Question about Maytag 24 in. MDB3700 Built-in Dishwasher
Dishes have a white substance on them after washing
How do I clean the filter if that is the problem
    Guru:
  • 351 Answers
Hello ./. the whiote deposit could be washer solution .. or could be the hgardness of your water. if you have a water softener you should check it for proper opperation. If you run the washer without detergent and stuill get the deposits , then is is not the washer, but is in the water system somewhere. Try using a rinse agent to get a good clean rinse and you may solve to situation that way.
Posted on May 03, 2010
How do I get rid of white residue on dishes in dishwasher?
if its hard ? then its minerals in your houses water , install a demineralize filter on the washer line , if it flakes off with your finger nail then its left over soap , your using too much or your water pump needs cleaned out or replaced
Aug 15, 2016 | Kenmore Dishwashers
DISH WASHER RUNNING FINE . NOT CLEANING AS GOOD AS USED TO. LEAVING DISHES NOT ALWAYS REAL CLEAN. IS THERE FILTERS TO CLEAN ?
Run 1 quart of white vinegar through a wash cycle.
Use only powdered detergent when washing.
Use a rinse aid product like Jet Dry.
Dec 12, 2010 | Whirlpool Dishwashers
WONT WASH CLEAN ALWAYS RESIDUE LIKE SAND ON GLASSES ETC. THAT IS ALMOST IMPOSSIBLE TO EVEN REMOVE BY HAND WASH ENOUGH SALT AND RINCE AID ALSO CLEAN FILTER EACH TIME NO OBSTRUCTION IN PUMP FILTER...
use CLR to remove any build up and then use LEMI-SHINE (walmart in dishsoap aisle) for the cleaning of your dishes. Works great for me as i have the worst well water on the planet.
Aug 11, 2010 | Dishwashers
I have a Whirlpool Quiet Partner II that used to
ok first prime the sink then put a table spoon of tang in dispensor then run the unit this will clean the dish washer
Jun 30, 2010 | Dishwashers
Film left on dishes
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Apr 27, 2010 | Kenmore 15899 Built-in Dishwasher
How do you remove white residue caused by the dishwasher?
If the white residue is a soapy substance cut down on the amount of detergent you are using. If it is a mineral built up, try using some TANG or another type or citric acid and wash thru with no dishes in the dish washer. The tub should come out sparkling clean!!
Apr 04, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes not completely drying and white powder residue left.
Do you have a water softner? If so you are using to much soap in your machine. Go to wal-mart and buy a container of dishwasher clean ( it is by the rinse aids) run that through to remove any excess soap and then cut down on the amount of detergent that you are using. 1-2 tablespoons only.
Jan 21, 2009 | Kenmore Elite 45986 Front Load Washer
GE Profile Dishwasher (5 years old); Leaving residue on dishes
In my case the counter mounted breather for the drain tube was being restricted ... finally to the point it would not drain the tub at all. I disassembled the above counter drain assembly and cleaned it out as it wass completely blocked and things work very well again. I would suggest this foirst as it is an easy task and is done 'above the counter'.
I then ran 2 cups of CLR with wash cycle ... no dishes to clean out the rest of the washer as on dissaembly of the internals to diagnose they were and very scummed up with a hard white crusty substance that was completely blocking some of the drain sump performations.
Dec 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
Having a problem with a white powdery substance Model 17602
The sump may be full of debris here is how to check it:
ok in the dishwasher you will see you lower spray arm. take it off. now going up the back is the supply tube. you need to pop it off of thed top then the back and turn it clockwise to get it off the motor. after you do that you will see 4 torx screws. take all 4 out and you will be able to remove the fine filter. thats the normally grey piece with all the slots. after you remove the filter you will see two more torx screws. remove them they are for 2 seperate pieces one is the foreigh food seperator and the other is the chopper cover. remove both of them and clean the whole thing out. as yiou are puytting it back together. let me know if you get stuck
Nov 28, 2008 | Kenmore 24 in. 17602 / 17604 / 17609...
Poor/Uneven Wash Quality
there is a new product out that filters the water going into your dishwasher. it works great and my dishes look fantastic. they use to look dirty with a white film on them. after the first load when i hooked up the dishwasher filter my dishes looked brand new. it is affordable and works everytime. you can get it at www.dishwasherfilter.com.
Oct 11, 2007 | Kenmore 15529 Built-in Dishwasher
Maytag 24 in. MDB3700 Built-in Dishwasher Logo
116 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
