drive, look for IDE on the package. IDE, PATA and ATAPI are near synonomous. They use a 40 pin flat ribbon cable to connect.
Thanks for using Fixya.
Nov 25, 2009 | Dell Dimension 8200 PC Desktop
Bad network card in a Dell Dimension 8200. What
You can purchase ethernet card "realtelk ethernet lan card "
Realtelk is best network card right now.
Also Dlink network card is also good.
Jul 24, 2009 | Dell Dimension 8200 PC Desktop
May 25, 2009 | Dell Dimension 8250 PC Desktop
Dell Dimension 8200 won't power up
If the power button does not light up at all, I would guess the power supply has a problem.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 8200 PC Desktop
Dimension 8200 Upgrade Heat Sink Problem
you can contact online for techsupport at dell at www.support.dell.com this a live tech support session totally free they have helped me out numerous times keep me posted on how this goes ok best regards mike
Aug 12, 2008 | Dell Dimension 8200 PC Desktop
Dimension 8200 will not turn on
Try a new power button. Also does the machine power light turn on at the front of the machine? if so check that the CPU is seated correctly as if it has come out of position then the machine doesn't boot. I would like to think power switch though.
Thanks J
Jan 17, 2008 | Dell Dimension 8200 PC Desktop
Dell Dimension 8200 PC Desktop Logo
340 people viewed this question
Alun Cox
